POV-Ray : Newsgroups : povray.binaries.images : Lamp with SSLT Figure Server Time
28 May 2026 12:06:41 EDT (-0400)
  Lamp with SSLT Figure (Message 21 to 30 of 35)
<<< Previous 10 Messages Goto Latest 10 Messages Next 5 Messages >>>
Subject: Re: Lamp with SSLT Figure
Date: 16 Feb 2011 06:33:31
Message: <4d5bb60b$1@news.povray.org>
On 16/02/2011 11:08 AM, Bruno Cabasson wrote:
> Here is another version of the SSLT candle experiment with corresponding code,
> if this can help.
Thanks Bruno,
used radiosity before) is integrating the SSLT code into Bishop3D.
code shortly.
> Still trying to render what the eye actually sees in RL ...
Good luck with that :-D
Regards
Date: 16 Feb 2011 10:36:36
Message: <4d5bef04@news.povray.org>
On 15/02/2011 10:32 PM, Robert McGregor wrote:
> How does it look with the lamp switched on?
In this image I gave the lampshade a filter of 0.15 and used colour rgb
<1.0,1.0,1.0>*50.
Using projected_through I got unexpected results not worth wasting disc
space on.
http://img140.imageshack.us/i/roomv4lamp01a01d2a0005.jpg/
Regards
Download 'roomv4lamp01a_01d4_4.jpg' (140 KB)
Preview of image 'roomv4lamp01a_01d4_4.jpg'
Date: 16 Feb 2011 10:40:00
Message: <web.4d5beebb5b9896bb4aa45fdf0@news.povray.org>
> > if this can help.
> Thanks Bruno,
> code shortly.
> Regards
>      Stephen
No attachment to my post ..
I'll yet another version in pbi with code when render finishes.
Bruno
Date: 16 Feb 2011 10:51:20
Message: <4d5bf278$1@news.povray.org>
The code was in the body of the text.
I look forward to it.
Regards
Date: 16 Feb 2011 13:38:25
Message: <4d5c19a1@news.povray.org>
Am 16.02.2011 16:36, schrieb Stephen:
> <1.0,1.0,1.0>*50.
Some aoi pattern might do good.
Date: 16 Feb 2011 14:10:11
Message: <4d5c2113$1@news.povray.org>
>> <1.0,1.0,1.0>*50.
Thanks I'll try that. :-D
Regards
Date: 16 Feb 2011 21:09:55
Message: <4d5c8373@news.povray.org>
> <1.0,1.0,1.0>*50.
> space on.
Nice one.
It absolutely begs for area_light with area_illumination. You have 2
choices: one area_light with circular orient the same dimention as that
of the globe, or two area_lights, one small in the center, or slightly
off center, representing the light bulb, and a second one as broad as
the globe.
For the globe, you can try using back side illumination. Just add a
second component after the diffuse component.
A trick that I did'nt try but may be interesting: Use inside_texture.
Have the normal texture be totaly transparent and the interior texture
with the texture you use now, keeping only the diffuse and ambient
components of the finish. Any specular or phong highlight is to be
applyed to the exterior texture, as well as reflections, if any.
In your test using projected_through, it looks like the light_source is
not at the center of the globe but some distance under it.
It's possible that the code for projected_through is not designed for an
object that surrounds the light and breaks down in that situation.
Date: 17 Feb 2011 04:12:08
Message: <4d5ce668$1@news.povray.org>
On 17/02/2011 2:09 AM, Alain wrote:
> Nice one.
Thanks.
> the globe.
I'll wait until I can get my head around projected_through and
looks_like but they are good ideas.
Again, worth trying.
It does doesn't it but the light is at the centre of the spheres that
make up the globe. Although the difference is below the the spheres.
I'm going to spend some time experimenting.
Regards
Date: 17 Feb 2011 04:14:38
Message: <4d5ce6fe$1@news.povray.org>
On reflection (no pun intended) I haven't the slightest idea what
pattern to use.
Regards
Date: 17 Feb 2011 04:18:39
Message: <4d5ce7ef@news.povray.org>
On 15/02/2011 12:12 PM, Stephen wrote:
> Another model, this time I used a DXF export from Poser as it is a
> single mesh as opposed to the multiple meshes a OBJ export gives. I also
> changed the room light from slightly yellow to white.
> As an aside when the lamp is rendered in isolation on a chequered plane
> the slight yellow cast in the fingers, toes and hair, disappears.
A close up using the scattering for "artificial" wax.
Regards
Download 'roomv4lamp01a_01c5c1_.jpg' (152 KB)
Preview of image 'roomv4lamp01a_01c5c1_.jpg'
