POV-Ray : Newsgroups : povray.binaries.images : Following a tutorial on radiosity... Server Time
28 May 2026 07:05:26 EDT (-0400)
  Following a tutorial on radiosity... (Message 8 to 17 of 17)
<<< Previous 7 Messages Goto Initial 10 Messages
Subject: Re: Compiling POV-Ray 3.7 for Linux
Date: 25 Oct 2011 18:43:04
Message: <4ea73b78@news.povray.org>
Hi(gh)!
On 26.10.2011 00:32, clipka wrote:
> That should be a *.tar.bz2 file actually. You won't get far with the
> Windows zip file on a Linux machine :-P
In fact it is! But I'm not even able to unpack the archive with ark
correctly - all I get is an error message saying "libarchive is not able
to process the archive file"!
See you in Khyberspace!
Yadgar
Subject: Re: Following a tutorial on radiosity...
Date: 26 Oct 2011 03:51:00
Message: <4ea7bbe4@news.povray.org>
Compare with this scene I happen to work on at this moment and rendered
with version 3.7...
Download 'at the jackal_03.png' (683 KB)
Preview of image 'at the jackal_03.png'
Date: 26 Oct 2011 06:04:07
Message: <4ea7db17$1@news.povray.org>
> Hi(gh)!
I don't know that "ark" you're mentioning; do you mean arc? arj? ar?
 From what I know, each of these three is specialized on one special
type of compressed file respectively, none of which is the bzip2 format.
The traditional official way to extract the contents should be:
     bunzip2 povray-3.7.0.RC3.tar.bz2
     tar -xf povray-3.7.0.RC3.tar
The following single command should also do the job:
     tar -xjf povray-3.7.0.RC3.tar.bz2
Date: 26 Oct 2011 09:42:49
Message: <4ea80e59$1@news.povray.org>
Hi(gh)!
This worked... but then the next problem: after ./configure
I got this:
This is an unofficial version compiled by:
The POV-Ray Team(tm) is not responsible for supporting this version.
Environment
checking build system type... x86_64-unknown-linux-gnu
checking host system type... x86_64-unknown-linux-gnu
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
/bin/bash: /media/disk1part12/Software: No such file or directory
configure: WARNING: `missing' script is too old or missing
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking whether to enable maintainer-specific portions of Makefiles... no
checking whether $C_INCLUDE_PATH contains the "." path... no
checking whether $CPLUS_INCLUDE_PATH contains the "." path... no
Programs
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking for style of include used by make... GNU
checking dependency style of gcc... gcc3
checking how to run the C preprocessor... gcc -E
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for stdlib.h... (cached) yes
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking dependency style of g++... gcc3
checking whether the g++ compiler works... yes
checking how to run the C++ preprocessor... g++ -E
checking for C++ compiler vendor... gnu
checking for g++ version... 4.6
checking for ranlib... ranlib
Libraries
checking whether to link with cygwin DLL... no
checking whether to enable static linking... no
checking for the pthreads library -lpthreads... no
checking whether pthreads work without any flags... no
checking whether pthreads work with -Kthread... no
checking whether pthreads work with -kthread... no
checking for the pthreads library -llthread... no
checking whether pthreads work with -pthread... yes
checking for joinable pthread attribute... PTHREAD_CREATE_JOINABLE
checking if more special flags are required for pthreads... no
checking for boostlib >= 1.37... configure: error: We could not detect
the boost libraries (version 1.37 or higher). If you have a staged boost
library (still not installed) please specify $BOOST_ROOT in your
environment and do not give a PATH to --with-boost option.  If you are
sure you have boost installed, then check your version number looking in
<boost/version.hpp>. See http://randspringer.de/boost for more
documentation.
All Greek to me! Really, it is the very first time in my life that I try
to compile larger things than just a single-script C++ program...
Are there packages missing? Should I install the boost libraries? What
are boost libraries?
Yadgar
Date: 26 Oct 2011 09:47:41
Message: <4ea80f7d$1@news.povray.org>
> Hi(gh)!
> I got this:
> Environment
> Programs
> Libraries
> documentation.
> Yadgar
have a look at the files INSTALL and README in the root of your build
directory ... tis all spelled out for ya!
Date: 26 Oct 2011 16:04:18
Message: <4ea867c2@news.povray.org>
High!
In fact I did nothing else but reading through INSTALL.txt -
http://www.povray.org/beta/source/unix-src-INSTALL.txt !
Yadgar
Date: 26 Oct 2011 16:55:26
Message: <4ea873be$1@news.povray.org>
> documentation.
Boost libraries := something you should install; check out your Linux
distribution's package manager, it'll most likely have them. Make sure
to also install the "developer" package for the boost libraries
(probably named something like "boost-dev" or "boost-devel").
If you still experience problems even after installing the boost
libraries, try adding the command-line option
"--with-boost-thread=boost_thread-mt" to ./configure.
Date: 1 Nov 2011 16:59:32
Message: <4eb05db4@news.povray.org>
High!
But I did not know which boost packages exactly are necessary, I
foolishly tried apt-get install boost* - which totally blew my system,
the system partition ran full, and nothing worked anymore...
Meanwhile, I have mostly recovered from the crash - but I still do not
now which boost packages to install...
Yadgar
Now playing: Rio (Duran Duran)
Date: 1 Nov 2011 21:33:24
Message: <4eb09de4@news.povray.org>
Hi(gh)!
On 25.10.2011 22:07, clipka wrote:
> What you really should try is POV-Ray 3.7 - radiosity has changed a lot
> since 3.6.
During the prolonged weekend, I stayed with a friend who in fact runs
3.7 on his multi-processor systems - and even though I decreased count
to 100 and upped error_bound to 0.15, the result (attached here) was
much more satisfying than everything I achieved under 3.6!
Yadgar
Now playing: September Gurls (Bangles)
Download '2011-10-30 port whatmough residential building #1, take 195 - view from kitchen into atelier, modified andresdottir radi' (19 KB)
Preview of image '2011-10-30 port whatmough residential building #1, take 195 - view from kitchen into atelier, modified andresdottir radi'
Date: 3 Nov 2011 04:59:52
Message: <4eb25808@news.povray.org>
> Hi(gh)!
>> since 3.6.
Now what did I tell you? :-)
