POV-Ray : Newsgroups : povray.binaries.images : Gancaloon - urbanism wip Server Time
12 Nov 2026 19:34:49 EST (-0500)
  Gancaloon - urbanism wip (Message 11 to 28 of 28)
<<< Previous 10 Messages Goto Initial 28 Messages
Subject: Re: Gancaloon - urbanism wip
Date: 3 Aug 2011 17:06:25
Message: <4e39b851$1@news.povray.org>
Thomas de Groot wrote:
> Well, this is not as simple as it seems, or I am doing something wrong
> (probably).
the subsampling of the height field needs to be done by rounding
the input coordinates
#declare cell_size = 0.03;
#declare F_flatroof = function {
  F_HF_00(int(x/cell_size)*cell_size,
          int(y/cell_size)*cell_size,
          int(z/cell_size)*cell_size).hf
and the thing about multiplying with the cell pattern was
just me not thinking clearly ;) Although it might be useful
to add a smaller scale cell pattern with low weight so that
not all houses within a block have exactly the same height.
Date: 4 Aug 2011 03:46:25
Message: <4e3a4e51$1@news.povray.org>
Happily, I am learning every day :-) This is a neat little trick,
Christian! Thank you very much indeed for sharing. I think this is going
to work superbly. Multiplying with a slightly smaller cell pattern gives
perfect results now.
I am going to implement this now on Gancaloon.
Subject: Re: Gancaloon - urbanism wip2
Date: 4 Aug 2011 04:48:09
Message: <4e3a5cc9@news.povray.org>
Using Christian's code, here is the next wip. Much better already!
Download 'gancaloon.png' (407 KB)
Preview of image 'gancaloon.png'
Date: 4 Aug 2011 18:35:41
Message: <4e3b1ebd@news.povray.org>
Nice ;)
My impression is that there is not enough space between houses.
There should probably be a fine scale road system, either painted
by hand or zeroed using some sort of crackle pattern.
Date: 5 Aug 2011 07:44:06
Message: <4e3bd786@news.povray.org>
On 5-8-2011 0:35, Christian Froeschlin wrote:
> Nice ;)
True, although the particular society of Gancaloon is based on this
closely built environment ;-)
Still, I was already working on a bit more open urbanism, like this image.
Note that I *added* the cell function instead of *multiplying* it. The
results are better because in the latter case the geometry of the
cutting function is changed in the y direction.
Download 'gancaloon.png' (409 KB)
Subject: Re: Gancaloon - urbanism wip2: workflow
Date: 5 Aug 2011 08:24:56
Message: <4e3be118$1@news.povray.org>
For those interested, this is the workflow I have developed to achieve
this view:
The urbanism is not detailed and only meant as illusion of a crowded
cityscape.
Follow this workflow (adapt details as needed):
1.  In e.g. GIMP draw a city block bitmap layer following a street
pattern layer.
2.  Export the bitmap and scale it up 10x.
3.  Add additional features according to need.
4.  Import the bitmap in Inkscape
5.  Apply Filters/Blurs/Blur content
6.  Apply Trace Bitmap with (e.g.):
           Brightness Cutoff = 0.500
           Suppress Speckles: size 2
           Smooth Corners: threshold 0.40
           Optimize Paths: tolerance 0.20
7.  Apply Paths/Simplify if needed
8.  Save as POV file (if you want to keep the svg file, save it as well)
9.  Open in POV-Ray and change the object{} content as needed:
     scale x an z by 1/10; scale up y; add textures; etc
10. translate to correct position, first by centering the object (use
dimensions given
     in the file) then by trial and error until correct (use an
orthographic vertical view)
     and apply the intersection with the cutoff function you have
created from a height_field
     and additional functions
Date: 5 Aug 2011 14:59:39
Message: <4e3c3d9b$1@news.povray.org>
Le 2011/08/04 18:35, Christian Froeschlin a écrit :
> Nice ;)
Keep in mind that it's a medieval style walled city. In those citys,
space is *scarse*! Buildings are literaly cramed toghether leaving only
the bare minimum space for the narow and twisting streets. Buildings
overhanging over the streets are relatively to very common. Facing
buildings may actualy touch each others. This makes for prety dark
streets and aleys.
Over time, as old buildings are torn down and new ones built, the
streets tend to become narower. Some streets become dead ends, and
former dead ends may now allow thru trafic. In the worst case, some
streets or group of streets can become totaly cut off from all other
streets... In that case, you may have some "tunels" through some
buildings, or strange bridges passing over buildings.
If the terrain is steep, some "streets" can actualy be stairs.
Date: 13 Aug 2011 17:05:00
Message: <web.4e46e60cb0e954807fa509390@news.povray.org>
Looks like a interesting project. Curious how it works out (I like cities views
For an ancient city (don't know if it's meant to be), a few more alleys may be
nice. Btw, they can use the axes as a sewer system, they exit nicely in the
sea...
Joost
Subject: Re: Gancaloon - urbanism wip3
Date: 19 Aug 2011 10:18:01
Message: <4e4e7099@news.povray.org>
From the other border of the River Yann, Gancaloon is going to look
something like this.
Water material based on code by Trevor Quayle; landscape patterned
texture based on code by Jaime Vives Piqueres.
My next problem now is this. I have an image_map for texturing the
roads, mostly transparant and which layers nicely over another texture,
except... if I use this patterned texture I cannot layer over it! I have
tried patterning the image_map but to no useful result. Any smart idea
you want to share? ;-)
Thanks!
Download 'gancaloon_08a.png' (560 KB)
Preview of image 'gancaloon_08a.png'
Date: 19 Aug 2011 11:12:33
Message: <4e4e7d61$1@news.povray.org>
> Thanks!
> Thomas
wow ... making progress! I LIKE where this is going. As far as smart
ideas ... well I'm bogged down working on a landscape of my own, but am
making some headway with Bill's height_field function.
Jim
Date: 19 Aug 2011 17:45:28
Message: <4e4ed978$1@news.povray.org>
Worst case you can always create a copy of the landscape height_field
translates slightly up just for the roads, so the transparency will show
the lower height_field.
> I have tried patterning the image_map but to no useful result.
Assuming you can make a road image that is white where the roads
are, black where the roads are not, and somewhat smoothed to avoid
hard edges, you should be able to load it as an image_map, use that
as a pigment_pattern with texture_map, using landscape texture for
0 and road texture for 1.
Date: 20 Aug 2011 02:46:58
Message: <4e4f5862$1@news.povray.org>
Yes, that should be last resort indeed.
Yes, that is the way I was thinking too, and started experimenting. I
see that I am on the right track (no pun intended)... Thanks!
Date: 20 Aug 2011 04:56:53
Message: <4e4f76d5@news.povray.org>
Yes! Got it at last! :-)
Note that the road pattern has also been incorporated into the
height_field (done in Geocontrol)
Download 'gancaloon.png' (419 KB)
Date: 21 Aug 2011 04:37:10
Message: <4e50c3b6$1@news.povray.org>
> sea...
The way the urbanism is built presently is intended for overview at some
distance. Real close, a totally different concept should be used where
more detailed alleyways would be provided. The period of the city is
some equivalent of 1000 AD, in the southeastern Mediterranean, but it is
not intended to represent any existing historical setting. It is
strictly imaginary with only touches of more familiar things.
Good idea about the sewer system. I might create an aqueduct or two
perhaps ;-)
Date: 23 Aug 2011 07:51:02
Message: <4e539426@news.povray.org>
Another view of the city, as seen from a boat coming from upstreams.
This is how Lord Dunsany described this part of the river in Idle Days
on the Yann, from the book A Dreamer's Tales:
[quote]
And now as the sun's last rays were nearly level, we saw the sight that
I had come to see, for from two mountains that stood on either shore two
cliffs of pink marble came out into the river, all glowing in the light
of the low sun, and they were quite smooth and of mountainous altitude,
and they nearly met, and Yann went tumbling between them and found the sea.
And this was Bar-Wul-Yann, the Gate of Yann, and in the distance through
that barrier's gap I saw the azure indescribable sea, where little
fishing-boats went gleaming by.
[/quote]
Note that Lord Dunsany visited the region long before the foundation of
Gancaloon!
Download 'gancaloon_10.png' (584 KB)
Preview of image 'gancaloon_10.png'
Date: 23 Aug 2011 09:04:32
Message: <4e53a560$1@news.povray.org>
> [quote]
> [/quote]
> Gancaloon!
> Thomas
Hey nice work ... curious about the camera settings that you are using,
mind posting a few particulars? I /really/ like how this scene is posed
... top drawer!
Date: 24 Aug 2011 03:46:07
Message: <4e54ac3f$1@news.povray.org>
On 23-8-2011 15:04, Jim Holsenback wrote:
>> Thomas
> ... top drawer!
Gladly.
Knowing that the height_field with the city has a scale of <500, 30,
500> and is centered on the origin with basis at 0.0, and knowing that
water level is y=0.60; and with the other side of the river being a
height_field with the same scale and translated <-250, 0, 0>:
//Camera positions:
#declare SceneLook      = 6;  //0=overview; 1=overview River Harbour;
2=Ruins; 3=orthographic vertical; 4=orthographic vertical for roaming
                               //5=Sikhara; 6=overside Yann; 7=offshore
Sea Harbour; 8=birdseye Yann mouth; 9=from upriver;
   #switch(SceneLook)
   #case (0)
     location  <-100, 30, -240.0>
     look_at   <-100,  0,    0.0>
   #break
   #case (1)
     location  <-140, 30, -140.0>
     look_at   <-140,  0,    0.0>
   #break
   #case(2)
     location  <-59.6, 14.3, -234.0>
     look_at   <-80.0, 25.0,    0.0>
   #break
   #case(3)
     orthographic
     location  <0.0, 300.0, 0.0>
     look_at   <0.0,   0.0, 0.0>
   #break
   #case(4)
     orthographic
     location  <-150.0, 100.0, -50.0>
     look_at   <-150.0,   0.0, -50.0>
   #break
   #case(5)
     location  <-100.0, 25.0, -50.0>
     look_at   <-150.0, 10.0,  10.0>
   #break
   #case(6)
     location  <-325.0,  5.0, -150.0>
     look_at   <-100.0, 10.0,   20.0>
   #break
   #case(7)
     location  <-100.0, 100.0, 200.0>
     look_at   <-100.0,  10.0,   0.0>
   #break
   #case(8)
     location  <-200.0, 100.0, 200.0>
     look_at   <-200.0,  10.0,   0.0>
   #break
   #case(9)
     location  <-200.0,  2.0, -200.0>
   direction 1.5*z
   angle 80
The large angle generates some deformation which are acceptable is these
kind of panoramic views.
Just ask if you want any more info.
Date: 24 Aug 2011 07:09:59
Message: <4e54dc07$1@news.povray.org>
> Thomas
Nope ... I'm good to go. Was just looking for a reality check with a
somewhat similar setup. Thanks.
