POV-Ray : Newsgroups : povray.binaries.images : Die, cast Server Time
28 May 2026 10:39:57 EDT (-0400)
  Die, cast (Message 11 to 20 of 25)
<<< Previous 10 Messages Goto Latest 10 Messages Next 5 Messages >>>
Subject: Re: Die, cast
Date: 23 Feb 2011 14:30:27
Message: <4d656053$1@news.povray.org>
Am 23.02.2011 13:11, schrieb Jim Holsenback:
> no kidding ... why is that with isosurfaces the render times skyrocket
> (besides the obvious isosurface slow downs) ...
Actually it /is/ the obvious isosurface slow downs. SSLT is very
intersection-test-intensive, and that's exactly where isosurfaces suck.
> should i expect similar performance with updated method?
Yup. Updated stuff includes bugfixes & an easier-to-use syntax, but no
performance improvements yet.
Date: 23 Feb 2011 17:15:01
Message: <web.4d6586bc44ccc99294d713cc0@news.povray.org>
I've noticed a weird X-pattern on superellipsoid faces with SSLT in RC3, just
wondering if you get the same thing with the new method.
Here's an image that illustrates what I mean - the left superellipsoid has the
X-pattern (like triangular faces with non-planar normals), the right
superellipsoid is the exact same but with no SSLT and using reflection &
transmit instead, but it looks as expected.
So, how does your die scene look using a superellipsoid instead of the
isosurface approximation mesh?
www.McGregorFineArt.com
Download 'sslt_embossed_superellipsoid.png' (217 KB)
Preview of image 'sslt_embossed_superellipsoid.png'
Date: 23 Feb 2011 17:20:01
Message: <web.4d6587d344ccc99294d713cc0@news.povray.org>
For comparison here's an SSLT box using the same basic setup - no X-pattern in
the box though, just in the superellipsoid...
Download 'sslt_box.png' (284 KB)
Preview of image 'sslt_box.png'
Date: 23 Feb 2011 22:14:51
Message: <4d65cd2b$1@news.povray.org>
Am 23.02.2011 23:14, schrieb Robert McGregor:
> superellipsoid is the exact same but with no SSLT and using reflection&
Did you use radiosity for those images? If so, can you try again without
radiosity?
If it appears only when radiosity is enabled, chances are it will be
fixed with the next release.
Otherwise there might be some distance threshold hidden in the
superellipsoid intersection testing code; SSLT is quite sensitive to
such things, as it needs to shoot rays from just slightly below the
surface. I know that blobs have such issues, for instance. To really fix
that, I'd need to do some changes deep in the bowels of POV-Ray - which
of course is a no-go during release candidate phase.
Date: 23 Feb 2011 23:22:50
Message: <4d65dd1a@news.povray.org>
No such artifacts here, so I'm optimistic that it's something I fixed.
Subject: Ebony & Ivory
Date: 24 Feb 2011 01:54:09
Message: <4d660091@news.povray.org>
Render time 1 day 3 hours. I guess I quite like it by now...
Download 'ssltdie_2011-02-24.jpg' (147 KB)
Preview of image 'ssltdie_2011-02-24.jpg'
Date: 24 Feb 2011 06:19:46
Message: <4d663ed2$1@news.povray.org>
On 23/02/2011 7:03 PM, Stephen wrote:
> On 23/02/2011 6:21 PM, Robert McGregor wrote:
>> Yes, meshes typically render very quickly.
> I second that.
But.
I'm having problems with the mm_per_unit as it seems to need adjusted
WRT each mesh. I'm running tests as we speak.
Regards
Date: 24 Feb 2011 08:45:00
Message: <web.4d665ffc44ccc99294d713cc0@news.povray.org>
> radiosity?
Yes, definitely a radiosity issue! But it only seems to appear in conjunction
with an environment map using emission (jpeg, png, hdr, and exr all produce the
artifacts). Here is a simple scene and a few test renders that will hopefully
point you in the right direction for a fix.
#declare Use_Radiosity = 1;
#declare Use_HDR       = 1;
global_settings {
   #if (Use_Radiosity) radiosity { } #end
   mm_per_unit 10
   location <3.4, 1.6, -1.6>
   look_at  <0, 0, 0>
   angle 60
   rotate y*30
light_source { <-250, 10, 0> rgb 8 }
#if (Use_HDR)
   sphere { 0, 10000 hollow inverse
      //pigment { image_map { jpeg "sky3" interpolate 2 map_type 1 }}
      pigment { image_map { exr "probe_beach" interpolate 2 map_type 1 }}
      finish { ambient 0.25 emission 0.25 diffuse 0 }
      no_image
#declare P_SSLT_Apple = pigment { rgb <0.85, 0.84, 0.53> }
#declare F_SSLT_Apple =
   finish { subsurface { <2.29, 2.39, 1.97>, <0.0030, 0.0034, 0.046> } }
#declare T_SSLT_Apple =
   texture { pigment { P_SSLT_Apple } finish { F_SSLT_Apple } }
superellipsoid { <0.1, 0.1> texture { T_SSLT_Apple } }
Cheers,
Rob
Download 'sslt_emission_issue.png' (271 KB)
Preview of image 'sslt_emission_issue.png'
Date: 24 Feb 2011 10:14:55
Message: <4d6675ef$1@news.povray.org>
Am 24.02.2011 14:44, schrieb Robert McGregor:
Thanks, but those artifacts look very familiar to me, from a bug I've
already eliminated. That, too, did only appear with radiosity, so I'm
pretty sure your issue has been taken care of.
Date: 24 Feb 2011 10:27:12
Message: <4d6678d0$1@news.povray.org>
Am 24.02.2011 12:19, schrieb Stephen:
Nope - I'm pretty sure that's not the case.
There are some issues though that may be related to what you experience;
for instance, SSLT doesn't yet know about unions, and needs meshes to be
closed for realism; as your lamp Vicky comes in partial meshes, that's
currently my best bet for what might cause you trouble.
