POV-Ray : Newsgroups : povray.binaries.images : Lamp with SSLT Figure Server Time
28 May 2026 12:06:19 EDT (-0400)
  Lamp with SSLT Figure (Message 16 to 25 of 35)
Subject: Re: Lamp with SSLT Figure
Date: 14 Feb 2011 21:20:01
Message: <web.4d59e2ca5b9896bb589572a50@news.povray.org>
Alain <aze### [at] qwertyorg> wrote:
> In fact, teeth and bone are essentialy the same base material: calcium
> carmonates.
Calcium phosphate, for vertebrates.
Date: 15 Feb 2011 07:12:34
Message: <4d5a6db2@news.povray.org>
Another model, this time I used a DXF export from Poser as it is a
single mesh as opposed to the multiple meshes a OBJ export gives. I also
changed the room light from slightly yellow to white.
As an aside when the lamp is rendered in isolation on a chequered plane
the slight yellow cast in the fingers, toes and hair, disappears.
Regards
Download 'roomv4lamp01a_01c4a_.jpg' (180 KB)
Preview of image 'roomv4lamp01a_01c4a_.jpg'
Date: 15 Feb 2011 17:35:01
Message: <web.4d5aff0d5b9896bb94d713cc0@news.povray.org>
> Regards
>      Stephen
That's looking good Steven. How does it look with the lamp switched on?
www.McGregorFineArt.com
Date: 16 Feb 2011 05:31:39
Message: <4d5ba78b$1@news.povray.org>
But thanks for asking ;-)
Regards
Date: 16 Feb 2011 06:10:00
Message: <web.4d5bb0225b9896bb4aa45fdf0@news.povray.org>
> Regards
>      Stephen
Here is another version of the SSLT candle experiment with corresponding code,
if this can help.
The big candle is 8cm high, and the checkered dome is 5m radius. Attempt for
flame is not satisfactory.
The monitor I used for this render is not calibrated, so I cannot guarantee for
light settings. I assumed the dome be lit by a very small amount, but
significantly visible. There is a balance to find between light power of flames,
fade_distance, and 'depth' of the light within the wax. In RL, the eye
compensates the relative illumination between dark scenes and to full day light.
Still trying to render what the eye actually sees in RL ...
Bruno
#version 3.7;
#declare m = 1;
#declare cm = m/100;
#declare mm = m/1000;
#declare FLAME_COLOR = (2*Orange+Yellow)/3;
#declare FLAME_POWER = 4;
#declare FLAME_FADE_DIST = 0.15*m;
#declare RAD_COUNT = 1600;
#declare SSLT_SAMPLES = <100, 50>*8;
#default { finish{ambient 0 emission 0}}
global_settings
    //assumed_gamma 2.2
    mm_per_unit 1/mm
    subsurface { samples SSLT_SAMPLES.x, SSLT_SAMPLES.y}
    radiosity
        pretrace_start 32/image_width
        pretrace_end 4/image_width
        count RAD_COUNT
        error_bound 0.5
        nearest_count 15
        recursion_limit 2
        low_error_factor 1
        media on
  location  <0.0, 1.5, -4.0>*8*cm
  direction 1.5*z
  look_at   <0.5, 1.0,  0.0>*8*cm
#declare O_Skysphere = sky_sphere {
    gradient y
    color_map {
      [0.0 rgb <0.6,0.7,1.0>]
      [0.7 rgb <0.0,0.1,0.8>]
#declare LS_Lamp = light_source {<-5, 5, -5>*m color rgb 0.2}
#macro makeLSCandle(_power)
    #local _ret = light_source
      0
      color rgb FLAME_POWER*FLAME_COLOR*_power
      area_light 1*cm*x, 2*cm*y, 20, 20
      adaptive 1 circular orient
      area_illumination on
      fade_power 2
      fade_distance FLAME_FADE_DIST
      //looks_like {sphere {0, 0.03 pigment {Red}}}
      translate 2.2*y
      scale 1/2
      scale 8*cm
      translate 0.3*cm*y
    _ret
// a checkered white marble / grey "plastic" plane
#declare O_Floor_ss = plane
  y, -1*cm
  texture
    checker
    texture
      pigment { color rgb 1 }
      finish
        specular 0.6
     ambient 0
        //reflection { 0.2 }
        // marble physical parameters from Jensen et al. "A Practical Model for
Subsurface Light Transport", Siggraph 2001
        subsurface { <2.19,2.62,3.00>,<0.0021, 0.0041, 0.0071> }
    texture
      finish
        specular 0.6
        diffuse 0.9
        ambient 0
    scale 1*m
  interior { ior 1.5 }
#declare O_Floor = plane
    y, -1*cm
    pigment {rgb 1}
// the classic chrome sphere
#declare O_ChromeSphere = sphere
    <1.5,0.7,1>*m, 0.7*m
    finish
        ambient 0 diffuse 0
        specular 0.7  roughness 0.01
        reflection { 0.7 metallic }
// a candle...
#declare O_CandleBody = blob
  threshold 0.5
  cylinder { <0.0, 0.0,  0.0>,
             <0.0, 2.0,  0.0>,  1.0,   1.0 } // candle "body"
  sphere   { <0.0, 2.5,  0.0>,  0.8,  -2.0 } // (used to shape the candle top)
  sphere   { <0.0,-0.52, 0.0>,  0.8,  -2.0 } // (used to shape the candle
bottom)
  sphere   { <0.0, 2.0, -0.5>,  0.1,  -0.2 } // the "notch" where wax runs over
  cylinder { <0.0, 1.88,-0.52>,
             <0.0, 1.5, -0.52>, 0.05,  0.2 } // a streak of wax running over
  sphere   { <0.0, 1.5, -0.55>, 0.07,  0.2 } // a drop of of wax running over
  texture
    //pigment {wrinlkles scale 0.1 color_map {[ 0.3 Blue] [0.3 Red]}}
    pigment {rgb 1}
    finish
      specular 0.2 roughness 0.2
      ambient 0
      // "artificial" wax parameters
      subsurface { < 1.6732, 1.2806, 0.6947>,< 0.0005, 0.0018, 0.0131> }
  scale 1/2
  scale 8*cm
  interior { ior 1.45 }
  rotate -y*45
// ... and the wick
#declare O_Wick = cylinder
    0, 1*cm*y, 1*mm
    pigment {rgb 0.05}
    translate 7.5*cm*y
#declare O_Flame = ovus
    3.5*mm, 3*mm
    pigment {rgbt 1}
    //finish {emission 1}
    hollow
    interior
        media
            samples 50
            scattering {1, 3/(1*cm)}
            absorption 6/(1*cm)
            density {spherical scale 2 warp {turbulence 0.7 octaves 8} scale 1/2
scale 0.3*cm scale 2*y translate -1*mm*y }
            density {spherical scale 0.3*cm scale 2*y translate -1*mm*y }
    scale 3
    translate 9*cm*y
    no_shadow
#macro makeCandle(_power)
    union
        light_source {makeLSCandle(_power)}
        object {O_CandleBody}
        object {O_Wick}
        object {O_Flame}
#declare O_Dome = sphere
    0, 5*m
    hollow
    pigment {checker scale 0.1*m}
//light_source {LS_Lamp}
object {O_Floor}
object {makeCandle(1) rotate 45*y}
object {makeCandle(0.5) scale 1/2 translate 5*cm*x - 5*cm*z}
object {O_Dome}
Date: 16 Feb 2011 06:33:31
Message: <4d5bb60b$1@news.povray.org>
> if this can help.
Thanks Bruno,
used radiosity before) is integrating the SSLT code into Bishop3D.
code shortly.
Good luck with that :-D
Regards
Date: 16 Feb 2011 10:36:36
Message: <4d5bef04@news.povray.org>
In this image I gave the lampshade a filter of 0.15 and used colour rgb
<1.0,1.0,1.0>*50.
Using projected_through I got unexpected results not worth wasting disc
space on.
http://img140.imageshack.us/i/roomv4lamp01a01d2a0005.jpg/
Regards
Download 'roomv4lamp01a_01d4_4.jpg' (140 KB)
Preview of image 'roomv4lamp01a_01d4_4.jpg'
Date: 16 Feb 2011 10:40:00
Message: <web.4d5beebb5b9896bb4aa45fdf0@news.povray.org>
> > if this can help.
> Thanks Bruno,
> code shortly.
> Regards
>      Stephen
No attachment to my post ..
I'll yet another version in pbi with code when render finishes.
Bruno
Date: 16 Feb 2011 10:51:20
Message: <4d5bf278$1@news.povray.org>
The code was in the body of the text.
I look forward to it.
Regards
Date: 16 Feb 2011 13:38:25
Message: <4d5c19a1@news.povray.org>
Am 16.02.2011 16:36, schrieb Stephen:
> <1.0,1.0,1.0>*50.
Some aoi pattern might do good.
