POV-Ray : Newsgroups : povray.binaries.images : Lamp with SSLT Figure Server Time
28 May 2026 10:40:16 EDT (-0400)
  Lamp with SSLT Figure (Message 26 to 35 of 35)
Subject: Re: Lamp with SSLT Figure
Date: 16 Feb 2011 14:10:11
Message: <4d5c2113$1@news.povray.org>
On 16/02/2011 6:38 PM, clipka wrote:
> Am 16.02.2011 16:36, schrieb Stephen:
>> On 15/02/2011 10:32 PM, Robert McGregor wrote:
>>> How does it look with the lamp switched on?
>> In this image I gave the lampshade a filter of 0.15 and used colour rgb
>> <1.0,1.0,1.0>*50.
> Some aoi pattern might do good.
Thanks I'll try that. :-D
Regards
Date: 16 Feb 2011 21:09:55
Message: <4d5c8373@news.povray.org>
> <1.0,1.0,1.0>*50.
> Using projected_through I got unexpected results not worth wasting disc
> space on.
> http://img140.imageshack.us/i/roomv4lamp01a01d2a0005.jpg/
Nice one.
It absolutely begs for area_light with area_illumination. You have 2
choices: one area_light with circular orient the same dimention as that
of the globe, or two area_lights, one small in the center, or slightly
off center, representing the light bulb, and a second one as broad as
the globe.
For the globe, you can try using back side illumination. Just add a
second component after the diffuse component.
A trick that I did'nt try but may be interesting: Use inside_texture.
Have the normal texture be totaly transparent and the interior texture
with the texture you use now, keeping only the diffuse and ambient
components of the finish. Any specular or phong highlight is to be
applyed to the exterior texture, as well as reflections, if any.
In your test using projected_through, it looks like the light_source is
not at the center of the globe but some distance under it.
It's possible that the code for projected_through is not designed for an
object that surrounds the light and breaks down in that situation.
Date: 17 Feb 2011 04:12:08
Message: <4d5ce668$1@news.povray.org>
On 17/02/2011 2:09 AM, Alain wrote:
> Nice one.
Thanks.
> the globe.
I'll wait until I can get my head around projected_through and
looks_like but they are good ideas.
Again, worth trying.
It does doesn't it but the light is at the centre of the spheres that
make up the globe. Although the difference is below the the spheres.
I'm going to spend some time experimenting.
Regards
Date: 17 Feb 2011 04:14:38
Message: <4d5ce6fe$1@news.povray.org>
On reflection (no pun intended) I haven't the slightest idea what
pattern to use.
Regards
Date: 17 Feb 2011 04:18:39
Message: <4d5ce7ef@news.povray.org>
On 15/02/2011 12:12 PM, Stephen wrote:
> Another model, this time I used a DXF export from Poser as it is a
> single mesh as opposed to the multiple meshes a OBJ export gives. I also
> changed the room light from slightly yellow to white.
> As an aside when the lamp is rendered in isolation on a chequered plane
> the slight yellow cast in the fingers, toes and hair, disappears.
A close up using the scattering for "artificial" wax.
Regards
Download 'roomv4lamp01a_01c5c1_.jpg' (152 KB)
Preview of image 'roomv4lamp01a_01c5c1_.jpg'
Date: 17 Feb 2011 04:37:47
Message: <4d5cec6b$1@news.povray.org>
Am 17.02.2011 10:14, schrieb Stephen:
> pattern to use.
I think having the sphere be somewhat brighter where it faces the
observer would be a good thing.
Date: 17 Feb 2011 04:51:02
Message: <4d5cef86$1@news.povray.org>
>> pattern to use.
So do I but it will need to wait until I explore AOI. ;-)
Regards
Date: 20 Feb 2011 10:13:08
Message: <4d612f84@news.povray.org>
How did you think of that?
Getting the diffuse value right is a balancing act. It depends in the
light source, AA level, other objects in the scene and even the camera
angle.
BTW Karma points to the first person who can tell me the story behind
the lamp in the window, a telephone and an open door.
Regards
Download 'roomv4lamp01a_01f1_.jpg' (116 KB)
Preview of image 'roomv4lamp01a_01f1_.jpg'
Date: 21 Feb 2011 17:31:57
Message: <4d62e7dd$1@news.povray.org>
> angle.
Some times, I think in a somewhat twisted way... ;)
Date: 21 Feb 2011 17:49:27
Message: <4d62ebf7$1@news.povray.org>
Well it works well. :-D
Regards
