POV-Ray : Newsgroups : povray.binaries.images : SSLT Dragon Server Time
28 May 2026 13:23:07 EDT (-0400)
  SSLT Dragon (Message 76 to 85 of 105)
Subject: Re: SSLT Dragon
Date: 5 Mar 2011 13:15:51
Message: <4d727dd7$1@news.povray.org>
> Mike Raiford<"m[raiford]!at"@gmail.com>  wrote:
>> Final render:
> Nice!
> Why is the reflection of the sphere not affected by the depth of field though?
> Looks wrong to me...
Physicaly acurate.
The depth of field for the reflection is NOT it's visual location on the
ground, but the full distance of the object-reflective surface-camera path.
Post process focal blur does it wrong as it ignore part of the effective
distance.
You are probably to used to the post process inacurate results.
Date: 5 Mar 2011 13:20:05
Message: <web.4d727e26d81bd80d94d713cc0@news.povray.org>
Jim Holsenback <jho### [at] povrayorg> wrote:
> On 02/22/2011 03:50 PM, Stephen wrote:
> > With a bit of a back light.
> > I think I'll wait until the next RC before continuing.
> cool subject choice ... i forget the artist but a dragon image was what
> brought me to povray. hey where you been coming up with the cool test
> objects ... bishop?
Okay, back on-subject with an SSLT dragon, work-in-progress. I'm not really
satisfied with the textures yet but it's getting there... I've posted the dragon
mesh over in povray.binaries.misc so others can give it a try.
So, when's that next RC coming??
Cheers,
Rob
www.McGregorFineArt.com
Download 'sslt_dragon_wip4.png' (733 KB)
Preview of image 'sslt_dragon_wip4.png'
Date: 5 Mar 2011 14:55:01
Message: <web.4d7294ddd81bd80da7b682960@news.povray.org>
Lovely! I should play with the textures too, I've been keeping it simple up till
now to get the hang of the effect.
Quite!!
Date: 6 Mar 2011 12:30:02
Message: <web.4d73c42fd81bd80d94d713cc0@news.povray.org>
I suppose I'll wait until RC4 to do more SSLT; it's a real pain having to use
slow layered textures for the pigments, and the SSLT/radiosity/emission
artifacts in RC3 drive me bonkers!
So, I'm calling this one done for now. Rendered in 17.5 hrs.
Cheers,
Rob
Download 'sslt_dragon_final.png' (1129 KB)
Preview of image 'sslt_dragon_final.png'
Date: 6 Mar 2011 13:12:50
Message: <4d73cea2$1@news.povray.org>
> Cheers,
> Rob
dang ... that's looking pretty good there Rob!
Date: 6 Mar 2011 14:05:12
Message: <4d73dae8@news.povray.org>
Very cool work, Rob.  This should be a sample image, or at least in the
hall of fame.
Jim
Date: 6 Mar 2011 15:32:20
Message: <4d73ef54@news.povray.org>
> Cheers,
> Rob
There is no real need to use layered textures.
You can apply a pattern to SSLT. You just need to use a texture_map. The
pigment don't realy mather.
box{-1 1 texture {agate texture_map{
[0 finish{subsurface{<25, 24, 22>, <0.007, 0.008, 0.009> }]
[1 finish{subsurface{<0.8, 0.3, 0.01>,<0.0021, 0.0025, 0.00946> } ]
	scale 0.4
interior{ior 1.43}
This gives an agate pattern that closely match the pigment.
Date: 6 Mar 2011 15:49:18
Message: <4d73f34e@news.povray.org>
>> to use
>> Cheers,
>> Rob
> scale 0.4
> interior{ior 1.43}
> Alain
Oups, missing closing braces in the finishes.
Date: 6 Mar 2011 16:46:09
Message: <4d7400a1$1@news.povray.org>
Nice, very nice. RC4 for me too and I had to buy a laptop stand with fan
to cope with SSLT.
Regards
Date: 6 Mar 2011 18:45:00
Message: <web.4d741ad3d81bd80d94d713cc0@news.povray.org>
>  scale 0.4
> interior{ior 1.43}
> Alain
Thanks Alain, actually I've tried that approach and it's okay, but doesn't
really give the fine control over the look of the material that I want
artistically - those coefficients require too much hand-holding, trial & error,
and voodoo (for me anyway) to make them look "right."
With Christoph's new method of using pigments to color the scattering and
absorption it will be /so/ much easier to get a "right" result quickly. And
commenting out the subsurface component in a finish will (I assume) enable us to
do quick render tests of materials without waiting for all the subsurface
calculations. Which will also make it easy to render with-SSLT and without-SSLT
images for comparsion of the two techniques (as Christoph did with his ivory
die).
Cheers,
Rob
