Hi(gh)!
Perhaps once more a stupid beginner's mistake (after 16 years of
POVing... it's just humiliating!): I'm just not able to place a text
object (within an object pigment pattern) on a box tilted by 30 degrees
around the x axis!
Here is the code:
#declare Display_Card_Rounding=
cylinder
0, <0.1, 0, 0>, 0.0015
#declare Display_Card_Panel=
box
0, <0.1, 0.03, 0.003>
#declare Display_Card=
union
union
object { Display_Card_Rounding }
object { Display_Card_Panel translate <0, 0, -0.0015>}
translate <0, 0.0015, 0>
rotate <30, 0, 0>
union
rotate <-30, 0, 0>
translate <0, 0, 2*(0.0315*cos(radians(60))+0.0015*sin(radians(60)))>
difference // Display card top
cylinder { 0, <0.1, 0, 0>, 0.003 }
plane { y, 0 rotate <30, 0, 0> }
plane { y, 0 rotate <-30, 0, 0> }
translate <0, 0.0315*sin(radians(60))-0.0015*cos(radians(60)),
0.0315*cos(radians(60))+0.0015*sin(radians(60))>
#declare N_Brushed=
normal
granite
bump_size 0.5
turbulence 10
scale <1, 0.001, 0.001>
#declare F_Metallic_Low_Ref =
finish
diffuse 1
brilliance 0.7
specular 1
roughness 0.001
reflection 0.05
metallic
#declare T_Brushed_Aluminium=
texture
pigment { color rgb 0.6 }
finish { F_Metallic_Low_Ref }
normal { N_Brushed }
object
Display_Card
texture { T_Brushed_Aluminium }
texture
pigment
object
text
ttf "/media/disk1part9/fonts/lucon.ttf"
"T_Stone1", 0.001, 0
scale 0.01
translate <0, 0.01, 0>
rotate <30, 0, 0>
color rgbf 1
color rgb 0
// end of code
All I ever get is an empty aluminium panel (see attachment)... what goes
wrong?
See you in Khyberspace!
Yadgar
Download '2011-12-10 includes showroom 1, take 75 - display card.jpg' (19 KB)
Preview of image '2011-12-10 includes showroom 1, take 75 - display card.jpg'
> around the x axis!
> wrong?
The text object you use for the pigment pattern is extremely thin (0.001
scaled by 0.01 = 0.00001), and not close enough to the surface you want
to texture.
You apparently want to attach it to the z=0 surface of the
Display_Card_Panel that, in total, undergoes the following transformations:
rotate <30, 0, 0>
You have to apply all of these to you text object (it seems you forgot
the first one) after the scaling, /plus/ a translation before the
scaling so that the z=0 plane lies entirely inside the text object (to
avoid coincident surface problems), i.e.:
text
translate <0, 0, -0.0005>
scale 0.01
rotate <30, 0, 0>
