POV-Ray : Newsgroups : povray.binaries.images : Life in Gancaloon (wip) Server Time
22 Apr 2026 06:51:41 EDT (-0400)
  Life in Gancaloon (wip) (Message 31 to 40 of 45)
<<< Previous 10 Messages Goto Latest 10 Messages Next 5 Messages >>>
Subject: Re: Life in Gancaloon (wip 3)
Date: 1 Oct 2011 02:51:04
Message: <4e86b858$1@news.povray.org>
On 1-10-2011 4:08, Alain wrote:
> As for the area light, adaptive is a must. Start with adaptive 0, and
> increase to adaptive 1 or 2 only if you have disturbing artefacts.
> Looking at the actual scene, it's probable that adaptive 0 will be
> correct, with, maybe, some pixel sized glitches near the torch holder on
> the wall.
> Most of the time, with adaptive 0, the time hit is barely larger than 4,
> even with high density arays like 17 * 17, 33 * 33 or 65 * 65.
Excellent suggestion. I was using adaptive 1, but I might indeed get
away with adaptive 0.
Date: 1 Oct 2011 02:54:14
Message: <4e86b916$1@news.povray.org>
On 30-9-2011 18:25, Darren New wrote:
> On 9/30/2011 4:48, Thomas de Groot wrote:
>> This is how I want it.
> Sweet. I do like how you've managed to capture the balance of the
> characters. Most such scenes come out looking very stilted.
Thank you indeed. I always painstakingly try to get the most natural
looking characters, which means very subtle changes in body pose and -
most of all - in facial expression. It takes a fair amount of time in
Poser but it is worth it. And it pushes one to study human nature ;-)
Date: 1 Oct 2011 03:03:59
Message: <4e86bb5f$1@news.povray.org>
On 30-9-2011 20:32, clipka wrote:
> Am 30.09.2011 13:48, schrieb Thomas de Groot:
> Looking better and better.
Thank you indeed. I shall let it rest now for a while. I might come back
with some improvements in the near future.
> BTW, are you using Poser or Daz 3D models? And what shoes are the ladies
> wearing? I've been searching for such shoes for quite a while without
> success - virtually all 3D models out there are either high heels or
> sneakers.
  I am using Poser 7 and 8; mostly 8 now but for some characters like
KelvinG2 and KojiG2 - which are later additions to Poser 7 - I use that
version.
These conforming slippers come with Poser 8's Alyson character (which
Izumi variant is the basis for the two female characters here).
I agree about the available shoes in Poser. I have not yet tried to make
my own conforming shoes (or clothes for that matter). That is something
on my todo list for quite a while already.
Subject: Re: Life in Gancaloon (wip 2)
Date: 1 Oct 2011 03:33:15
Message: <4e86c23b$1@news.povray.org>
On 30-9-2011 14:29, Stephen wrote:
> On 27/09/2011 7:53 AM, Thomas de Groot wrote:
>> By the way, the latest Poseray solution for dynamic hair is quite
>> satisfying (cylinders instead of sheets). I am working on a beard and
>> hair for my Beggar and the main concern now is to get a satisfying
>> texture. I shall show some results soon.
> Please do. I can't seem to find any reasonable settings in either Poser
> or PoseRay except for cornrows.
A couple of things you should do after reaping the corn ;-)
1) In Poser: Before exporting, adjust the Hair Density to your needs,
and check Show Population (very important!).
2) In Poseray: Convert Lines to Tubes: set Minimum Line Length to 0; set
Root diameter to 0.01; set Tip Diameter to 0.001.
3) In Poseray: Only export the tube_groups to POV-Ray, not the Lines
(switch those off in the Group Menu).
With this you have a working basis from which to experiment on.
Date: 1 Oct 2011 04:26:00
Message: <4e86ce98@news.povray.org>
Thanks, I never set Show Population so that might be one of the problems.
I will waste some more time. :-D
Regards
Date: 1 Oct 2011 04:39:31
Message: <4e86d1c3$1@news.povray.org>
As far as I understand the whole procedure so far, Show Population
effectively shows and generates the end result. It is this also which is
exported, along with the basic lines used for the hair construction.
Date: 1 Oct 2011 06:04:38
Message: <4e86e5b6@news.povray.org>
exported. So I tried a few times just using them. A quick test shows
that 6000 hairs are too much. ;-)
Thanks again.
Regards
Date: 1 Oct 2011 10:31:59
Message: <4e87245f$1@news.povray.org>
Maybe I am seeing something else, but without Show Population you only
get the guide hairs I believe, while with Show Population checked, you
get guide hairs *and* the rest of the Hair Dresser's creation.
Date: 1 Oct 2011 10:53:09
Message: <4e872955@news.povray.org>
That's why I wrote somewhen. This was back when the hair room was
introduced.
I was also wrong about 6000 hairs being too much. My problem was the
PoseRay settings. I needed to set Root diameter to 0.0002.
Just playing about, I've exported a mesh with 16000 hairs and get not
bad results. Although I managed to crash RC3 when I tried to load the
mesh file into the editor.
Regards
Date: 2 Oct 2011 03:09:17
Message: <4e880e1d@news.povray.org>
> introduced.
I think we need to make a compromise between a very large number of fine
hairs (= very heavy data file) and fewer, somewhat thicker hairs (=
smaller data file). I have been mainly exploring the latter option,
which implies the search for a convincing hair texture.
Here is an example, with a 300+Mb data file and a simple grey pigment.
Download 'poserfiguretest.png' (565 KB)
Preview of image 'poserfiguretest.png'
