POV-Ray : Newsgroups : povray.binaries.images : 10,000 grains Server Time
16 Mar 2026 04:07:12 EDT (-0400)
  10,000 grains (Message 1 to 7 of 7)
Subject: 10,000 grains
Date: 2 Apr 2011 17:25:01
Message: <web.4d9793f1218bfb1c51e8e2d10@news.povray.org>
I've been experimenting with different ways of rendering non-intersecting
grains. One way to approximate this is to make each grain a blob, and then to
subtract negative blob components from it using neighboring points. The method
is similar to how I made the underwater air bubbles, except I now have access to
a list of each point's nearest neighbors, which means the parse time is
*significantly* reduced.
This scene took 11 seconds to parse. It took only 7 minutes 9 seconds to trace
with one 7x7 area illuminating area light. Blobs, when used in this manner, are
very efficient. Total particle count: 10,090.
The Voronoi calculations (using an external program) took about 1 minute to
solve for 32,768 points. However, the output from that program only needs to be
created once. The resulting data can then be used in different ways. For this
image the actual points filled a cubic volume, but (in POV) I kept only the
points which existed in a sphere and below a plane. That is why only 10,090 out
of 32,768 points made it into the final render.
The next challenge will be to vary the particle sizes without having them
produce incorrect results :/
~Sam
Download '10090-grains.jpg' (102 KB)
Preview of image '10090-grains.jpg'
Subject: Re: 10,000 grains
Date: 2 Apr 2011 17:45:01
Message: <4d9798dd$1@news.povray.org>
On 04/02/2011 06:24 PM, Samuel Benge wrote:
> Hi,
> grains.
I see a collision between grain 8972 and 8973 ... just kidding ;-)
Some of them do look like lucky charms marsh mellow bits (the colors)
You're such a wizard at this kind of stuff  ... fantastic!
Date: 2 Apr 2011 17:52:19
Message: <4d979a93@news.povray.org>
>> Hi,
>> grains.
what, how...
> just kidding ;-)
I would hope so, since I didn't number them :P
Yeah, and the regularity of the grain sizes doesn't help...
Thanks, Jim!
Date: 2 Apr 2011 19:35:00
Message: <web.4d97b2655cefd4e394d713cc0@news.povray.org>
Sam, I think we need bad weather in your area more often - this is another
/really/ cool concept you've developed. I can see this being so useful for
gumball machines, or jars of beans, or piles of skulls, or... well, keep going
man; looking forward to seeing what you come up with next!
www.McGregorFineArt.com
Date: 2 Apr 2011 19:52:54
Message: <4d97b6d6$1@news.povray.org>
Thanks, Robert!
No intersection tests aside from pitting one blob component against
another were used, so to place non-intersecting spherical objects would
require a different paradigm altogether. The current setup assumes that
the creation of oddly-shaped objects is expected.
There is the possibility of iteratively checking for intersections, but
the C++ library I am using changes the order of the points, which means
I will need to find a way to keep track of those changes before I can
pack spherical objects.
The experimentation continues...
~Sam
Date: 3 Apr 2011 04:00:57
Message: <4d982939$1@news.povray.org>
He he... in sedimentological terms, this would be a very well-sorted,
moderately rounded sand sample :-)
You constantly amaze me.
Date: 3 Apr 2011 14:52:59
Message: <4d98c20b$1@news.povray.org>
In breakfast cereal terms that's also true. "Contains 3 important
minerals!" ;)
