POV-Ray : Newsgroups : povray.binaries.images : Problem with text object Server Time
18 Feb 2026 14:26:34 EST (-0500)
  Problem with text object (Message 1 to 3 of 3)
Subject: Problem with text object
Date: 9 Dec 2011 20:02:08
Message: <4ee2af90@news.povray.org>
Hi(gh)!
Perhaps once more a stupid beginner's mistake (after 16 years of
POVing... it's just humiliating!): I'm just not able to place a text
object (within an object pigment pattern) on a box tilted by 30 degrees
around the x axis!
Here is the code:
   #declare Display_Card_Rounding=
   cylinder
     0, <0.1, 0, 0>, 0.0015
   #declare Display_Card_Panel=
   box
     0, <0.1, 0.03, 0.003>
   #declare Display_Card=
   union
     union
       object { Display_Card_Rounding }
       object { Display_Card_Panel translate <0, 0, -0.0015>}
       translate <0, 0.0015, 0>
       rotate <30, 0, 0>
     union
       rotate <-30, 0, 0>
       translate <0, 0, 2*(0.0315*cos(radians(60))+0.0015*sin(radians(60)))>
     difference // Display card top
       cylinder { 0, <0.1, 0, 0>, 0.003 }
       plane { y, 0 rotate <30, 0, 0> }
       plane { y, 0 rotate <-30, 0, 0> }
       translate <0, 0.0315*sin(radians(60))-0.0015*cos(radians(60)),
0.0315*cos(radians(60))+0.0015*sin(radians(60))>
#declare N_Brushed=
normal
   granite
   bump_size 0.5
   turbulence 10
   scale <1, 0.001, 0.001>
#declare F_Metallic_Low_Ref =
finish
   diffuse 1
   brilliance 0.7
   specular 1
   roughness 0.001
   reflection 0.05
   metallic
#declare T_Brushed_Aluminium=
texture
   pigment { color rgb 0.6 }
   finish { F_Metallic_Low_Ref }
   normal { N_Brushed }
object
     Display_Card
     texture { T_Brushed_Aluminium }
     texture
       pigment
	object
	  text
	    ttf "/media/disk1part9/fonts/lucon.ttf"
	    "T_Stone1", 0.001, 0
	    scale 0.01
	    translate <0, 0.01, 0>
	    rotate <30, 0, 0>
	  color rgbf 1
	  color rgb 0
// end of code
All I ever get is an empty aluminium panel (see attachment)... what goes
wrong?
See you in Khyberspace!
Yadgar
Download '2011-12-10 includes showroom 1, take 75 - display card.jpg' (19 KB)
Preview of image '2011-12-10 includes showroom 1, take 75 - display card.jpg'
Subject: Re: Problem with text object
Date: 10 Dec 2011 02:03:22
Message: <4ee3043a$1@news.povray.org>
> around the x axis!
> wrong?
The text object you use for the pigment pattern is extremely thin (0.001
scaled by 0.01 = 0.00001), and not close enough to the surface you want
to texture.
You apparently want to attach it to the z=0 surface of the
Display_Card_Panel that, in total, undergoes the following transformations:
     rotate <30, 0, 0>
You have to apply all of these to you text object (it seems you forgot
the first one) after the scaling, /plus/ a translation before the
scaling so that the z=0 plane lies entirely inside the text object (to
avoid coincident surface problems), i.e.:
   text
     translate <0, 0, -0.0005>
     scale 0.01
     rotate <30, 0, 0>
Date: 10 Dec 2011 17:56:37
Message: <4ee3e3a5@news.povray.org>
> Hi(gh)!
> around the x axis!
Why don't you create your box parallel to one plane, say the X-Y plane,
Much simpler = lot less place for mistakes.
