POV-Ray : Newsgroups : povray.binaries.images : Realistic indoor radiosity - I still don't get it! Server Time
21 Jul 2026 09:22:41 EDT (-0400)
  Realistic indoor radiosity - I still don't get it! (Message 21 to 24 of 24)
Subject: Re: Realistic indoor radiosity - I still don't get it!
Date: 17 Jan 2012 07:18:01
Message: <4f1566f9$1@news.povray.org>
Hi(gh)!
On 13.01.2012 16:29, Hildur K. wrote:
> inside you have to use two different radiosity settings for each situation.
...and as I aim at building consistent worlds which I would like to
animate, this is a show-stopper! How can I move the camera from inside
to outside (e. g. through an open door) without getting those weird
brightness oscillations like with cheap digital cameras in video mode?
> One tip: try to avoid using colors for surfaces that are 100% white (or 100%
> black for that matter) they can never be realistic.
> One more thing. The recursion limit of 5 is probably a bit too high for your
> scene as you are getting more light in through the windows than in the tutorial.
> "recursion limit" controls how many times indirect light bounces off the
> surfaces. Where there is little light coming in you typically use higher values
> to get more light in you room. Every situation is unique so you may have to try
> out a few variations. Too much recursion washes away the contrast, too little
> and your scene is too dark. Only do this AFTER you set the material finishes to
> Try playing with the balance between "recursion limit" and "brightness".
> I usually use recursion limit of 3-5 indoors and 1-3 outdoors.
> If you start getting "dirt" or dark smudges on your surfaces, that means you are
> on the right track. Those you should be able to get rid of in the final
> rendering by raising "count" to 400-600. It takes longer to render but that is
> the necessary evil of radiosity.
Thank you for your advice... but meanwhile, Thomas de Groot has provided
me with some settings which work well both inside and outside... and
render FAST, the "kitchen" scene takes only about 4 minutes on my Athlon
64 3500+!
When it comes to animation: is there any way to avoid that strange
"flickering" of radiosity between the frames?
See you in Khyberspace!
Yadgar
Date: 17 Jan 2012 07:33:19
Message: <4f156a8f@news.povray.org>
And just like our eyes too. Sometimes PovRay shows that our imagination
is better than real life.
I am pleased that Thomas has come up with a compromise solution.
Regards
Date: 17 Jan 2012 07:48:03
Message: <4f156e03$1@news.povray.org>
> Hi(gh)!
>> outside and
>> situation.
Not only cheap cameras you know. Watch any TV documentary and you will
see brightness adjustments being made while the camera moves from inside
to out or vice versa. In movies I suspect they avoid this by shooting
scenes either inside or outside and making the view through the window
artificial by using a backdrop for instance which they can tune to the
scene. By the way, there is a method to achieve this brought to us by
Tim Nikias back in 2005: www.nolights.de using his glare.inc macro for
creating a backdrop image. His example is the Waiting for Company scene.
> 64 3500+!
...And I learned a lot about radiosity in version 3.6 from Hildur! :-)
Good to see you here again once in a while, Hildur!
Date: 20 Jan 2012 21:45:00
Message: <web.4f1a24994ccf544d85de7b680@news.povray.org>
The +HR command line switch in 3.7 may help with this.  I haven't tried it
myself, so you'll have to experiment.
You are, of course, using -J for anti-aliasing.  (That actually hasn't worked
for me in 3.7, but Christoph hasn't reproduced the problem.)
