On 23/09/2011 1:23 PM, Thomas de Groot wrote:
> Nobody asked, but I shall tell nonetheless: :-)
> The stonework has been obtained with the displacement feature that comes
> with (the latest) Poseray beta. I was experimenting and got these results.
I did notice. It is a nice effect.
Regards
The latest version.
Download 'beware iskander_07.png' (763 KB)
Preview of image 'beware iskander_07.png'
On 9/26/2011 5:31, Thomas de Groot wrote:
> The latest version.
"Keep away from the mistress, you camel-mannered tunic-wetting mollycoddle!"
Looking really good.
How come I never get only one kudo?
On 26/09/2011 1:31 PM, Thomas de Groot wrote:
> The latest version.
Looking better but something needs to be done with that green top. It
looks as if it has been through the wash too many times. ;-)
reinstall some libraries.
constrained group.
Regards
>> The latest version.
> constrained group.
I agree. Something that needs more work. Cloth parameters are tricky to
get right. Already here, stretch resistance is fairly high (the params
are mainly based on silk) and the hem is narrower than the top. Still,
the result is not totally satisfying. I continue working on it though.
By the way, the latest Poseray solution for dynamic hair is quite
satisfying (cylinders instead of sheets). I am working on a beard and
hair for my Beggar and the main concern now is to get a satisfying
texture. I shall show some results soon.
>> The latest version.
> mollycoddle!"
He he... Maybe...
Thanks!
I meant that you should try putting at least a few points of the front
of the hem in the constrained group. That should keep it close to the
models body.
Bishop3D will work with. I tried running PAE from Poser++ to animate
some hair today but found that PAE will only work with Poser 4 BVH
files. Drat!
I upgraded my Poser 7 to Poser Pro 2010 to take advantage of my 64 bit
system. It is much faster loading and saving scenes than Poser 7,
much since I upgraded it in March
Regards
> models body.
Yes. A more interesting solution is to apply a bit of wind force, here
coming from the staircase. That solves the issue, although I need to
look into a couple of other issues concerning the top itself.
> files. Drat!
I see. Well, you will need at least to wait for the beta to turn into
Poseray v.3.13 (or whatever) probably when POV-Ray exits the RC stage(?).
I use Poser 8 now mostly. It works far better under Windows 7 than under
WinXP where I still needed Poser 7 for several things. I do not intend
for the time being to upgrade to Poser 9 or the latest Poser Pro. The
program works fine for me at this moment and I did not see any real
major improvements which I might need.
>>> The latest version.
>> constrained group.
Given the build of the lady, she need a tie string around her stomach.
Given the environment, buttons where prety exclusively used as
decorations, and lacing was used everywhere we now use buttons and zippers.
> Thomas
<grin> To remain in style with a Lankhmarish perspective ;-)
Exactly so.
