POV-Ray : Newsgroups : povray.binaries.images : SSLT Dragon Server Time
28 May 2026 10:50:42 EDT (-0400)
  SSLT Dragon (Message 11 to 20 of 105)
Subject: Re: SSLT Dragon
Date: 27 Feb 2011 03:18:16
Message: <4d6a08c8@news.povray.org>
news:web.4d677237d81bd80d6dd25f0b0@news.povray.org...
> I'll try again next time I'm in front of it... failing that, I might still
> have
> the converted .inc file, if it's still useful?
Yes, Bill, that would be fine indeed.
Date: 27 Feb 2011 18:30:00
Message: <web.4d6ade48d81bd80da7b682960@news.povray.org>
Stephen <mcavoys_at@aoldotcom> wrote:
> On 25/02/2011 9:11 AM, Bill Pragnell wrote:
> > I'll try again next time I'm in front of it... failing that, I might still have
> That would be great, Bill.
http://www.infradead.org/~wmp/lucy.inc.zip
It's about 60mb. One mesh2, #declared as 'lucy'. Enjoy!
Date: 28 Feb 2011 03:17:23
Message: <4d6b5a13@news.povray.org>
news:web.4d6ade48d81bd80da7b682960@news.povray.org...
Thank you indeed, Bill!
Date: 28 Feb 2011 04:05:31
Message: <4d6b655b@news.povray.org>
Thanks Bill, quick to download too. :-D
Regards
Date: 1 Mar 2011 05:00:01
Message: <web.4d6cc33fd81bd80dc4633eb90@news.povray.org>
> On 24/02/2011 9:30 AM, Bill Pragnell wrote:
> >> I had the same problem with Lucy, using MeshLab. Somehow I could not get it
> >> >  converted.
> > What seemed to be the issue? I also converted Lucy (I think with Meshlab +
> > Poseray) a couple of years ago and had no problems. I did lower the triangle
> > count a bit, since the file size was vast and I knew most of it would be
> > sub-pixel in the scene I was making...
> MeshLab fails with an error message saying that the application has
> requested the Runtime to terminate in an unusual way.
> PoseRay might do it. But slowly, slowly!
> After about 10 minutes loading the PLY file the % completed bar is at
> about 2%.
I thought I'd give this a go - I grabbed the PLY file of Lucy and wrote a few
lines of Smalltalk to convert into a mesh2 file - took about 30 minutes. Flat
polygons, but, as Bill said, they're probably going to be sub-pixel anyway.
But. But... The resulting file (with 5 decimal places of accuracy) is 1.2GB in
size, and when I tried to render it on my 4GB MacBook Pro, POV took about 3.8GB
of Virtual Memory, which nowhere near fitted into the 2.3GB of free RAM I had
after the OS and file buffers took their slices. I left it trying to parse the
file for about 50 minutes then just gave up.
I might give it a go on an AWS EC2 cloud instance - it's US$0.68 per hour for a
8 CPU/7G RAM/64 Bit machine. But I've still got to get a 1.2GB file onto it!
I'm *not* going to give anyone the file, but you welcome to take the code and
run it yourself in Pharo 1.2 (a Smalltalk development environment). You *will*
need a 6GB, 8GB or greater machine to use the mesh2 though!
Cheers,
Edouard.
Date: 1 Mar 2011 07:05:34
Message: <4d6ce10e@news.povray.org>
What might be of help, if you can do it, is to simplify the model. Using
a trial version of 3DS Max I reduced the vertex count to 20% of the
original (28 Meg, 9 Meg zipped)
Regards
Download 'lucy20_01b_1.jpg' (156 KB)
Preview of image 'lucy20_01b_1.jpg'
Date: 1 Mar 2011 08:59:30
Message: <4d6cfbc2$1@news.povray.org>
sweet ... excellent material!
Date: 1 Mar 2011 11:53:53
Message: <4d6d24a1$1@news.povray.org>
Thanks but it is the bog standard marble. It is backlit and that makes a
difference. :-)
I think I'll try Lucy with the material map I used for the Buddha.
Regards
Date: 1 Mar 2011 18:37:32
Message: <4d6d833c@news.povray.org>
> difference. :-)
And here it is. I've created another simplified mesh using 10% of the
vertexes (14 Meg zipped to 5 Meg). It messes up my big idea of
mm_per_unit though.
I don't mind sharing it even though 3DS Max says the mesh is a rats nest.
Regards
Download 'lucy10_01_.jpg' (191 KB)
Preview of image 'lucy10_01_.jpg'
Date: 1 Mar 2011 19:00:01
Message: <web.4d6d8811d81bd80da7b682960@news.povray.org>
> mm_per_unit though.
Here's my little attempt. Rendered in 10mins, without aa though. One thing I've
noticed is that I get a large number of bright single-pixel artifacts unless I
use large sample counts (using 1000,100 here), even when also using aa. Is there
any way to avoid this, or is it just the nature of the beast?
Bill
Download 'sublucy.jpg' (36 KB)
Preview of image 'sublucy.jpg'
