POV-Ray : Newsgroups : povray.binaries.images : Prism over a height_field? Server Time
22 Apr 2026 05:19:48 EDT (-0400)
  Prism over a height_field? (Message 11 to 12 of 12)
Subject: Re: Prism over a height_field?
Date: 30 Jul 2011 21:07:07
Message: <4e34aabb@news.povray.org>
Thomas de Groot wrote:
> The attached image is the render of a prism object (linear_sweep
> bezier_spline) generated by Inkscape from an image.
If you exported the drawing as image instead of contour you could
use it as height_field with varying heights coded in color (but maybe
not enough resolution for your large city). You could then add your
terrain height image to make it follow the terrain.
Date: 31 Jul 2011 02:50:39
Message: <4e34fb3f@news.povray.org>
Yes, that is correct. I have used that technique in the past. The reason
I switched to prisms is that - in my experience - the height_fields
generated from the image were not crisp enough to simulate buildings. At
a distance that might not be too problematic, but I am afraid that even
at the middle distance it would be perturbing the view. Still, I think I
should return to the technique and see were it brings me. Thanks for
reminding me of this.
I am now working with prisms on a part of the city now, as a first
approach, and it looks promising. I shall come back with that later
today probably.
A drawback of prisms is that in the end render time will increase. If I
had a way to go from prisms to meshes.... :-)
