POV-Ray : Newsgroups : povray.binaries.images : Gancaloon - urbanism wip Server Time
4 Jul 2026 09:15:19 EDT (-0400)
  Gancaloon - urbanism wip (Message 21 to 28 of 28)
Subject: Re: Gancaloon - urbanism wip3
Date: 19 Aug 2011 17:45:28
Message: <4e4ed978$1@news.povray.org>
Thomas de Groot wrote:
> My next problem now is this. I have an image_map for texturing the
> roads, mostly transparant and which layers nicely over another texture,
> except... if I use this patterned texture I cannot layer over it!
Worst case you can always create a copy of the landscape height_field
translates slightly up just for the roads, so the transparency will show
the lower height_field.
> I have tried patterning the image_map but to no useful result.
Assuming you can make a road image that is white where the roads
are, black where the roads are not, and somewhat smoothed to avoid
hard edges, you should be able to load it as an image_map, use that
as a pigment_pattern with texture_map, using landscape texture for
0 and road texture for 1.
Date: 20 Aug 2011 02:46:58
Message: <4e4f5862$1@news.povray.org>
Yes, that should be last resort indeed.
Yes, that is the way I was thinking too, and started experimenting. I
see that I am on the right track (no pun intended)... Thanks!
Date: 20 Aug 2011 04:56:53
Message: <4e4f76d5@news.povray.org>
Yes! Got it at last! :-)
Note that the road pattern has also been incorporated into the
height_field (done in Geocontrol)
Download 'gancaloon.png' (419 KB)
Preview of image 'gancaloon.png'
Date: 21 Aug 2011 04:37:10
Message: <4e50c3b6$1@news.povray.org>
On 13-8-2011 23:01, Joost wrote:
> Looks like a interesting project. Curious how it works out (I like cities views
> For an ancient city (don't know if it's meant to be), a few more alleys may be
> nice. Btw, they can use the axes as a sewer system, they exit nicely in the
> sea...
The way the urbanism is built presently is intended for overview at some
distance. Real close, a totally different concept should be used where
more detailed alleyways would be provided. The period of the city is
some equivalent of 1000 AD, in the southeastern Mediterranean, but it is
not intended to represent any existing historical setting. It is
strictly imaginary with only touches of more familiar things.
Good idea about the sewer system. I might create an aqueduct or two
perhaps ;-)
Date: 23 Aug 2011 07:51:02
Message: <4e539426@news.povray.org>
Another view of the city, as seen from a boat coming from upstreams.
This is how Lord Dunsany described this part of the river in Idle Days
on the Yann, from the book A Dreamer's Tales:
[quote]
And now as the sun's last rays were nearly level, we saw the sight that
I had come to see, for from two mountains that stood on either shore two
cliffs of pink marble came out into the river, all glowing in the light
of the low sun, and they were quite smooth and of mountainous altitude,
and they nearly met, and Yann went tumbling between them and found the sea.
And this was Bar-Wul-Yann, the Gate of Yann, and in the distance through
that barrier's gap I saw the azure indescribable sea, where little
fishing-boats went gleaming by.
[/quote]
Note that Lord Dunsany visited the region long before the foundation of
Gancaloon!
Download 'gancaloon_10.png' (584 KB)
Preview of image 'gancaloon_10.png'
Date: 23 Aug 2011 09:04:32
Message: <4e53a560$1@news.povray.org>
> [quote]
> [/quote]
> Gancaloon!
> Thomas
Hey nice work ... curious about the camera settings that you are using,
mind posting a few particulars? I /really/ like how this scene is posed
... top drawer!
Date: 24 Aug 2011 03:46:07
Message: <4e54ac3f$1@news.povray.org>
On 23-8-2011 15:04, Jim Holsenback wrote:
>> Thomas
> ... top drawer!
Gladly.
Knowing that the height_field with the city has a scale of <500, 30,
500> and is centered on the origin with basis at 0.0, and knowing that
water level is y=0.60; and with the other side of the river being a
height_field with the same scale and translated <-250, 0, 0>:
//Camera positions:
#declare SceneLook      = 6;  //0=overview; 1=overview River Harbour;
2=Ruins; 3=orthographic vertical; 4=orthographic vertical for roaming
                               //5=Sikhara; 6=overside Yann; 7=offshore
Sea Harbour; 8=birdseye Yann mouth; 9=from upriver;
   #switch(SceneLook)
   #case (0)
     location  <-100, 30, -240.0>
     look_at   <-100,  0,    0.0>
   #break
   #case (1)
     location  <-140, 30, -140.0>
     look_at   <-140,  0,    0.0>
   #break
   #case(2)
     location  <-59.6, 14.3, -234.0>
     look_at   <-80.0, 25.0,    0.0>
   #break
   #case(3)
     orthographic
     location  <0.0, 300.0, 0.0>
     look_at   <0.0,   0.0, 0.0>
   #break
   #case(4)
     orthographic
     location  <-150.0, 100.0, -50.0>
     look_at   <-150.0,   0.0, -50.0>
   #break
   #case(5)
     location  <-100.0, 25.0, -50.0>
     look_at   <-150.0, 10.0,  10.0>
   #break
   #case(6)
     location  <-325.0,  5.0, -150.0>
     look_at   <-100.0, 10.0,   20.0>
   #break
   #case(7)
     location  <-100.0, 100.0, 200.0>
     look_at   <-100.0,  10.0,   0.0>
   #break
   #case(8)
     location  <-200.0, 100.0, 200.0>
     look_at   <-200.0,  10.0,   0.0>
   #break
   #case(9)
     location  <-200.0,  2.0, -200.0>
   direction 1.5*z
   angle 80
The large angle generates some deformation which are acceptable is these
kind of panoramic views.
Just ask if you want any more info.
Date: 24 Aug 2011 07:09:59
Message: <4e54dc07$1@news.povray.org>
> Thomas
Nope ... I'm good to go. Was just looking for a reality check with a
somewhat similar setup. Thanks.
