POV-Ray : Newsgroups : povray.binaries.images : Die, cast Server Time
28 May 2026 12:06:19 EDT (-0400)
  Die, cast (Message 21 to 25 of 25)
Subject: Re: Die, cast
Date: 24 Feb 2011 11:24:56
Message: <4d668658$1@news.povray.org>
On 24/02/2011 3:26 PM, clipka wrote:
> Am 24.02.2011 12:19, schrieb Stephen:
>> I'm having problems with the mm_per_unit as it seems to need adjusted
>> WRT each mesh. I'm running tests as we speak.
> Nope - I'm pretty sure that's not the case.
I have a vague idea that it might be related to the scale of the model
not the actual size of the model in PovRay. For instance I got better
looking results with Vicky when I set the mm_per_unit as if she was
1676.4 mm not the 228.6 mm she was scaled in the scene.
But then you wrote the code and what do I know. So I am experimenting
with mm_per_unit, scattering values and material scales.
> There are some issues though that may be related to what you experience;
> for instance, SSLT doesn't yet know about unions, and needs meshes to be
> closed for realism; as your lamp Vicky comes in partial meshes, that's
> currently my best bet for what might cause you trouble.
a DFX which is a single mesh. When I exported her as an OBJ the joins
into my models.
Regards
Date: 24 Feb 2011 14:38:06
Message: <4d66b39e$1@news.povray.org>
Am 24.02.2011 17:24, schrieb Stephen:
I'd recommend leaving mm_per_unit as it /should/ be. If that doesn't
give you the proper look, it's the scattering parameters that need tweaking.
> into my models.
No need to have it /perfectly/ closed. As far as that goes, SSLT should
be rather robust.
Date: 25 Feb 2011 04:25:01
Message: <web.4d67751244ccc992c22181d10@news.povray.org>
Does SSLT support Texture Maps where each texture has its own finish and
subsurface {values}?
> > into my models.
> be rather robust.
Good, the mesh I'm using has a few triangles that are only connected at two
vertexes.
To give you an idea of what the mesh is like:
Download 'buddha_01d2_0006.jpg' (73 KB)
Preview of image 'buddha_01d2_0006.jpg'
Date: 25 Feb 2011 09:40:48
Message: <4d67bf70$1@news.povray.org>
> tweaking.
are you implying the default value here? I'm trying to pick up some of
these comments in the doc entry.
Date: 25 Feb 2011 10:48:59
Message: <4d67cf6b$1@news.povray.org>
Am 25.02.2011 15:40, schrieb Jim Holsenback:
>> tweaking.
No, I'm implying the "true" scale of the scene.
