POV-Ray : Newsgroups : povray.binaries.images : Strange Artifacts Server Time
28 May 2026 08:32:20 EDT (-0400)
  Strange Artifacts (Message 6 to 15 of 25)
<<< Previous 5 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Strange Artifacts
Date: 30 Sep 2011 15:53:52
Message: <4e861e50$1@news.povray.org>
Le 30/09/2011 20:21, clipka nous fit lire :
> Am 30.09.2011 11:47, schrieb Jörg 'Yadgar' Bleimann:
>> Hi(gh)!
>> With my current house project ("Port Whatmough Residential Area") I
>> encountered some strange artifacts when I tried to join two segments of
>> a roof railing (a straight and a curved one) with a sphere.
>> The curved segment follows a rounded 90° cutout of the ground floor
>> having a radius of 3.5 units; as the railing generally is spaced 0.1
>> units inwards from the roof's eged, the curved segment's (technically a
>> section of a torus) radius is 3.6 units, therefore it's angular size is
>> slightly less than 90° (see second attached image).
>> Although I've taken the resulting difference in the x direction (which
>> calculates as cos(atan(0.1/3.6))*3.6) relative to the eastern end of the
>> straight section into account, the spherical cornerpiece still does not
>> fit seamlessly.
> I think that should be:
>     cos(asin(0.1/3.6))*3.6
>   = sqrt(sqr(3.6)-sqr(0.1))
> In addition, are you sure you cut the cylinder and torus properly?
If, as I now think, he used a translation of the clipping plane, the
answer is no. (a rotation should have been used)
Date: 30 Sep 2011 17:05:51
Message: <4e862f2f$1@news.povray.org>
Hi(gh)!
Am 30.09.2011 21:53, schrieb Le_Forgeron:
The cylinder is not cut at all, but defined according to the length of
the straight rail piece, with equal y and z coordinates respectively at
beginning and end, so there is no distortion. The torus is defined in
default position, i. e. parallel to the x-z plane and cut by two boxes
rotated only around the y axis, so the cut planes are always circles,
not ellipses!
See you in Khyberspace!
Yadgar
Date: 30 Sep 2011 17:38:36
Message: <4e8636dc@news.povray.org>
Hi(gh)!
With
<4.9+(3.6-sqrt(sqrt(3.6)-sqrt(0.1))), sh+rfh/(mr+1), 4.1>
as the sphere's coordinates rather than
<4.9+(3.6-cos(atan(0.1/3.6))*3.6), sh+rfh/(mr+1), 4.1>
the result is even worse - see attached image!
Yadgar
Download 'railing_corner.png' (19 KB)
Preview of image 'railing_corner.png'
Date: 30 Sep 2011 21:20:03
Message: <4e866ac3$1@news.povray.org>
> Hi(gh)!
> With
Of course: You mixed up sqrt and sqr :-P
My bad though, because sqr doesn't exist as a predefined formula in
POV-Ray; so it should be:
   sqrt(3.6*3.6 - 0.1*0.1)
Date: 1 Oct 2011 13:26:28
Message: <4e874d44@news.povray.org>
Hi(gh)!
Am 01.10.2011 03:19, schrieb clipka:
Now the result is the same like with my original version (see attachment)...
Yadgar
Download 'whatmough_residential.png' (29 KB)
Preview of image 'whatmough_residential.png'
Date: 1 Oct 2011 18:45:01
Message: <4e8797ed$1@news.povray.org>
> attachment)...
I can't help but think that the torus and cylinder ends might be bogus.
Do you have some code for me to toy around with?
Date: 1 Oct 2011 20:45:01
Message: <web.4e87b3292d6bb20470368d3d0@news.povray.org>
> > attachment)...
Also, an orthographic view from above could be illuminating.  Even if your
angles are correct it looks like the issue could be due to a miss calculation of
the torus center or radius.
Cheers,
Mike
Date: 2 Oct 2011 06:45:17
Message: <4e8840bd$1@news.povray.org>
Am 02.10.2011 00:44, schrieb clipka:
>> attachment)...
O.k., here it is:
#declare rfh = 1; // Roof railing total height
#declare ur = 0.025; // Upper rail radius
#declare or = 0.018; // Other rails' radius
#declare pr = 0.018; // Railing post radius
#declare cp = 0.08;  // Rail cornerpieces' radius
#declare fh = 0.02;  // Railing post foot height
#declare fpr = 0.005; // Railing post foot outer rounding radius
#declare jlt = 0.012; // Railing middle join loop thickness
#declare jlr = 0.005; // Railing middle join loop outer rounding radius
#declare jlw = 2*(jlr+pr); // Railing middle join loop width
#declare mr = 2;      // Number of middle rails
#declare rvsp = rfh/(mr+1); // Vertical spacing of rails
#declare F_Shiny =
finish
   diffuse 1
   brilliance 0.6
   specular 0.8
   roughness 0.05
#declare T_Red_Metal =
texture
   pigment { color rgb <0.8, 0, 0> }
   finish { F_Shiny }
   cylinder
     <2.1+cp, sh+2*rfh/(mr+1), 4.1>, <4.9, sh+2*rfh/(mr+1), 4.1>, or
     texture { T_Red_Metal }
   sphere
   // sqrt(sqr(3.6)-sqr(0.1))
   // <4.9+(3.6-cos(atan(0.1/3.6))*3.6), sh+rfh/(mr+1), 4.1>, or
     <4.9+(3.6-sqrt(pow(3.6, 2)-pow(0.1, 2))), sh+rfh/(mr+1), 4.1>, or
   difference // ground floor round cutout railing, lower rail
     torus
       3.6, or
     box
       <0, -(or+df), -(3.6+or+df)>, <3.6+or+df, or+df, 3.6+or+df>
     box
       <-(3.6+or+df), -(or+2*df), -(3.6+or+2*df)>, <3.6+or+2*df, or+2*df, 0>
       rotate <0, degrees(atan(0.1/3.5)), 0>
     translate <8.5, sh+rfh/3, 4>
Yadgar
Date: 2 Oct 2011 07:00:46
Message: <4e88445e@news.povray.org>
Hi(gh)!
Am 02.10.2011 02:41, schrieb Solar Mike:
O.k.... with and without the spherical cornerpiece!
Yadgar
Download 'orthoview1.png' (66 KB) Download 'orthoview2.png' (65 KB)
Preview of image 'orthoview1.png'
Preview of image 'orthoview2.png'
Date: 2 Oct 2011 07:14:15
Message: <4e884787$1@news.povray.org>
> cylinder
Note that this does /not/ coincide with the sphere's center. You need to
apply the small correction here as well to fix this...
> sphere
> torus
> 3.6, or
> box
> box
... and here you're miscalculating the angle, using both the wrong
values (should be 0.1/3.6 rather than 0.1/3.5) and the wrong formula
(should be asin rather than atan).
