POV-Ray : Newsgroups : povray.binaries.images : Alienese Server Time
28 Jun 2026 00:23:47 EDT (-0400)
  Alienese (Message 7 to 16 of 16)
<<< Previous 6 Messages Goto Initial 10 Messages
Subject: Re: Alienese
Date: 19 Sep 2010 20:48:57
Message: <4c96af79@news.povray.org>
"Christian Froeschlin" <chr### [at] chrfrde> wrote in message
news:4c962d8c@news.povray.org...
> Looks neat and very elegant solution! The only problem I see
> is that the perfect grid may be a bit distracting. I just played
> with a derived pigment that uses different spacings for each
> line although it is not really a proportional font:
Cool, though for my purposes I don't need a wall of text so the pattern
should never be obvious.
Though I did think about how to make each line be a random number of
characters long...
...In fact I've given that a quick try, turns out to be pretty simple.
Here's the code:
#local f_cells = function { pattern { cells } }
#macro AlieneseWrap( LineLength, Variation )
 function {
  select( LineLength - int(f_cells(x/LineLength,y,z)*Variation) - x, 0, 1 )
 pigment_map {
  [0 rgb 0]
  [1 Alienese]
 pigment { AlieneseWrap( 25, 10 ) }
Obviously this can be adapted easily to have chinese style downwards writing
instead of left-to-right. Dunno what the syntax is for this language :)
Tek
http://evilsuperbrain.com
Download 'temp.png' (95 KB)
Preview of image 'temp.png'
Date: 19 Sep 2010 20:58:41
Message: <4c96b1c1@news.povray.org>
Extreme example!
AlieneseWrap( 60, 60 )
It looks like code, maybe I need to add some hierarchical indenting!
(probably putting too much thought into this, should get on with the sci-fi
picture I created it for!)
Tek
news:4c96af79@news.povray.org...
> characters long...
> Here's the code:
> function {
> pigment_map {
>  [0 rgb 0]
>  [1 Alienese]
> #end
> writing
> Tek
Download 'temp.png' (83 KB)
Date: 20 Sep 2010 03:20:11
Message: <4c970b2b$1@news.povray.org>
"Tek" <tek### [at] evilsuperbraincom> schreef in bericht
news:4c96b1c1@news.povray.org...
> Extreme example!
> sci-fi picture I created it for!)
Sure! But together with Christian, you have now been at the sart of a whole
new body of literature!  ;-)
Thanks!!
Date: 20 Sep 2010 16:30:00
Message: <web.4c97c40cc11dc80196b08580@news.povray.org>
> Extreme example!
This is very cool--looks like the 'matrix' code at he beginning of the MATRIX
films.
I shall have fun experimenting with these ideas; I'm still looking over your
code to fully understand it.  Nice work!  (I'm imagining the letters being used
to create a height_field--then you'd have a 'Rosetta Stone' generator.) I'm
guessing that the letters can be made to look less 'aligned' somehow--as if
hand-drawn (or hand-chisled!) by a non-artist.
Ken
Date: 22 Sep 2010 05:37:38
Message: <4c99ce62@news.povray.org>
Kenneth wrote:
> I'm imagining the letters being used to create a height_field--then
> you'd have a 'Rosetta Stone' generator. I'm guessing that the letters
> can be made to look less 'aligned' somehow--as if hand-drawn (or
I tried my variant with increased turbulence to break up
the alignment even more:
   warp {turbulence <0.4,0.2,0.2> lambda 1.0 octaves 1}
And tested it with a height_field:
#declare f_alienese = function
   pigment { AlieneseProportional scale 0.07}
height_field
   function 1024,1024
     f_bozo(x*3,y*3,z*3) - 0.04*f_alienese(x,y,0).red -
     0.04 * f_noise3d(x*250,y*250,z*250)
   pigment {color White}
   translate <-0.5,0,-0.5>
   rotate 180*y
   scale <6,1,6>
I think the results look quite promising. Of course,
for a Rosetta stone you'd also need a translation into
a widely known language such as Klingonese ;)
Download 'alienesehf.jpg' (50 KB)
Preview of image 'alienesehf.jpg'
Date: 22 Sep 2010 06:55:00
Message: <web.4c99df5ac11dc80196b08580@news.povray.org>
Indeed! Very happy to see that the HF idea works so well. (Thanks for posting
the code example, too.) Makes me want to whip up an isosurface-block version, or
perhaps some kind of superellipsoid/HF difference.
> Of course,
LOL.  And, of course, that old stand-by, Greek--the well-known intergalactic
language...
Date: 23 Sep 2010 16:20:01
Message: <web.4c9bb606c11dc80eea30b3a0@news.povray.org>
Nice work!
Date: 24 Sep 2010 08:48:58
Message: <4c9c9e3a$1@news.povray.org>
On 9/19/2010 7:58 PM, Tek wrote:
> Extreme example!
I didn't realize they made a translation of MS-DOS to Glabraxian III ... :)
Good work!
~Mike
Date: 24 Sep 2010 14:12:50
Message: <4c9cea22$1@news.povray.org>
>> Extreme example!
>> sci-fi
> Good work!
Don't talk to loud, or they will start printing contracts and publishing
end user licences in Glabraxian ;)
Date: 27 Sep 2010 10:12:30
Message: <4ca0a64e$1@news.povray.org>
I think they already do ;)
~Mike
