POV-Ray : Newsgroups : povray.binaries.images : Lego C-3PO Minifigure Server Time
27 Jul 2025 08:39:46 EDT (-0400)
  Lego C-3PO Minifigure (Message 1 to 7 of 7)
Subject: Lego C-3PO Minifigure
Date: 28 Sep 2011 03:42:27
Message: <4e82cfe3@news.povray.org>
Here's my latest render.
Not sure if I've got the gold colour quite right - I'm using "lg_tan"
I tried "lg_pearl_gold" but it looked to shiny.
Any ideas how I can get rid of the strange effect at the base of the legs?
I'm planning to make the POV source available on my own website shortly :-)
Bye for now
Download 3D Lego models and other resources from:
http://www.pearse.co.uk/lego
Download 'c-3po.png' (153 KB)
Preview of image 'c-3po.png'
Subject: Re: Lego C-3PO Minifigure
Date: 28 Sep 2011 04:17:05
Message: <4e82d801$1@news.povray.org>
   It's difficult to say withouth something to reflect...
   I would say these white artifacts are radiosity artifacts: try a
smaller pretrace_end, perhaps....
Jaime
Date: 28 Sep 2011 06:37:12
Message: <4e82f8d8$1@news.povray.org>
Am 28.09.2011 10:17, schrieb Jaime Vives Piqueres:
>> legs?
> I would say these white artifacts are radiosity artifacts: try a smaller
They /are/ radiosity artifacts. Here's the essentials of how they come
into existence:
When POV-Ray computes the radiosity brightness at a particular point
from previously taken samples, it interpolates between multiple samples,
weighing them according to how well it /expects/ them to be suitable for
that particular point. Two of the primary criteria playing a role here are:
- how close the sample is to any other objects, or protrusions on the
surface (such as the foot protrudes from the leg), and
- how close the sample is to the point in question.
As a matter of fact it is the ratio between these distances that is a
weighing factor.
Unfortunately there is no simple way for POV-Ray to tell the distance to
the next object, so what POV-Ray does is that it uses the
sample-ray-shooting process to also probe for nearby surfaces. As a
consequence, POV-Ray will fail to notice nearby objects or protrusions
if none of the sample rays happens to hit it.
Normally this is not a big deal: For points close to a protrusion, such
odd samples are usually far away, getting a much lower quality ranking
than numerous other samples that have been taken much closer, and are
therefore less prone to entirely missing the protrusion. So those odd
samples are "drowned" in good samples.
However, artifacts /do/ occur at places where POV-Ray did not take /any/
good samples at all. That is what has happened between the legs and the
feet. (Notice how the bright splotches only appear on the legs, while
the feet are free: This is because the feet are short, and there's no
room on them to take a sample that could miss the legs, while there's
enough room on the leg and breast from where the feet could be missed.)
As for ideas how to solve this, here are a few that /might/ help:
- Increase count; this will reduce the likelyhood of protrusions (such
as the feet) being missed. You can cause POV-Ray to just test for
distance in these added rays by making use of the radiosity importance
mechanism (needs POV-Ray 3.7). I doubt whether this will help much
though, unless you crank up count really high.
- Decrease pretrace_end; this will cause a more thorough pretrace,
reducing the likelihood of POV-Ray not taking any good samples at any
particular place.
- Increase error_bound; this will increase the effective radius of all
samples, causing samples taken /somewhat/ close to the feet to also be
good /extremely/ close to them. I /think/ a value of 1.0 or greater
should eliminate the problem (at the cost of potentially introducing
others :-P), but I might be wrong.
- Increase minimum_reuse; this will only increase the effective radius
of the "finest" samples, again causing samples taken /somewhat/ close to
the feet to also be used /very/ close to the feet.
- Reduce maximum_reuse; this will decrease the effective radius of the
"coarsest" samples, including the odd sample. (Very close to the feet,
POV-Ray will then not find /any/ samples at all during the main render,
and will take more to fill the gaps.)
- Set always_sample on; this will cause POV-Ray to take additional
samples during main render in spaces where it only finds the odd sample.
I wouldn't recommend it though, as it is prone to introducing other
artifacts.
Other radiosity parameters probably have no effect on this issue.
Date: 30 Sep 2011 22:30:00
Message: <web.4e8679ffa22921fa85de7b680@news.povray.org>
> [snip] and there's no
As many times as I read and re-read and re-read the documentation and your
explanations for how radiosity works, I still haven't the foggiest idea of what
the words in front of me actually mean...
Date: 30 Sep 2011 23:20:01
Message: <web.4e86869ca22921fa85de7b680@news.povray.org>
I find that error_bound values much above 0.5 defeat much of the purpose of
radiosity. :-P
Date: 3 Oct 2011 16:21:47
Message: <4e8a195b@news.povray.org>
Thanks for your comments clipka and Jaime.
I'm using POV-Ray 3.7.0 RC3
I've reduced the pretrace_end from 0.004 to 0.001
This seems to have solved the problem as shown on the updated image.
Thanks!
Here are my amended settings - based on the "Radiosity_Final" settings
in rad_def.inc
       pretrace_start 0.08
       //pretrace_end   0.004
       pretrace_end   0.001
       count 800
       nearest_count 9
       error_bound 0.2
       recursion_limit 1
       low_error_factor 0.7
       gray_threshold 0
       minimum_reuse 0.01
       brightness 1.0
       adc_bailout 0.01/2
Keep well
Reuben
Download 'c-3po_v2.png' (147 KB)
Preview of image 'c-3po_v2.png'
Date: 23 Nov 2011 16:06:49
Message: <4ecd6069$1@news.povray.org>
You can download the C-3PO model from my website. Available formats are
DXF, OBJ, POV-Ray and LDRaw. See the following link for more details:
http://www.pearse.co.uk/lego/models/c-3po/
Bye for now
