POV-Ray : Newsgroups : povray.binaries.images : moai Server Time
28 May 2026 10:50:18 EDT (-0400)
  moai (Message 21 to 30 of 36)
<<< Previous 10 Messages Goto Latest 10 Messages Next 6 Messages >>>
Subject: Re: moai
Date: 1 Apr 2011 07:34:02
Message: <4d95b82a$1@news.povray.org>
On 04/01/2011 06:30 AM, Stephen wrote:
> On 01/04/2011 10:26 AM, Jim Holsenback wrote:
>> That's what I might end up doing because I'm not totally happy with
>> certain aspects of the lighting just yet ... I tried putting the statue
>> and pedestal in a light group. btw: this is supposed to be "after hours"
>> lighting
> I looks great to me.
Thanks, but I DO see what Jamie was getting at ... the wall behind the
statue, and the moai/pedestal itself desperately needs some lighting work.
After reviewing the "Light Attenuation" thread in p.gen I was wondering
if my problem was what I was doing for fade_distance when I discovered
that my scattering box was intercepting my room fill light (doh!) I
/really/ wanted to try to do this scene w/o radiosity and use a 3 point
lighting scheme ... the key light being the spot on the moai, the back
light being the light through the window firing up the scattering and
the room fill to even things out.
As far as fade_distance ... I'm still investigating but I think the
nugget here is what Christoph said:
"As I already mentioned, the key is not the fade_power, but the
fade_distance. Sufficiently far away from the light source - relative to
fade_distance (or, in other words, with sufficiently small fade_distance
relative to the scene dimensions) - the formula gets arbitrarily close
to 1/x2. "
I've been using:
#declare LightDist = vlength(LightPos);
as my value for fade_distance, Which is WRONG ... I want a smaller value
for that and up the intensity of the light source to compensate ...
@Christoph: Did I get that right?
Jim
Subject: Re: moai
Date: 1 Apr 2011 07:50:01
Message: <web.4d95bb68dc06386b05ef170@news.povray.org>
Jim Holsenback <jho### [at] povrayorg> wrote:
> I've been using:
> Jim
This is something I learned from doing the matinee scene.
What I have ended up doing, is set a relatively small fade distance (say the
size of the light itself).  I then figure out what general value I want it at a
certain distance (i.e., distance from light to your object or scene centre).
Then use the formula given in the help to back calculate the initial intensity.
For example, in my matinee scene for the projector, the distance from my
projector light to the screen is about 2400, I set the fade distance to about
4.5.  Back-calculating to get a value of 1 at the screen (calculate the
attenutaion value and take the inverse), gives an initial value of ~142,000!
This seems very high, but it works out well because of the samll fade distance.
-tgq
Subject: Re: moai
Date: 1 Apr 2011 08:40:50
Message: <4d95c7d2$1@news.povray.org>
On 04/01/2011 08:47 AM, Trevor G Quayle wrote:
> Jim Holsenback<jho### [at] povrayorg>  wrote:
>> I've been using:
>> Jim
> -tgq
Sweet ... I think I'm getting some material here for [3.4.7.9] ... also
explains what Ive was talking about with a value of 125000 in one of his
recent scenes. My initial response was ... WTF!!!
Cool ... another "teaching moments" :-)
Subject: Re: moai
Date: 1 Apr 2011 10:25:39
Message: <4d95e063$1@news.povray.org>
"Robert McGregor" <rob### [at] mcgregorfineartcom> schreef in bericht
news:web.4d95306edc0638694d713cc0@news.povray.org...
> FlyerX should get some sort of POVvy award or something; really cool
> program.
Absolutely right.
Subject: Re: moai
Date: 1 Apr 2011 11:26:21
Message: <4d95ee9d$1@news.povray.org>
>> I've been using:
>> Jim
> -tgq
OK ... so here's what I've come up with and it seems to work.
#declare Intensity = function (LD,FD) { 1/(2/((1+(LD/FD))*(1+(LD/FD)))) };
 From your example I used LD=2400 and FD=4.5 and get 142756 and some
change ;-) ... If I missed something feel free to set me straight as I'd
like to include this in [3.4.7.9] along with a small narrative.
Jim
Subject: Re: moai
Date: 1 Apr 2011 12:35:00
Message: <web.4d95fe10dc06386b05ef170@news.povray.org>
> Jim
That's exactly it.  However I would maybe modify it slightly for presentation.
You can simplify by removing the double reciprocal (just invert the original
equation).  Also, this is true for fade_power of 2, I would leave fade_power as
part of it for completeness and to avoid confusion:
#declare Intensity = function (LD,FD) {pow(1+(LD/FD),FP)/2};
Also I would perhaps call it 'intensity multiplier' or similar.  If you want a
base intensity of 2, you would multiply this factor by 2, etc.
-tgq
Subject: Re: moai
Date: 1 Apr 2011 16:10:54
Message: <4d96314e$1@news.povray.org>
>> Jim
LOL ... thanks fer makin' it purdy ;-)
> -tgq
When you get a second I'd appreciate a little QA:
http://wiki.povray.org/content/Documentation:Reference_Section_4.4#Light_Fading
Subject: Re: moai
Date: 1 Apr 2011 17:15:00
Message: <web.4d963f59dc06386b05ef170@news.povray.org>
> > -tgq
> Thanks :-)
I think the two paragraphs following the graph need to be expanded somewhat or
the ideas better explained.
A few items:
"First, when Fade_Distance is larger than one, the light intensity at distances
smaller than Fade_Distance actually increases."
Actually this is true for any fade_distance, even when it is smaller than one.
"This is necessary to get the light source color if the distance traveled equals
Fade_Distance."
This isn't really necessary, as the function *could* have been set up the
regular way with 1 instead of 2 in the numerator (as it is for material
attenuation).  I believe it was set up the way it is so that one could set the
fade distance and know that at the fade_distance the light value would equal the
set intensity (a=1).  Meant to somewhat simplify it.
This is the way I had always treated it before until recently.  Now I am seeing
how it doesn't follow a very good inverse-squared relationship over
fade_distance and somwhat beyond if it is used this way.
The way I have come to use it now is to recognize that the function does break
down to be very close to inverse squared as the distance from fade_distance gets
significantly larger.  I think that perhaps this concept should be separated and
explained, as this is the purpose of the example code you have.
If I can find some time in the next few days I will try to consider some wording
for you if you don't come up with something in the meantime.
Also, as proof-reading note, don't use i.e. when you mean e.g.  I.e. means "that
is" and should be used to clarify a general statement that has a specific
meaning, and should not be used in place of e.g. "for example".  In the case
here "i.e.: the size of the light itself" I believe this should be e.g. as it is
one good (and appropriate) example of a value you could choose, but certainly
not the only one.
Sorry if I got a bit too carried away on you, no offense is intended, I have to
review reports for peers at work and for my wife at home, so I tend to get
carried away when doing this.
Subject: Re: moai
Date: 1 Apr 2011 18:19:23
Message: <4d964f6b$1@news.povray.org>
>>> -tgq
>> Thanks :-)
yep ... I tried to punch it up a bit and was hoping that you'd offer
some insight.
> A few items:
<snip> ... I can work with what you posted here!
no worries Trevor ... if it makes the docs better, ego's shouldn't be
getting in the way ... I'm good to go. You've been a BIG help!
Subject: Re: moai
Date: 2 Apr 2011 05:50:00
Message: <web.4d96f076dc06386ef04570e0@news.povray.org>
About the sculpting part of this discussion, Here's a very nic tutorial about
blender "sculpting" without adding geometry but directly painting the bump map:
http://www.blendernation.com/2011/03/31/tutorial-glsl-bump-painting/
Of course the final part where he consolidates everything into a Normal map is
not usable for POV-Ray.
