POV-Ray : Newsgroups : povray.binaries.images : Paris by night - 1951 - wip Server Time
28 May 2026 12:13:11 EDT (-0400)
  Paris by night - 1951 - wip (Message 31 to 40 of 42)
<<< Previous 10 Messages Goto Latest 10 Messages Next 2 Messages >>>
Subject: Re: Paris by night - 1951 - wip
Date: 29 Mar 2011 03:05:45
Message: <4d9184c9$1@news.povray.org>
"Nekar Xenos" <nek### [at] gmailcom> schreef in bericht
news:op.vs2c8so9ufxv4h@xena...
> I posted the wall macro I used in my sunflower scene on
> povray.text.scene-files just in case you want to play around with it...
Thank you. I shall certainly do that,
Date: 29 Mar 2011 03:16:24
Message: <4d918748@news.povray.org>
I think we both mean the same thing :-)
As there is a lamp shade, I did not use a spotlight but simple point/area
lights within a scattering media. However, in both cases, the halo effect is
not really there like in the original, which is the reason for my emissive
media around the light source.
This is the media code I use for both halo and scattering:
//====start code
#local HaloScale    = 100;
#local colLum       = rgb <1.0, 1.0, 0.9>; // light color
#local haloTurb     = 0.1;                 // outer halo turbulence
#local haloStrength = 0.5;                 // inner and outer halo intensity
(outer halo is 50% inner halo intensity)
#local DensityShift = 0.6; //0.9      // shifts the density within the media
#local DensityHalo =
density {
  spherical
  turbulence haloTurb
  color_map {
    [0.4 rgb 0]
    [0.8 colLum*haloStrength*0.05]
    [1.0 colLum*haloStrength*0.5]
  scale <1, 1, 1>
  translate DensityShift*y
#local mediaHalo =
media {
  emission haloStrength*0.5
  intervals 1
  samples 100
  confidence 0.9999
  variance 1/10
  density {DensityHalo}
#declare LampHalo =
sphere {0, 1
  texture {pigment {rgb 0 transmit 1} finish {ambient 0 diffuse 0}}
  interior {media {mediaHalo}}
  hollow no_shadow
  translate -DensityShift*y
  scale HaloScale
  translate <-0.09911, 1.861, 0.0> //locate halo center a bit within the
lamp shade
//__________________________________________________________________________________
// a scattering media around the street lamps
#if (Halo)
  #declare LampHalo2 =
  sphere {0, 1
    interior {
      media {
        intervals 1
        samples 100
        scattering {1, (colLum*0.1)/600}  //200
        density {
          spherical
          color_map {
            [0.5 rgb 1]
            [1.0 rgb 0]
    hollow no_shadow
    scale 600             //200
    translate CamLoc
    rotate CamRot*y
  object {LampHalo2}
//====end code
Date: 29 Mar 2011 03:20:49
Message: <4d918851$1@news.povray.org>
"Stephen" <mcavoys_at@aoldotcom> schreef in bericht
news:4d90d6d0$1@news.povray.org...
> On 28/03/2011 8:06 AM, Thomas de Groot wrote:
>> "Stephen"<mcavoys_at@aoldotcom>  schreef in bericht
>> news:4d8eeda4@news.povray.org...
>>> life)
>> Yes, I can undestand that. The present street is not in the center of
>> town
>> but probably more on the periphery. Interestingly, while the overall
>> aspect
>> is rather downtrod, there still is a lawyer's office here: did you see
>> the
>> telltale oval shield above the entrance at right? I found that an
>> interesting idea when I discovered (and remembered) what it represented
>> exactly.
> I saw the sign but did not realise the significance. I would have expected
> the three balls of a pawnbroker in this district. ;-)
This one is the sign of a bailiff, so the pawnbroker should not be far
away.... :-)
> I actually prefer your sky to that of the photograph.
Yes, me too. It has bit more structure.
>>> Great idea but I think it should be less subtle. Why not bring Cathy
>>> nearer the camera?
>> Yes, I probably should.
> But you might not. :-P
I might not indeed ;-) She was already shifted away from the camera, but who
knows?
>>> Thanks, Now I will have to cut some more paper.
>>> I do like the idea of shared universes.
>> I agree. Looking forward to it :-)
> There is not much to see at the moment as your image is not very
> contrast-y and doesn't show up well in the red light of the dark room.
> When I've added a sink I'll be able to have some prints up to dry.
> What ever you do please don't change the aspect ratio as it took me all of
> Sunday morning to change the aspect ratio of the enlarger image and
> prints. I was having a blond day.
I wont as the the aspect ratio is that of the original.
Date: 29 Mar 2011 07:39:34
Message: <4d91c4f6@news.povray.org>
> away.... :-)
Always good to know. ;-)
Yes, I think that's why.
>>>> nearer the camera?
> knows?
Maybe more colourful clothes, then.
Good :-D
Regards
Date: 29 Mar 2011 09:55:00
Message: <web.4d91e422d16f200e81c811d20@news.povray.org>
> //====start code
> density {
>   spherical
>   turbulence haloTurb
>   color_map {
>     [0.4 rgb 0]
>   scale <1, 1, 1>
> #local mediaHalo =
> media {
>   intervals 1
>   samples 100
>   confidence 0.9999
>   variance 1/10
In reality, scattering media will additionally scatter the light itself, which
is why it gets illuminated outside of the direct light cone.  The scattering
media is not going to carry the light outside of the light cone (except maybe
with radiosity usage).  What I did to try to simulate this in my theatre scene
was add light sources within my media.  I ended up trying to tune a spotlight to
produce a similar illumination profile to the Henyey-Greenstein scattering
(actually a spot and a point as the spot will only cover the forward 180deg):
ecc=eccentricity for type 5 scattering
  #local I0=1/(4*pi)*(1-pow(ecc,2))/pow(1+pow(ecc,2)-2*ecc,3/2); //base
intensity
  #local I1=1/(4*pi)*(1-pow(ecc,2))/pow(1+pow(ecc,2),3/2); //maximum intensity
  union{
    light_source {0 //forward half of light scattering
      rgb (I0-I1)
      fade_power FP fade_distance FD
      spotlight
      point_at -y  // lighting direction
      radius 0     //use 0 for no hotspot
      falloff 90   //use full 90deg, doesn't work past 90
      tightness 6  //value of 6 is a good general relationship with ecc=0.6
      area_light <0, LRAD, 0> <0, 0, LRAD>  //area light parameters added to
soften if needed
      2, 2
      adaptive 1
      circular orient jitter
    light_source {0  //general base fill for scattering
      rgb (I1)
      2, 2
      adaptive 1
I don't know how this will affect the media scattering as I turned off media
interaction in mine as I just wanted the general lighting, but it may give you
some ideas to start with.
-tgq
Date: 29 Mar 2011 10:51:02
Message: <4d91f1d6@news.povray.org>
State of the art of the street surface just for your info. Placeholders
instead of buildings.
I roughened the surface a bit up and applied a slope/altitude texture to the
dirt for more reflections around the water and none higher up. I might be
able to use this same texture as a pigment_pattern to vary the cobbles'
finish in the same way.
Download 'Paris la nuit.png' (234 KB)
Preview of image 'Paris la nuit.png'
Date: 29 Mar 2011 11:30:01
Message: <web.4d91fa3ed16f200e81c811d20@news.povray.org>
> Thomas
Much more convincing.  Still more regular than cobblestones would be, but I
think I can live with it...
Have you ever tried adapting crackle pattern to cobblestones?  May be some
ptoential depending on form and metric used.  I have used it for random raindrop
ripples in water.
-tgq
Date: 29 Mar 2011 13:50:01
Message: <web.4d921a8dd16f200e94d713cc0@news.povray.org>
Thomas, here's a simple example of what I was suggesting about breaking up the
paver reflections more via a pigment_pattern mask.
In this way each brick can have its own unique pigment and normal, but the
finish is applied across the union of all bricks (as long as the texture is
applied /after/ the brick transformations):
//-------------------Start Code-------------------
#declare R = seed(0);
#declare R1 = seed(0);
#declare Brick = superellipsoid {<0.1,0.1> scale <8, 2.5, 4>/4 scale 0.975}
#declare Show_Pigment_Pattern = 0;
#macro Build_Texture()
   #local n1  = RRand(0.05,0.25,R);
   #local n2  = RRand(0.25,0.75,R);
   #local n3  = RRand(0,100,R);
   #local c1  = RRand(0.1,0.8,R1);
   #local c2  = RRand(0.1,0.8,R1);
   // simple mask to define scattered reflection areas
   pigment_pattern { dents scale 1.5 turbulence 0.5 }
   texture_map {
      [0
         #if (Show_Pigment_Pattern)
            pigment { rgb 0 }
         #else
            pigment { bozo pigment_map { [0.5 rgb c1][1 rgb c2] } }
            normal { granite n1 scale n2 translate n3 }
            finish { specular 0 reflection 0  diffuse 0.25 }
      [1
            pigment { rgb 1 }
         #else
            pigment { bozo pigment_map { [0 rgb c1][1 rgb c2] } }
            finish {
               specular 1.5 roughness 0.02
               reflection { 0.5, 1 fresnel on } conserve_energy
#declare Floor = object {
   Center_Object(
      union {
         #local cnt=0;
         #local xx=0;
         #local nx=0;
         #while (nx<10)
            #local zz=0;
            #local nz=0;
            #while (nz<30)
               object { Brick
                  rotate <RRand(-2,2,R),RRand(-2,2,R),RRand(-2,2,R)>
                  translate <xx, RRand(-0.05,0.05,R),zz>
                  #if (mod(cnt,2)=0) translate x*2 #end
                  texture { Build_Texture() }
               #local cnt=cnt+1;
               #local zz=zz+2;
               #local nz=nz+1;
            #local xx=xx+4;
            #local nx=nx+1;
      },x+y+z
object { Floor translate z*10 interior { ior 1.33 } }
//-------------------End Code-------------------
I hope this helps...
Cheers,
Rob
www.McGregorFineArt.com
Download 'reflectionmaskingbricks.png' (760 KB)
Preview of image 'reflectionmaskingbricks.png'
Date: 29 Mar 2011 17:58:07
Message: <4d9255ef@news.povray.org>
> Thomas
What I would do, is to use a somewhat larger area_light using
are_illumination. If using a looks_like, make the area_light about
double to tripple the extent of that object.
Then, place it a little bit lower than where it should be.
The fade_distance would be shorter than the dimention of the light, on
par with the non-enlarged area_light.
If needed, I may also add another, weak, light slightly in front of the
reflector, possibly with a fade_power 3 or 4.
Using radiosity won't help as radiosity can be affected by your media,
but can never illuminate any media.
It may possibly be simulated using a small, hollow, transparent,
no_image, no_shadow, and partly reflective sphere, or maybe a disk, some
distance before the lamp and use photons to reflect some light into the
media.
We need something between scattering media and SSLT for such cases when
you have some multiple scattering. It will probably be very slow...
Date: 30 Mar 2011 02:58:25
Message: <4d92d491$1@news.povray.org>
"Alain" <aze### [at] qwertyorg> schreef in bericht
news:4d9255ef@news.povray.org...
> are_illumination. If using a looks_like, make the area_light about double
> The fade_distance would be shorter than the dimention of the light, on par
> Using radiosity won't help as radiosity can be affected by your media, but
> It may possibly be simulated using a small, hollow, transparent, no_image,
> no_shadow, and partly reflective sphere, or maybe a disk, some distance
> before the lamp and use photons to reflect some light into the media.
Thanks Alain. These are a couple of things I want to try out.
