POV-Ray : Newsgroups : povray.binaries.images : SSLT Dragon Server Time
28 May 2026 12:14:42 EDT (-0400)
  SSLT Dragon (Message 21 to 30 of 105)
Subject: Re: SSLT Dragon
Date: 1 Mar 2011 19:09:25
Message: <4d6d8ab5$1@news.povray.org>
Am 01.03.2011 13:05, schrieb Stephen:
> What might be of help, if you can do it, is to simplify the model. Using
> a trial version of 3DS Max I reduced the vertex count to 20% of the
> original (28 Meg, 9 Meg zipped)
Very beautiful texture!
Date: 1 Mar 2011 19:14:51
Message: <4d6d8bfb$1@news.povray.org>
On 01/03/2011 11:58 PM, Bill Pragnell wrote:
> Here's my little attempt. Rendered in 10mins, without aa though. One thing I've
> noticed is that I get a large number of bright single-pixel artifacts unless I
> use large sample counts (using 1000,100 here), even when also using aa. Is there
> any way to avoid this, or is it just the nature of the beast?
Nice but use aa it makes a difference. My samples are only 100, 50. Back
lighting makes a difference as well.
I used mm_per_unit = 1.105 for the first one and 28.6 for the green one.
It took well over an hour.
Your image looks more like marble what settings did you you use?
Regards
Date: 1 Mar 2011 19:18:25
Message: <4d6d8cd1@news.povray.org>
Thanks but as I said to Jim it is the marble from the paper.
I like the jade one posted later better.
I'm going to run some more test renders overnight.
Regards
Date: 1 Mar 2011 19:28:08
Message: <4d6d8f18@news.povray.org>
I lied, I've just noticed that they are 500, 250
Regards
Date: 2 Mar 2011 04:20:01
Message: <web.4d6e0b8ad81bd80d6dd25f0b0@news.povray.org>
But does it? I thought aa was wasted on otherwise supersampled features like
area lights, focal blur, media etc? The edges of lucy's self-shadows are lovely,
it's just the floor shadow and her horizon that show aliasing. I'll do some aa
tests tonight.
Excellent, I was shooting for a very translucent marble.
mm_per_unit = 80 (the model is about 1 unit high)
samples 1000, 100 (only way I could get rid of bright point artifacts)
subsurface { 5*colour, 0.5*(1-colour) } (IIRC!)
Bill
Date: 2 Mar 2011 06:16:50
Message: <4d6e2722$1@news.povray.org>
> tests tonight.
I did a test without aa and there are more artefacts in the non-aa
rendering.
So your model is about 80 mm (3 inches) why pick that value?
This is something I'm having difficulty getting my head around. :-(
Regards
Date: 2 Mar 2011 07:00:00
Message: <web.4d6e3131d81bd80d6dd25f0b0@news.povray.org>
> rendering.
I see what you mean. The artifacts were definitely lessened by aa, but they were
lessened much more by increasing the sampling :)
Well, I was basically just tweaking until it looked good. I don't really
understand what the subsurface:mm_per_unit ratio means, although the
scattering:absorption ratio of the subsurface values seems more intuitive (not
dissimilar to media).
I think the mm_per_unit value kind of makes sense - most everyday experience
with translucent stone objects is small statues/knick-knacks. For larger items
(metres and larger), I would expect the translucency to be much more subtle, or
even invisible, due to the greater path lengths.
I think word-of-god elucidation is required :)
Date: 2 Mar 2011 08:22:37
Message: <4d6e449d$1@news.povray.org>
>> rendering.
OK, that saves me some experimenting.
I agree that the subsurface values seems more intuitive.
I think that I'll wait until RC4, where the syntax will change, before
playing any more.
Regards
Date: 2 Mar 2011 12:40:29
Message: <4d6e810d@news.povray.org>
> mm_per_unit = 80
Using your setting of mm_per_unit  80 and subsurface {samples 500, 100 }
I think that this one turns out nice. It took five and a half hours to
after my laptop overheated)
Regards
Download 'lucy10_01c_.jpg' (183 KB)
Preview of image 'lucy10_01c_.jpg'
Date: 2 Mar 2011 12:50:07
Message: <4d6e834f$1@news.povray.org>
>> mm_per_unit = 80
I thought you were gonna wait for RC4
Now go have a cup of tea and let the ole laptop cool down for a bit ;-)
