On 30/09/2011 3:13 PM, Thomas de Groot wrote:
> On 30-9-2011 16:11, Thomas de Groot wrote:
>> About gamma: I am not sure. If I reproduce your test, I see those parts
>> of the scene that are in direct sunlight (Linger's skin and the corner
>> stones wall mainly) that remain lighter longer.
> ....and yes, Lingyi's scabbard. Which is just a pigment with some higher
> specular values.
That's fine as that is what I see too.
Just thought I'd mention it.
Regards
On 9/30/2011 4:48, Thomas de Groot wrote:
> This is how I want it.
Sweet. I do like how you've managed to capture the balance of the
characters. Most such scenes come out looking very stilted.
How come I never get only one kudo?
Am 30.09.2011 16:11, schrieb Thomas de Groot:
... which, by the way, is perfectly normal.
Am 30.09.2011 13:48, schrieb Thomas de Groot:
Looking better and better.
BTW, are you using Poser or Daz 3D models? And what shoes are the ladies
wearing? I've been searching for such shoes for quite a while without
success - virtually all 3D models out there are either high heels or
sneakers.
> 2-pass render with a scattering media, but without area light in the
> second pass. Still +3hours render time with 6 threads. With an area
> light I judge from testing that render time would be multiplied by 10.
> Thomas
Coming along nicely.
As for the area light, adaptive is a must. Start with adaptive 0, and
increase to adaptive 1 or 2 only if you have disturbing artefacts.
Looking at the actual scene, it's probable that adaptive 0 will be
correct, with, maybe, some pixel sized glitches near the torch holder on
the wall.
Most of the time, with adaptive 0, the time hit is barely larger than 4,
even with high density arays like 17 * 17, 33 * 33 or 65 * 65.
> the wall.
Excellent suggestion. I was using adaptive 1, but I might indeed get
away with adaptive 0.
Thank you indeed. I always painstakingly try to get the most natural
looking characters, which means very subtle changes in body pose and -
most of all - in facial expression. It takes a fair amount of time in
Poser but it is worth it. And it pushes one to study human nature ;-)
Thank you indeed. I shall let it rest now for a while. I might come back
with some improvements in the near future.
> sneakers.
I am using Poser 7 and 8; mostly 8 now but for some characters like
KelvinG2 and KojiG2 - which are later additions to Poser 7 - I use that
version.
These conforming slippers come with Poser 8's Alyson character (which
Izumi variant is the basis for the two female characters here).
I agree about the available shoes in Poser. I have not yet tried to make
my own conforming shoes (or clothes for that matter). That is something
on my todo list for quite a while already.
On 30-9-2011 14:29, Stephen wrote:
> On 27/09/2011 7:53 AM, Thomas de Groot wrote:
>> By the way, the latest Poseray solution for dynamic hair is quite
>> satisfying (cylinders instead of sheets). I am working on a beard and
>> hair for my Beggar and the main concern now is to get a satisfying
>> texture. I shall show some results soon.
> Please do. I can't seem to find any reasonable settings in either Poser
> or PoseRay except for cornrows.
A couple of things you should do after reaping the corn ;-)
1) In Poser: Before exporting, adjust the Hair Density to your needs,
and check Show Population (very important!).
2) In Poseray: Convert Lines to Tubes: set Minimum Line Length to 0; set
Root diameter to 0.01; set Tip Diameter to 0.001.
3) In Poseray: Only export the tube_groups to POV-Ray, not the Lines
(switch those off in the Group Menu).
With this you have a working basis from which to experiment on.
Thanks, I never set Show Population so that might be one of the problems.
I will waste some more time. :-D
Regards
