POV-Ray : Newsgroups : povray.binaries.images : Life in Gancaloon (wip) Server Time
22 Apr 2026 03:27:10 EDT (-0400)
  Life in Gancaloon (wip) (Message 36 to 45 of 45)
Subject: Re: Life in Gancaloon (wip 2)
Date: 1 Oct 2011 04:39:31
Message: <4e86d1c3$1@news.povray.org>
On 1-10-2011 10:25, Stephen wrote:
> Thanks, I never set Show Population so that might be one of the problems.
> I will waste some more time. :-D
As far as I understand the whole procedure so far, Show Population
effectively shows and generates the end result. It is this also which is
exported, along with the basic lines used for the hair construction.
Date: 1 Oct 2011 06:04:38
Message: <4e86e5b6@news.povray.org>
exported. So I tried a few times just using them. A quick test shows
that 6000 hairs are too much. ;-)
Thanks again.
Regards
Date: 1 Oct 2011 10:31:59
Message: <4e87245f$1@news.povray.org>
Maybe I am seeing something else, but without Show Population you only
get the guide hairs I believe, while with Show Population checked, you
get guide hairs *and* the rest of the Hair Dresser's creation.
Date: 1 Oct 2011 10:53:09
Message: <4e872955@news.povray.org>
That's why I wrote somewhen. This was back when the hair room was
introduced.
I was also wrong about 6000 hairs being too much. My problem was the
PoseRay settings. I needed to set Root diameter to 0.0002.
Just playing about, I've exported a mesh with 16000 hairs and get not
bad results. Although I managed to crash RC3 when I tried to load the
mesh file into the editor.
Regards
Date: 2 Oct 2011 03:09:17
Message: <4e880e1d@news.povray.org>
> introduced.
I think we need to make a compromise between a very large number of fine
hairs (= very heavy data file) and fewer, somewhat thicker hairs (=
smaller data file). I have been mainly exploring the latter option,
which implies the search for a convincing hair texture.
Here is an example, with a 300+Mb data file and a simple grey pigment.
Download 'poserfiguretest.png' (565 KB)
Preview of image 'poserfiguretest.png'
Date: 2 Oct 2011 03:34:47
Message: <4e881417@news.povray.org>
shortly. ;-)
his company any time soon.
Here is one I did yesterday with a hair density of 30000 (24500 hairs)
715 MB.
All textures are defaults.
Now for curly and longer hair.
Thanks for letting me know about this.
Regards
Download 'grownhair01e1_.jpg' (181 KB)
Preview of image 'grownhair01e1_.jpg'
Date: 2 Oct 2011 04:00:08
Message: <4e881a08$1@news.povray.org>
> 715 MB.
This is looking very good Stephen! Finer and more hairs is of course
better in close up. At a distance, one should be able to get away with
lower density... That might be the choice to make when building a scene.
In any case, Poseray is handling the hairs quite nicely now, though I
would like to see some improvement on the handling of the different hair
files generated. There appears to be some confusion with the name-giving
which should be more straightforward and directly related to the
original names. I shall see if I can make a proposal to FlyerX about this.
Date: 2 Oct 2011 04:52:40
Message: <4e882658$1@news.povray.org>
Thanks
As you say. :-)
For scenes the least that you can get away with the better. There is
enough demand on system resources without adding large meshes.
> original names.
I noticed that.
Not a bad idea.
BTW I'm still using PoseRay v3.12.2 as the current Beta forces the use
of sRGB Colours. Unfortunately this is not compatible with Bishop3D and
I don't want to take the time out to explore the colour spaces ATM
Regards
Date: 2 Oct 2011 07:18:21
Message: <4e88487d$1@news.povray.org>
> Not a bad idea.
FlyerX told me that rgb/srgb will be optional in the next beta release.
Date: 2 Oct 2011 07:51:33
Message: <4e885045$1@news.povray.org>
>> Not a bad idea.
Good, that suits me. :-D
Regards
