POV-Ray : Newsgroups : povray.binaries.images : Strange Artifacts Server Time
23 Nov 2026 14:10:22 EST (-0500)
  Strange Artifacts (Message 21 to 25 of 25)
<<< Previous 20 Messages Goto Initial 25 Messages
Subject: Re: Strange Artifacts
Date: 3 Oct 2011 21:55:54
Message: <4e8a67aa$1@news.povray.org>
Am 02.10.2011 22:43, schrieb Jörg 'Yadgar' Bleimann:
> After your suggested corrections, it looks almost perfect... but there
> are still those parallel rows of dots, just like there were
> coincindental surfaces!
For those I have no explanation so far. I'll probably need more code to
find out anything (camera, lights, global settings... the whole smash).
Date: 4 Oct 2011 04:14:29
Message: <4e8ac065@news.povray.org>
High!
Should I really post the 500+ lines of code here?
See you in Khyberspace!
Yadgar
Date: 4 Oct 2011 06:53:58
Message: <4e8ae5c6@news.povray.org>
Here it is, the whole smash:
// Residential area architectural study for Port Whatmough
// (C) 2011 Jörg "Yadgar" Bleimann
// SWITCHES
#declare r=1; // toggles basic radiosity: 0 = off, 1 = on
#declare av=0; // toggles assembly view: 0 = off, 1 = on
global_settings
   #if (r=1)
     radiosity { }
     ambient_light 0
   #else
     ambient_light 0.25
// PIGMENTS
#declare P_Sky =
pigment
   gradient y
   color_map
     [0 rgb <0.7, 1, 1>]
     [0.2 rgb <0, 0.25, 1>]
     [1   rgb <0, 0.25, 1>]
// FINISHES
#declare F_Standard =
finish
   diffuse 1
   brilliance 0.15
#declare F_Shiny =
finish
   diffuse 1
   brilliance 0.6
   specular 0.8
   roughness 0.05
// TEXTURES
#declare T_Simple_White =
texture
   pigment { color rgb 1 }
   finish { F_Standard }
#declare T_Red_Metal =
texture
   pigment { color rgb <0.8, 0, 0> }
   finish { F_Shiny }
#declare T_Soil =
texture
   pigment { color rgb <0.8, 0.65, 0.4> }
// STANDARDIZED OBJECTS
#declare sh = 2.6; // storey overall height
#declare cl = 0.15; // ceiling thickness
#declare ow = 0.18; // outer walls thickness
#declare iw = 0.1;  // inner walls thickness
#declare wr = 0.1;  // window rounding radius
#declare df=0.0001; // difference value to add or subtract to avoid
coincidental surfaces
#declare Column =
cylinder
   0, <0, sh, 0>, 0.1
#declare Suspension =
prism
   linear_sweep
   linear_spline
   0, 0.1, 5
   <0, 0>, <2, 0>, <4, sh>, <0, sh>, <0, 0>
#declare OuterStair=
box
   0, <0.3, 0.2, 0.6>
#declare OuterStairs=
union
   #declare st=sh;
   #declare i=1;
   #while (i<(sh/0.2)+1)
     object
       OuterStair
       scale <i, 1, 1>
       translate <0, st-i*0.2, 0>
     #declare i=i+1;
#declare OuterStairs_Balustrade=
prism
   linear_sweep
   linear_spline
   0, 0.1, 5
   <0, 0>, <3.9, 0>, <3.9, 0.9>, <0, sh+0.9>, <0, 0>
#declare rfh = 1; // Roof railing total height
#declare ur = 0.025; // Upper rail radius
#declare or = 0.018; // Other rails' radius
#declare pr = 0.018; // Railing post radius
#declare cp = 0.08;  // Rail cornerpieces' radius
#declare fh = 0.02;  // Railing post foot height
#declare fpr = 0.005; // Railing post foot outer rounding radius
#declare jlt = 0.012; // Railing middle join loop thickness
#declare jlr = 0.005; // Railing middle join loop outer rounding radius
#declare jlw = 2*(jlr+pr); // Railing middle join loop width
#declare mr = 2;      // Number of middle rails
#declare rvsp = rfh/(mr+1); // Vertical spacing of rails
#declare Railing_Post_Foot =
union
	difference
		cylinder
		  0, <0, 0.02, 0>, pr+0.024
		cylinder
		  <0, -df, 0>, <0, 0.02+df, 0>, pr
		difference
	    cylinder
		    <0, 0.02-fpr, 0>, <0, 0.02+df, 0>, pr+0.024+df
		  cylinder
		    <0, 0.02-fpr-df, 0>, <0, 0.02+2*df, 0>, pr+0.024-fpr
   torus
     pr+0.024-fpr, fpr
     translate <0, 0.02-fpr, 0>
#declare Railing_Join_Loop_Rounding_Cutout =
difference
   cylinder
     <-jlr-df, 0, 0>, 0, pr+jlt+df
   cylinder
     <-jlr-2*df, 0, 0>, <df, 0, 0>, pr+jlt-jlr
#declare Railing_Join_Loop_Rounding =
torus
   pr+jlt-jlr, jlr
   rotate <0, 0, 90>
#declare Railing_Join_Loop=
union
	difference
		cylinder
		  0, <jlw, 0, 0>, pr+jlt
	  cylinder
	    <-df, 0, 0>, <jlw+df, 0, 0>, pr
	  object
	    translate <jlr, 0, 0>
	  object
	    rotate <0, 180, 0>
	    translate <jlr+2*pr, 0, 0>
   object
   object
#declare Upper_Railing_Join_Loop =
object
   Railing_Join_Loop
   scale ur/or
#declare Railing_Post_Lower_Segment =
cylinder
   0, <0, rvsp-or-(jlt/2), 0>, pr
#declare Railing_Post_Middle_Segment =
cylinder
   <0, or+(jlt/2), 0>, <0, rvsp-(or+jlt/2), 0>, pr
#declare Railing_Post_Upper_Segment =
cylinder
   <0, or+(jlt/2), 0>, <0, rvsp-(ur+jlt*(ur/or)/2), 0>, pr
#declare Railing_Post =
union
   object { Railing_Post_Foot }
   object { Railing_Post_Lower_Segment }
   #declare s=1;
   #while (s<mr)
     object { Railing_Join_Loop translate <-jlw/2, s*rvsp, 0> }
     object { Railing_Post_Middle_Segment translate <0, s*rvsp, 0> }
     #declare s=s+1;
   object { Railing_Post_Upper_Segment translate <0, s*rvsp, 0> }
   object { Upper_Railing_Join_Loop translate <-jlw*(ur/or)/2, rfh, 0> }
#declare Railing_Rail_Cornerpiece =
difference
   torus
     cp, or
   box
     -(cp+or+df), <cp+or+df, cp+or+df, 0>
   box
     <0, -(cp+or+2*df), cp+or+df>, <cp+or+2*df, cp+or+2*df, -(cp+or+2*df)>
#declare Upper_Railing_Rail_Cornerpiece =
difference
   torus
     cp, ur
   box
     -(cp+ur+df), <cp+ur+df, cp+ur+df, 0>
   box
     <0, -(cp+ur+2*df), cp+ur+df>, <cp+ur+2*df, cp+ur+2*df, -(cp+ur+2*df)>
// ACTUAL SCENE
#if (av=0)
	sky_sphere
	  pigment { P_Sky }
	plane
	  y, 0
	  texture { T_Soil }
	union
		difference
			box // main block
			  <2, 0, 4>, <14, sh, 12>
		  cylinder // verandah cutout, western part
		    <8.5, -df, 4>, <8.5, sh+df, 4>, 3.5
		  box // verandah cutout, eastern part
		    <8.5, -df, 4-df>, <14+df, sh+df, 7.5>
	  box
	    <11, sh-cl, 2>, <14, sh, 7.5>
	  object
	    Column
	    translate <11.1, 0, 2.1>
	  object
	    Column
	    translate <13.9, 0, 2.1>
	  box // 1st floor
	    <9, sh, 9.5>, <14, sh*2, 16>
	  difference
	    object { Suspension }
	    cylinder { <1.5, -df, 1.1>, <1.5, 0.1+df, 1.1>, 0.45 }
	    cylinder { <0.4, -df, 2>, <0.4, 0.1+df, 2>, 0.2 }
	    cylinder { <0.65, -df, 1.5>, <0.65, 0.1+df, 1.5>, 0.1 }
	    cylinder { <0.35, -df, 0.4>, <0.35, 0.1+df, 0.4>, 0.15 }
	    cylinder { <2.7, -df, 2.05>, <2.7, 0.1+df, 2.05>, 0.3 }
	    rotate <-90, -90, 0>
	    translate <13.9, 0, 12>
	  difference
	    cylinder { <0.7, -df, 1.9>, <0.7, 0.1+df, 1.9>, 0.45 }
	    cylinder { <1.6, -df, 0.4>, <1.6, 0.1+df, 0.4>, 0.2 }
	    cylinder { <0.6, -df, 0.8>, <0.6, 0.1+df, 0.8>, 0.1 }
	    cylinder { <3, -df, 2.3>, <3, 0.1+df, 2.3>, 0.15 }
	    cylinder { <1.9, -df, 1.2>, <1.9, 0.1+df, 1.2>, 0.3 }
	    translate <9, 0, 12>
	  object
	    OuterStairs
	    rotate <0, 180, 0>
	    translate <9, sh, 10.2>
	  object
	    rotate <-90, 180, 0>
	    translate <9, sh, 9.5>
	  object
		texture { T_Simple_White }
	#declare p=0;
	#while (p<7)
	  object
	    Railing_Post
	    translate <2.5+p, sh, 11.9>
	    texture { T_Red_Metal }
	  #declare p=p+1;
   cylinder
     <9+df, sh+rfh/(mr+1), 11.9>, <2.1+cp, sh+rfh/(mr+1), 11.9>, or
   cylinder
     <9+df, sh+2*rfh/(mr+1), 11.9>, <2.1+cp, sh+2*rfh/(mr+1), 11.9>, or
   cylinder
     <9+df, sh+rfh, 11.9>, <2.1+cp, sh+rfh, 11.9>, ur
   #declare p=0;
	#while (p<mr)
	  object
	    translate <2.1+cp, sh+(p+1)*(rfh/(mr+1)), 11.9-cp>
	  #declare p=p+1;
	object
	  translate <2.1+cp, sh+rfh, 11.9-cp>
	#declare p=0;
	#while (p<8)
	  object
	    Railing_Post
       rotate <0, 90, 0>
	    translate <2.1, sh, 11.5-p>
	  #declare p=p+1;
   cylinder
     <2.1, sh+rfh/(mr+1), 11.9-cp>, <2.1, sh+rfh/(mr+1), 4.1+cp>, or
   cylinder
     <2.1, sh+2*rfh/(mr+1), 11.9-cp>, <2.1, sh+2*rfh/(mr+1), 4.1+cp>, or
   cylinder
     <2.1, sh+rfh, 11.9-cp>, <2.1, sh+rfh, 4.1+cp>, ur
   #declare p=0;
	#while (p<mr)
	  object
	    rotate <0, -90, 0>
	    translate <2.1+cp, sh+(p+1)*(rfh/(mr+1)), 4.1+cp>
	  #declare p=p+1;
	object
     rotate <0, -90, 0>
	  translate <2.1+cp, sh+rfh, 4.1+cp>
   cylinder
     <2.1+cp, sh+rfh/(mr+1), 4.1>, <4.9+(3.6-sqrt(pow(3.6, 2)-pow(0.1,
2))), sh+rfh/(mr+1), 4.1>, or
   cylinder
     <2.1+cp, sh+2*rfh/(mr+1), 4.1>, <4.9+(3.6-sqrt(pow(3.6, 2)-pow(0.1,
2))), sh+2*rfh/(mr+1), 4.1>, or
   cylinder
     <2.1+cp, sh+rfh, 4.1>, <4.9+(3.6-sqrt(pow(3.6, 2)-pow(0.1, 2))),
sh+rfh, 4.1>, ur
	#declare p=0;
	#while (p<3)
	  object
	    Railing_Post
	    translate <2.5+p, sh, 4.1>
	  #declare p=p+1;
	sphere
           // sqrt(sqr(3.6)-sqr(0.1))
	  // <4.9+(3.6-cos(atan(0.1/3.6))*3.6), sh+rfh/(mr+1), 4.1>, or
	  <4.9+(3.6-sqrt(pow(3.6, 2)-pow(0.1, 2))), sh+rfh/(mr+1), 4.1>, or
	sphere
	  <4.9, sh+2*rfh/(mr+1), 4.1>, or
	sphere
	  <4.9, sh+rfh, 4.1>, ur
   difference // ground floor round cutout railing, lower rail
		torus
		  3.6, or
	  box
	    <0, -(or+df), -(3.6+or+df)>, <3.6+or+df, or+df, 3.6+or+df>
	  box
	    <-(3.6+or+df), -(or+2*df), -(3.6+or+2*df)>, <3.6+or+2*df, or+2*df, 0>
       rotate <0, degrees(asin(0.1/3.6)), 0>
	  translate <8.5, sh+rfh/3, 4>
	#declare p=0;
	#while (p<5)
	  object
	    Railing_Post
       rotate <0, 279+p*18, 0>
	    translate <8.5, sh, 4>+3.6*<sin(radians(279+p*18)), 0,
cos(radians(279+p*18))>
	  #declare p=p+1;
	#declare p=0;
	#while (p<3)
	  object
	    Railing_Post
	    translate <8.5+p, sh, 7.6>
	  #declare p=p+1;
	#declare p=0;
	#while (p<5)
	  object
	    Railing_Post
       rotate <0, 90, 0>
	    translate <11.1, sh, 7-p>
	  #declare p=p+1;
	#declare p=0;
	#while (p<3)
	  object
	    Railing_Post
	    translate <11.5+p, sh, 2.1>
	  #declare p=p+1;
	#declare p=0;
	#while (p<7)
	  object
	    Railing_Post
       rotate <0, 90, 0>
	    translate <13.9, sh, 2.5+p>
	  #declare p=p+1;
	// LIGHTING
	light_source
	  <500000, 3000000, 700000>
	  color rgb 1
	// CAMERAS
	#declare vp = 15; // selects viewpoint
	#switch (vp)
	  #case (0) // view from south
	    #declare CamPos = <8, 1.7, -10>;
	    #declare dir = 0;
	    #declare azi = 0;
	    #declare ang = 55;
	  #break
	  #case (1) // top view
	    #declare CamPos = <6, 30, 7>;
	    #declare dir = 0;
	    #declare azi = -89.9999;
	    #declare ang = 65;
	  #break
	  #case (2) // view from north
	    #declare CamPos = <9.5, 1.7, 25>;
	    #declare dir = 180;
	    #declare azi = 0;
	    #declare ang = 55;
	  #break
	  #case (3) // view from east
	    #declare CamPos = <30, 1.7, 9>;
	    #declare dir = 270;
	    #declare azi = 0;
	    #declare ang = 55;
	  #break
	  #case (4) // Outer stairs, view upstairs
	    #declare CamPos = <2.5, sh+1.7, 9.9>;
	    #declare dir = 90;
	    #declare azi = 0;
	    #declare ang = 55;
	  #break
	  #case (5) // Outer stairs, view downstairs
	    #declare CamPos = <9.5, 2*sh+1.7, 9.9>;
	    #declare dir = 270;
	    #declare azi = -40;
	    #declare ang = 55;
	  #break
	  #case (6) // oblique view from south
	    #declare CamPos = <8, 20, -10>;
	    #declare dir = 0;
	    #declare azi = -45;
	    #declare ang = 55;
	  #break
	  #case (7) // view to northwest from base of outer stairs
	    #declare CamPos = <3.5, sh+1.7, 9.9>;
	    #declare dir = 315;
	    #declare azi = -25;
	    #declare ang = 55;
	  #break
	  #case (8) // view to southeast from base of outer stairs
	    #declare dir = 135;
	    #declare azi = -20;
	    #declare ang = 55;
	  #break
	  #case (9) // top view of northwestern corner of ground floor
	    #declare CamPos = <2.1+cp, sh+5, 11.9-cp>;
	    #declare dir = 0;
	    #declare ang = 55;
	  #break
	  #case (10) // view to south-southwest from base of outer stairs
	    #declare dir = 202.5;
	    #declare azi = -25;
	    #declare ang = 55;
	  #break
	  #case (11) // top view of southwestern corner of ground floor
	    #declare CamPos = <2.1+cp, sh+5, 4.1-cp>;
	    #declare dir = 0;
	    #declare ang = 55;
	  #break
	  #case (12) // top view of round cutout of ground floor
	    #declare CamPos = <6.75, 1500, 4>;
	    #declare dir = 0;
	    #declare ang = 55;
	  #break
	  #case (13) // top view of southern end of round cutout of ground floor
	    #declare CamPos = <4.9, sh+0.7, 4.1>;
	    #declare dir = 0;
	    #declare ang = 55;
	  #break
	  #case (14) // close-up view of southern end of round cutout of ground
floor
	    #declare CamPos = <5.9, sh+0.5, 3.1>;
	    #declare dir = 315;
	    #declare azi = -10;
	    #declare ang = 55;
	  #break
	  #case (15) // extreme close-up view of southern end of round cutout
of ground floor
	    #declare CamPos = <5.9, sh+rfh/3, 3.1>;
	    #declare dir = 315;
	    #declare azi = -0;
	    #declare ang = 5;
	  #break
	#declare CamLook = <sin(radians(dir)) * cos(radians(azi)),
sin(radians(azi)), cos(radians(dir)) * cos(radians(azi))>;
	camera
	  location CamPos
	  look_at CamPos+CamLook
	  angle ang
#else // assembly view
   sky_sphere
     pigment { color rgb 0.7 }
   light_source
     <2000, 500, -2000>
     color rgb 1
   object
   camera
     location <0, 0.4, 0>
     look_at 0
     angle 40
// end of code
Yadgar
Date: 4 Oct 2011 07:50:46
Message: <4e8af316$1@news.povray.org>
Am 04.10.2011 12:53, schrieb Jörg 'Yadgar' Bleimann:
The bad news for us is that this is indeed a bug. Apparently the math
for the torus is very susceptible to rounding errors when the camera is
inside a very thin torus, on (or very close to) the torus' "center
plane". (The cylindrical part of the railing seems to be affected only
because the torus, despite being cut away, still "projects" artifacts.)
The bug might be pretty similar in nature to the artifacts seen in
sphere sweeps.
The good news for you is that for obvious reasons these artifacts are
highly unlikely to show up in your final render.
Date: 4 Oct 2011 08:03:23
Message: <4e8af60b$1@news.povray.org>
Hi(gh)!
No, this is not really bad news - at least it does not show that even
after 15 years of poving, I still get messed up with trivial beginners'
mistakes...
Yes, very probably not... and in animations, these dots would be almost
surely lost in compression!
Yadgar
