POV-Ray : Newsgroups : povray.binaries.images : Paris by night - 1951 - wip Server Time
28 May 2026 10:50:18 EDT (-0400)
  Paris by night - 1951 - wip (Message 23 to 32 of 42)
Subject: Re: Paris by night - 1951 - wip
Date: 28 Mar 2011 02:58:25
Message: <4d903191@news.povray.org>
"Nekar Xenos" <nek### [at] gmailcom> schreef in bericht
news:op.vs0ao1i0ufxv4h@xena...
> I'm sure this will be corrected if you remove the spherical media at the
> lights and use the method I described earlier in conjunction with
> spotlights.
And get better halos? Remind me where you described this, I seem to have
forgotten... :-(
Date: 28 Mar 2011 03:07:43
Message: <4d9033bf$1@news.povray.org>
"Stephen" <mcavoys_at@aoldotcom> schreef in bericht
news:4d8eeda4@news.povray.org...
Yes, I can undestand that. The present street is not in the center of town
but probably more on the periphery. Interestingly, while the overall aspect
is rather downtrod, there still is a lawyer's office here: did you see the
telltale oval shield above the entrance at right? I found that an
interesting idea when I discovered (and remembered) what it represented
exactly.
> Great idea but I think it should be less subtle. Why not bring Cathy
> nearer the camera?
Yes, I probably should.
> Thanks, Now I will have to cut some more paper.
> I do like the idea of shared universes.
I agree. Looking forward to it :-)
Date: 28 Mar 2011 10:56:19
Message: <op.vs16fxtjufxv4h@go-dynamite>
On Mon, 28 Mar 2011 08:58:26 +0200, Thomas de Groot
>> spotlights.
> forgotten... :-(
I think that if you remove your emissive halos and put spotlights there as
well as the scattering media over the whole scene it should work.
Light attenuation and media interaction should also be enabled. This works
for light shafts, so it should work for halos.
-Nekar Xenos-
Date: 28 Mar 2011 12:47:22
Message: <op.vs2bk5qiufxv4h@xena>
>> spotlights.
> forgotten... :-(
> Thomas
I played a bit with media1.pov to get the effect:
///////////////begin code////////////////////////
//	Persistence of Vision Raytracer Scene Description File
//	File: media1.pov
//	Author:
//	Description:
// Participating media environment with spotlights.
// -w320 -h240
// -w800 -h600 +a0.3
#version 3.6;
global_settings {assumed_gamma 1.0}
// The camera.
   location <10, 6, -20>
   direction <0, 0, 1.5>
   look_at <0, 4, 0>
// Add media.
media {
   scattering { 1, rgb 0.03}
   intervals 1
   samples 5
   method 3
// Light source not interacting with the atmosphere.
light_source { <0, 15, 0> color rgb 0.7
   media_interaction off
   shadowless
// Spotlight
#declare Intensity = 2;
light_source {
   <0, 9, -5> color rgb 2
   spotlight
   point_at <0, 5, 0>
   radius 45
   falloff 60
   tightness 1
   fade_distance 5
   fade_power 2
   media_attenuation on
// Room.
box { <-20, 0, -20>, <20, 20, 20>
   pigment { rgb 1 }
   finish { ambient 0.2 diffuse 0.5 }
   hollow
//////////End code///////////////////
-Nekar Xenos-
Download 'mediatest.png' (5 KB)
Preview of image 'mediatest.png'
Date: 28 Mar 2011 13:23:09
Message: <op.vs2c8so9ufxv4h@xena>
On Mon, 28 Mar 2011 08:56:12 +0200, Thomas de Groot
>> In the photo, the cobble stones are well worn and rounded. Your's looks
>> as
>> if they are new and freshly layed.
>> Some are obviously brocken and are concave.
>> It also looks like some may be missing and the resulting hole filled
>> with
>> gravel or sand.
> Yes indeed. This should be the next implementation of my macro... Not
> sure
> however if I can get that finished for the TC-RTC deadline, but certainly
> worth the effort.
I posted the wall macro I used in my sunflower scene on
povray.text.scene-files just in case you want to play around with it...
-Nekar Xenos-
Date: 28 Mar 2011 14:43:28
Message: <4d90d6d0$1@news.povray.org>
On 28/03/2011 8:06 AM, Thomas de Groot wrote:
> "Stephen"<mcavoys_at@aoldotcom>  schreef in bericht
> exactly.
I saw the sign but did not realise the significance. I would have
expected the three balls of a pawnbroker in this district. ;-)
I actually prefer your sky to that of the photograph.
>> nearer the camera?
But you might not. :-P
There is not much to see at the moment as your image is not very
contrast-y and doesn't show up well in the red light of the dark room.
When I've added a sink I'll be able to have some prints up to dry.
What ever you do please don't change the aspect ratio as it took me all
of Sunday morning to change the aspect ratio of the enlarger image and
prints. I was having a blond day.
Regards
Date: 28 Mar 2011 15:01:59
Message: <4d90db27@news.povray.org>
> "Alain"<aze### [at] qwertyorg>  schreef in bericht
> news:4d8f7ecc$1@news.povray.org...
>> It's an old neibourhood. That street pavement is probably well over 70
>> years old, it have seen both WWI and WWII.
> Absolutely.
>> In the photo, the cobble stones are well worn and rounded. Your's looks as
>> It also looks like some may be missing and the resulting hole filled with
>> gravel or sand.
> Yes indeed. This should be the next implementation of my macro... Not sure
> worth the effort.
> Thomas
The first thing to do would be to alter the mesh used for the
cobblestones for one that is more rounded. It may have a "broken"
underside. You then can use a random stream to verticaly flip some of them.
Then, also with a random stream, "forget" some.
Date: 29 Mar 2011 03:04:20
Message: <4d918474$1@news.povray.org>
"Alain" <aze### [at] qwertyorg> schreef in bericht
news:4d90db27@news.povray.org...
> The first thing to do would be to alter the mesh used for the cobblestones
> for one that is more rounded. It may have a "broken" underside. You then
Yes, that is one of the implementations I had in mind indeed, even extended
to 6 different faces. For the time being, I tweaked the surface representing
the dirt between the stones a bit further and the effect is better now. And
I put some more irregularities on the surface of the cobbles.
Date: 29 Mar 2011 03:05:45
Message: <4d9184c9$1@news.povray.org>
news:op.vs2c8so9ufxv4h@xena...
Thank you. I shall certainly do that,
Date: 29 Mar 2011 03:16:24
Message: <4d918748@news.povray.org>
I think we both mean the same thing :-)
As there is a lamp shade, I did not use a spotlight but simple point/area
lights within a scattering media. However, in both cases, the halo effect is
not really there like in the original, which is the reason for my emissive
media around the light source.
This is the media code I use for both halo and scattering:
//====start code
#local HaloScale    = 100;
#local colLum       = rgb <1.0, 1.0, 0.9>; // light color
#local haloTurb     = 0.1;                 // outer halo turbulence
#local haloStrength = 0.5;                 // inner and outer halo intensity
(outer halo is 50% inner halo intensity)
#local DensityShift = 0.6; //0.9      // shifts the density within the media
#local DensityHalo =
density {
  spherical
  turbulence haloTurb
  color_map {
    [0.4 rgb 0]
    [0.8 colLum*haloStrength*0.05]
    [1.0 colLum*haloStrength*0.5]
  scale <1, 1, 1>
  translate DensityShift*y
#local mediaHalo =
media {
  emission haloStrength*0.5
  intervals 1
  samples 100
  confidence 0.9999
  variance 1/10
  density {DensityHalo}
#declare LampHalo =
sphere {0, 1
  texture {pigment {rgb 0 transmit 1} finish {ambient 0 diffuse 0}}
  interior {media {mediaHalo}}
  hollow no_shadow
  translate -DensityShift*y
  scale HaloScale
  translate <-0.09911, 1.861, 0.0> //locate halo center a bit within the
lamp shade
//__________________________________________________________________________________
// a scattering media around the street lamps
#if (Halo)
  #declare LampHalo2 =
  sphere {0, 1
    interior {
      media {
        intervals 1
        samples 100
        scattering {1, (colLum*0.1)/600}  //200
        density {
          spherical
          color_map {
            [0.5 rgb 1]
            [1.0 rgb 0]
    hollow no_shadow
    scale 600             //200
    translate CamLoc
    rotate CamRot*y
  object {LampHalo2}
//====end code
