![](/i/fill.gif) |
High!
On 06/10/2010 04:44 AM, Dave Blandston wrote:
>> Now playing: Twilight (Vangelis) - how matching!
> Always good music!
And I thought you were a metalhead... I'm quite amazed!
> Why not post the entire scene code? I'm not very experienced with media, but the
> bright spots on the hills are very interesting. I will try to help you if I can.
O.k., but beware, its VERY long - some 1500 lines!
// Ghurghusht and the Shams System
// Credits:
// Atmosphere: Bruno Cabasson
// Water: Christoph Hormann
#include "functions.inc"
#declare ani=0; // animation flag (if mapping = 0)
#declare mapping=0; // toggles generating a cylindrical map of Ghurghusht
#declare greymap=3; // 0 = physical map, 1 = 8-bit grayscale map, 2 =
16-bit grayscale map, 3 = 24-bit map
#declare legend=0; // toggles rendering map legend only (if mapping != 0)
#declare ridges=2; // switches between various patterns for isosurface
#declare os=1; // operating system: 0 = Linux, 1 = Windows
#declare tcm=0; // terrain calculation mode: 0 = isosurface, 1 = mesh2
#declare test=0; // 0 = full globe, 1 = lake around Sitara Insula only
#declare rds=0; // radiosity switch
#if (ani=1)
#declare mapping=0;
#if (mapping)
#declare rds=0;
#if (mapping=2)
#declare greymap=1;
// Positions of planets and moons
// Column 0: orbital semi-major axis (to Shams or the respective planet)
in kilometres
// Column 1: radius in x dimension, in kilometres
// Column 2: radius in y dimension, in kilometres (if oblateness is
given then stated as -1)
// Column 3: radius in z dimension, in kilometres (if oblateness is
// Column 4: axial tilt in degrees (planets: relative to orbit around
Shams, moons: relative to planet's equatorial plane)
// Column 5: orbital inclination in degrees (planets: relative to
ecliptic, moons: relative to planet's equatorial plane)
// Column 6: orbital eccentricity
// Column 7: perihelion argument (degrees; if variable then stated als -1)
// Column 8: longitude of ascending node (degrees; if variable then
stated als -1)
// Column 9: oblateness (not taken into account if different radii
explicitly stated)
// Column 10: declination of north pole (degrees)
// Column 11: right ascension of north pole (degrees!)
// Column 12: albedo (if irrelevant (Shams) stated as -1)
// begin modifications according to Bruno Cabasson's TerraPOV tutorial
(2009)
global_settings
#if (version < 3.7 & !mapping)
assumed_gamma 1
adc_bailout 0.001
max_trace_level 20
#if (rds) radiosity { } #end
#declare TP_PLANET_RADIUS = 5124.6666;
#declare TP_BASE_RAYLEIGH_POWER = 6.7; // Constant
#declare TP_RAYLEIGH_FACTOR = 0.35; // User defined
#declare _tp_rayleigh_power = TP_BASE_RAYLEIGH_POWER*TP_RAYLEIGH_FACTOR;
#declare TP_ATMO_THICKNESS = 100; // original value: 50
#declare TP_RAYLEIGH_DENSITY_MAX = 0.15; // original value: 1
#declare TP_RAYLEIGH_AMOUNT = 2.3;
#declare _tp_rayleigh_density = density
function
TP_RAYLEIGH_DENSITY_MAX*exp(-_tp_rayleigh_power*(sqrt(x*x+(y+TP_PLANET_RADIUS)*(y+TP_PLANET_RADIUS)+z*z)
- TP_PLANET_RADIUS)/TP_ATMO_THICKNESS)
#declare TP_RAYLEIGH_SCATTERING_COLOR = rgb <0.135, 0.33, 1>;
#declare TP_ATMO_INTERVALS = 3; // Necessary for good integration
#declare TP_ATMO_SAMPLES = 3;
#declare TP_ATMO_METHOD = 3; // Adaptive
#declare TP_ATMO_BOTTOM = 0;
#declare _tp_rayleigh_media =
media
method TP_ATMO_METHOD
intervals TP_ATMO_INTERVALS
samples TP_ATMO_SAMPLES
scattering
4, TP_RAYLEIGH_AMOUNT*TP_RAYLEIGH_SCATTERING_COLOR/TP_ATMO_THICKNESS
extinction 1
density
#declare _tp_rayleigh_atmosphere = difference
sphere {0, TP_PLANET_RADIUS + TP_ATMO_BOTTOM + TP_ATMO_THICKNESS
translate -TP_PLANET_RADIUS*y}
sphere {0, TP_PLANET_RADIUS + TP_ATMO_BOTTOM translate
hollow
pigment {rgbt 1}
interior {media{_tp_rayleigh_media}}
translate TP_PLANET_RADIUS*y
// end modifications according to Bruno Cabasson's TerraPOV tutorial (2009)
#if (os=0)
#declare fontpath="/media/disk1part9/fonts/";
#else
#declare fontpath="D:/WINDOWS/Fonts/";
#declare S =
function { x*x + y*y + z*z -1 }
#declare Terrain_Part1_Function=
function
pattern
granite
scale 10
poly_wave 0.333
#declare Terrain_Part2_Function=
function
pattern
bozo
#declare Terrain_Part3_Function=
function
pattern
ripples
scale 10
turbulence 0.5
#declare P_Average =
pigment
average
pigment_map
[0.5 granite scale 10 poly_wave 0.333 ]
[1 spherical scale 10 turbulence 0.5 poly_wave 0.333 ]
[0.025 crackle scale 0.2 turbulence 1 ]
#declare Terrain_Part4_Function=
function
pigment { P_Average }
#switch (ridges)
#case (0)
#declare Terrain_Function=
function { S(x, y, z) + Terrain_Part1_Function (x*50, y*50,
z*50)*0.02 + Terrain_Part2_Function (x, y, z)*0.01 }
#break
#case (1)
function { S(x, y, z) + Terrain_Part3_Function (x*50, y*50, z*50)*0.05
#break
#case (2)
function { S(x, y, z) + Terrain_Part4_Function (x*50, y*50,
z*50).gray*0.05
#break
#if (!mapping)
#declare R1=seed(1747);
#declare R2=seed(1969);
union
sphere // Qais
0, 1
texture
pigment
gradient y
color_map
[0 rgb 1]
[0.027 rgb 1]
[0.0274 rgb 0.85]
[0.0304 rgb 0.85]
[0.0324 rgb 1]
[0.0329 rgb 1]
[0.0411 rgb 0.6]
[0.0418 rgb 0.6]
[0.0429 rgb 1]
[0.0708 rgb 1]
[0.0712 rgb 0.96]
[0.0731 rgb 0.96]
[0.0742 rgb 1]
[0.0776 rgb <0.8, 0.9, 1>]
[0.0783 rgb <0.8, 0.9, 1>]
[0.079 rgb 1]
[0.0845 rgb 1]
[0.0848 rgb <0.66, 0.85, 1>]
[0.0976 rgb <0.66, 0.85, 1>]
[0.0987 rgb 1]
[0.1102 rgb 1]
[0.1108 rgb 0.88]
[0.1128 rgb 0.88]
[0.1132 rgb 1]
[0.1339 rgb 1]
[0.1452 rgb <0.56, 0.76, 1>]
[0.1501 rgb <0.56, 0.76, 1>]
[0.1537 rgb 1]
[0.1639 rgb 1]
[0.1646 rgb 0.91]
[0.1692 rgb 0.91]
[0.1784 rgb 1]
[0.1987 rgb 1]
[0.1999 rgb <0.3, 0.7, 1>]
[0.2473 rgb <0.3, 0.7, 1>]
[0.2478 rgb 1]
[0.2538 rgb 1]
[0.2541 rgb <0.17, 0.53, 1>]
[0.2798 rgb <0.17, 0.53, 1>]
[0.2901 rgb 1]
[0.2976 rgb 1]
[0.2995 rgb <0.04, 0.45, 1>]
[0.3524 rgb <0, 0.3, 1>]
[0.4634 rgb <0, 0, 0.95>]
[0.4982 rgb <0.2, 0.59, 1>]
[0.5052 rgb <0.12, 0.56, 1>]
[0.5475 rgb <0, 0, 0.97>]
[0.6789 rgb <0.06, 0.47, 1>]
[0.6967 rgb <0.3, 0.8, 1>]
[0.6978 rgb 0.35]
[0.7032 rgb 0.35]
[0.7035 rgb 0.86]
[0.7472 rgb 0.89]
[0.7498 rgb <0.42, 0.86, 1>]
[0.7767 rgb <0.42, 0.86, 1>]
[0.7782 rgb 0.93]
[0.8245 rgb 0.93]
[0.8261 rgb <0.45, 0.89, 1>]
[0.8673 rgb <0.45, 0.89, 1>]
[0.8702 rgb 0.75]
[0.8712 rgb 0.75]
[0.8713 rgb 0.43]
[0.8756 rgb 0.43]
[0.876 rgb 1]
[0.8903 rgb 1]
[0.8916 rgb 0.68]
[0.8923 rgb 0.68]
[0.8928 rgb 1]
[0.9139 rgb 1]
[0.9142 rgb 0.53]
[0.9187 rgb 0.53]
[0.9193 rgb 1]
[0.9372 rgb 1]
[0.9398 rgb 0.48]
[0.9508 rgb 0.48]
[0.9682 rgb 1]
[1 rgb 1]
turbulence 0.02
scale 2
translate y
finish { ambient 0.0005 diffuse 1 brilliance 0.4 }
difference
cylinder
<0, -0.002, 0>, <0, 0.002, 0>, 2.4
cylinder
<0, -0.0021, 0>, <0, 0.0021, 0>, 1.5
double_illuminate
texture
pigment
cylindrical
color_map
[0 rgbf <1, 0.97, 0.985, 0.6>]
[0.0092 rgbf <1, 0.97, 0.985, 0.6>]
[0.0092 rgbf <0.65, 0.62, 0.47, 0.14>]
[0.0107 rgbf <0.65, 0.62, 0.47, 0.14>]
[0.0107 rgbf <1, 0.97, 0.985, 0.6>]
[0.0127 rgbf <1, 0.97, 0.985, 0.6>]
[0.0127 rgbf <0.75, 0.696, 0.672, 0.36>]
[0.0141 rgbf <0.75, 0.696, 0.672, 0.36>]
[0.0141 rgbf <1, 0.97, 0.985, 0.6>]
[0.0184 rgbf <1, 0.97, 0.985, 0.6>]
[0.0184 rgbf <1, 1, 1, 0.6>]
[0.0205 rgbf <1, 1, 1, 0.6>]
[0.0205 rgbf <1, 0.97, 0.985, 0.6>]
[0.0321 rgbf <1, 0.97, 0.985, 0.6>]
[0.0321 rgbf <0.89, 0.87, 0.834, 0.64>]
[0.0373 rgbf <0.89, 0.87, 0.834, 0.64>]
[0.0373 rgbf <1, 0.97, 0.985, 0.6>]
[0.0452 rgbf <1, 0.97, 0.985, 0.6>]
[0.0452 rgbf <0.98, 0.95, 0.81, 0.43>]
[0.0487 rgbf <0.98, 0.95, 0.81, 0.43>]
[0.0487 rgbf <1, 0.97, 0.985, 0.6>]
[0.0532 rgb <1, 0.97, 0.985, 0.6>]
[0.0532 rgb <0.97, 0.925, 0.896, 0.51>]
[0.0575 rgb <0.97, 0.925, 0.896, 0.51>]
[0.0575 rgbf <0.683, 0.5904, 0.2164, 0.8>]
[0.0603 rgbf <0.683, 0.5904, 0.2164, 0.8>]
[0.0603 rgbf <1, 0.963, 0.888, 0.534>]
[0.0651 rgbf <1, 0.963, 0.888, 0.534>]
[0.0651 rgbf <0.742, 0.7195, 0.6721, 0.248>]
[0.0675 rgbf <0.742, 0.7195, 0.6721, 0.248>]
[0.0675 rgbf <0.721, 0.612, 0.5139, 0.557>]
[0.0692 rgbf <0.721, 0.612, 0.5139, 0.557>]
[0.0692 rgbf <0.965, 0.948, 0.8123, 0.092>]
[0.0732 rgbf <0.965, 0.948, 0.8123, 0.092>]
[0.0732 rgbf <0.7921, 0.78231, 0.6231, 0.47>]
[0.0762 rgbf <0.7921, 0.78231, 0.6231, 0.47>]
[0.0762 rgbf <0.7812, 0.7526, 0.5931, 0.53>]
[0.0804 rgbf <0.7812, 0.7526, 0.5931, 0.53>]
[0.0804 rgbf <0.7415, 0.7126, 0.6312, 0.12>]
[0.0829 rgbf <0.7415, 0.7126, 0.6312, 0.12>]
[0.0829 rgbf <0.6712, 0.6623, 0.4894, 0.73>]
[0.0853 rgbf <0.6712, 0.6623, 0.4894, 0.73>]
[0.0853 rgbf <0.5921, 0.5823, 0.5561, 0.376>]
[0.0881 rgbf <0.5921, 0.5823, 0.5561, 0.376>]
[0.0881 rgbf <0.3126, 0.2531, 0.0037, 0.621>]
[0.09 rgbf <0.3126, 0.2531, 0.0037, 0.621>]
[0.09 rgbf <1, 0.97, 0.985, 0.6>]
[0.09 rgbf <0.2, 0.14, 0.04, 0.045>]
[0.1023 rgbf <0.2, 0.14, 0.04, 0.045>]
[0.1023 rgbf <1, 0.95, 0.94, 0.5>]
[0.1065 rgbf <1, 0.95, 0.94, 0.5>]
[0.1065 rgbf <0.45, 0.38, 0.29, 0.19>]
[0.1083 rgbf <0.45, 0.38, 0.29, 0.19>]
[0.1083 rgbf <0.93, 0.85, 0.81, 0.55>]
[0.1102 rgbf <0.93, 0.85, 0.81, 0.55>]
[0.1102 rgbf <0.74, 0.61, 0.46, 0.21>]
[0.1108 rgbf <0.74, 0.61, 0.46, 0.21>]
[0.1108 rgbf <0.51, 0.457, 0.219, 0.77>]
[0.1134 rgbf <0.51, 0.457, 0.219, 0.77>]
[0.1134 rgbf <0.49, 0.416, 0.193, 0.92>]
[0.1156 rgbf <0.49, 0.416, 0.193, 0.92>]
[0.1156 rgbf <0.692, 0.623, 0.523, 0.14>]
[0.1181 rgbf <0.692, 0.623, 0.523, 0.14>]
[0.1181 rgbf <0.815, 0.761, 0.4134, 0.69>]
[0.1197 rgbf <0.815, 0.761, 0.4134, 0.69>]
[0.1197 rgbf <0.512, 0.412, 0.3218, 0.92>]
[0.1215 rgbf <0.512, 0.412, 0.3218, 0.92>]
[0.1215 rgbf <0.478, 0.423, 0.2951, 0.85>]
[0.1228 rgbf <0.478, 0.423, 0.2951, 0.85>]
[0.1228 rgbf <0.1946, 0.1725, 0.0842, 0.94>]
[0.1251 rgbf <0.1946, 0.1725, 0.0842, 0.94>]
[0.1251 rgbf <0.8153, 0.7841, 0.7522, 0.25>]
[0.1275 rgbf <0.8153, 0.7841, 0.7522, 0.25>]
[0.1275 rgbf <0.5278, 0.5005, 0.3928, 0.68>]
[0.1299 rgbf <0.5278, 0.5005, 0.3928, 0.68>]
[0.1299 rgbf <0.8039, 0.7869, 0.7521, 0.29>]
[0.1327 rgbf <0.8039, 0.7869, 0.7521, 0.29>]
[0.1327 rgbf <0.5732, 0.5412, 0.3412, 0.67>]
[0.1339 rgbf <0.5732, 0.5412, 0.3412, 0.67>]
[0.1339 rgbf <0.951, 0.9082, 0.8312, 0.2209>]
[0.1374 rgbf <0.951, 0.9082, 0.8312, 0.2209>]
[0.1374 rgbf <0.6731, 0.6233, 0.4678, 0.4761>]
[0.14 rgbf <0.6731, 0.6233, 0.4678, 0.4761>]
[0.14 rgbf <0.8592, 0.8492, 0.5782, 0.2375>]
[0.1415 rgbf <0.8592, 0.8492, 0.5782, 0.2375>]
[0.1415 rgbf <0.7572, 0.6531, 0.5905, 0.4231>]
[0.1447 rgbf <0.7572, 0.6531, 0.5905, 0.4231>]
[0.1447 rgbf <0.4824, 0.4245, 0.3126, 0.8634>]
[0.1476 rgbf <0.4824, 0.4245, 0.3126, 0.8634>]
[0.1476 rgbf <0.5123, 0.4563, 0.2195, 0.7361>]
[0.1503 rgbf <0.5123, 0.4563, 0.2195, 0.7361>]
[0.1503 rgbf <0.3735, 0.3129, 0.1938, 0.0412>]
[0.1523 rgbf <0.3735, 0.3129, 0.1938, 0.0412>]
[0.1523 rgbf <0.4123, 0.3563, 0.2453, 0.0932>]
[0.1547 rgbf <0.4123, 0.3563, 0.2453, 0.0932>]
[0.1547 rgbf <0.4593, 0.4126, 0.2231, 0.4231>]
[0.1601 rgbf <0.4593, 0.4126, 0.2231, 0.4231>]
[0.1601 rgbf <0.4003, 0.3521, 0.1963, 0.0214>]
[0.1634 rgbf <0.4003, 0.3521, 0.1963, 0.0214>]
[0.1651 rgbf <0.4003, 0.3521, 0.1963, 0.0214>]
[0.1651 rgbf <0.5124, 0.4751, 0.2768, 0.2544>]
[0.1678 rgbf <0.5124, 0.4751, 0.2768, 0.2544>]
[0.1678 rgbf <0.5069, 0.4457, 0.2989, 0.3444>]
[0.1695 rgbf <0.5069, 0.4457, 0.2989, 0.3444>]
[0.1695 rgbf <0.5241, 0.4321, 0.1295, 0.9542>]
[0.1732 rgbf <0.5241, 0.4321, 0.1295, 0.9542>]
[0.1732 rgbf <0.4721, 0.4109, 0.1758, 0.4682>]
[0.176 rgbf <0.4721, 0.4109, 0.1758, 0.4682>]
[0.176 rgbf <0.4832, 0.4201, 0.2254, 0.2156>]
[0.1776 rgbf <0.4832, 0.4201, 0.2254, 0.2156>]
[0.1776 rgbf <0.4369, 0.3974, 0.2405, 0.1198>]
[0.1805 rgbf <0.4369, 0.3974, 0.2405, 0.1198>]
[0.1805 rgbf <0.5823, 0.5172, 0.4423, 0.5768>]
[0.1828 rgbf <0.5823, 0.5172, 0.4423, 0.5768>]
[0.1828 rgbf <0.5492, 0.5047, 0.4782, 0.315>]
[0.1857 rgbf <0.5492, 0.5047, 0.4782, 0.315>]
[0.1857 rgbf <0.5392, 0.4902, 0.4248, 0.229>]
[0.1891 rgbf <0.5392, 0.4902, 0.4248, 0.229>]
[0.1891 rgbf <0.5205, 0.4721, 0.4004, 0.311>]
[0.1916 rgbf <0.5205, 0.4721, 0.4004, 0.311>]
[0.1916 rgbf <0.5085, 0.4631, 0.3815, 0.782>]
[0.197 rgbf <0.5085, 0.4631, 0.3815, 0.782>]
[0.197 rgbf <0.4581, 0.413, 0.3241, 0.762>]
[0.1994 rgbf <0.4581, 0.413, 0.3241, 0.762>]
[0.1994 rgbf <0.4329, 0.3571, 0.2554, 0.1563>]
[0.2041 rgbf <0.4329, 0.3571, 0.2554, 0.1563>]
[0.2041 rgbf <0.4003, 0.32, 0.2136, 0.537>]
[0.2067 rgbf <0.4003, 0.32, 0.2136, 0.537>]
[0.2067 rgbf <0.4153, 0.3041, 0.1942, 0.3478>]
[0.2089 rgbf <0.4153, 0.3041, 0.1942, 0.3478>]
[0.2089 rgbf <0.3999, 0.3128, 0.1911, 0.3237>]
[0.2112 rgbf <0.3999, 0.3128, 0.1911, 0.3237>]
[0.2112 rgbf <0.3745, 0.2984, 0.1736, 0.5123>]
[0.2137 rgbf <0.3745, 0.2984, 0.1736, 0.5123>]
[0.2137 rgbf <0.3763, 0.2742, 0.1836, 0.221>]
[0.2154 rgbf <0.3763, 0.2742, 0.1836, 0.221>]
[0.2154 rgbf <0.3423, 0.2532, 0.1325, 0.198>]
[0.2181 rgbf <0.3423, 0.2532, 0.1325, 0.198>]
[0.2181 rgbf <0.3321, 0.2409, 0.1452, 0.209>]
[0.22 rgbf <0.3321, 0.2409, 0.1452, 0.209>]
[0.22 rgbf <0.11, 0.045, 0.001, 1>]
[0.2223 rgbf <0.11, 0.045, 0.001, 1>]
[0.2223 rgbf <0.3163, 0.2376, 0.1508, 0.2842>]
[0.2246 rgbf <0.3163, 0.2376, 0.1508, 0.2842>]
[0.2246 rgbf <0.3004, 0.2153, 0.1276, 0.3412>]
[0.2275 rgbf <0.3004, 0.2153, 0.1276, 0.3412>]
[0.2275 rgbf <0.2987, 0.2204, 0.1264, 0.3934>]
[0.23 rgbf <0.2987, 0.2204, 0.1264, 0.3934>]
[0.23 rgbf <0.2835, 0.2175, 0.1003, 0.2145>]
[0.2331 rgbf <0.2835, 0.2175, 0.1003, 0.2145>]
[0.2331 rgbf <0.2809, 0.1984, 0.0921, 0.3674>]
[0.2367 rgbf <0.2809, 0.1984, 0.0921, 0.3674>]
[0.2367 rgbf <0.279, 0.1912, 0.0909, 0.4582>]
[0.2389 rgbf <0.279, 0.1912, 0.0909, 0.4582>]
[0.2389 rgbf <0.2659, 0.1738, 0.1184, 0.44>]
[0.2406 rgbf <0.2659, 0.1738, 0.1184, 0.44>]
[0.2406 rgbf <0.2711, 0.166, 0.1053, 0.5693>]
[0.2437 rgbf <0.2711, 0.166, 0.1053, 0.5693>]
[0.2437 rgbf <0.2523, 0.123, 0.0934, 0.5552>]
[0.2459 rgbf <0.2523, 0.123, 0.0934, 0.5552>]
[0.2459 rgbf <0.2401, 0.1264, 0.0894, 0.126>]
[0.2483 rgbf <0.2401, 0.1264, 0.0894, 0.126>]
[0.291 rgbf <0.09, 0.035, 0.001, 1>]
[0.294 rgb <0.98, 0.94, 0.97, 0.2>]
[0.296 rgbf <0.09, 0.035, 0.001, 1>]
[0.3289 rgbf <0.092, 0.032, 0.002, 1>]
[0.3293 rgbf <0.78, 0.71, 0.21, 0.3>]
[0.3299 rgbf <0.78, 0.71, 0.21, 0.3>]
[0.3301 rgbf <0.089, 0.029, 0.0017, 0.99>]
[0.3325 rgbf <0.089, 0.029, 0.0017, 0.99>]
[0.3325 rgbf <0.34, 0.29, 0.007, 0.32>]
[0.3333 rgbf <0.34, 0.29, 0.007, 0.32>]
[0.3333 rgbf <0.09, 0.027, 0.0015, 0.84>]
[0.3357 rgbf <0.09, 0.027, 0.0015, 0.84>]
[0.3357 rgbf <0.37, 0.29, 0.013, 0.54>]
[0.3364 rgbf <0.37, 0.29, 0.013, 0.54>]
[0.3365 rgbf <0.09, 0.027, 0.0015, 0.84>]
[0.3397 rgbf <0.09, 0.027, 0.0015, 0.84>]
[0.34 rgbf <0.54, 0.49, 0.09, 0.23>]
[0.3412 rgbf <0.53, 0.497, 0.085, 0.25>]
[0.3415 rgbf <0.09, 0.027, 0.0015, 0.84>]
[0.3421 rgbf <0.09, 0.027, 0.0015, 0.84>]
[0.3421 rgbf <0.1034, 0.0256, 0.008, 0.87>]
[0.3438 rgbf <0.1034, 0.0256, 0.008, 0.87>]
[0.3438 rgbf <0.126, 0.0463, 0.0042, 0.912>]
[0.3449 rgbf <0.126, 0.0463, 0.0042, 0.912>]
[0.3449 rgbf <0.115, 0.0408, 0.0052, 0.905>]
[0.3465 rgbf <0.115, 0.0408, 0.0052, 0.905>]
[0.3465 rgbf <0.105, 0.0467, 0.0053, 0.942>]
[0.3479 rgbf <0.105, 0.0467, 0.0053, 0.942>]
[0.3479 rgbf <0.109, 0.0504, 0.0023, 0.921>]
[0.3482 rgbf <0.109, 0.0504, 0.0023, 0.921>]
[0.3482 rgbf <0.116, 0.0532, 0.0038, 0.829>]
[0.3509 rgbf <0.116, 0.0532, 0.0038, 0.829>]
[0.3509 rgbf <0.1362, 0.07631, 0.0091, 0.821>]
[0.3521 rgbf <0.1362, 0.07631, 0.0091, 0.821>]
[0.3521 rgbf <0.0921, 0.0683, 0.0073, 0.859>]
[0.3529 rgbf <0.0921, 0.0683, 0.0073, 0.859>]
[0.3529 rgbf <0.1582, 0.0921, 0.0089, 0.912>]
[0.3576 rgbf <0.1582, 0.0921, 0.0089, 0.912>]
[0.3576 rgbf <0.1542, 0.0931, 0.0082, 0.921>]
[0.3592 rgbf <0.1542, 0.0931, 0.0082, 0.921>]
[0.3592 rgbf <0.1321, 0.1021, 0.0079, 0.949>]
[0.3607 rgbf <0.1321, 0.1021, 0.0079, 0.949>]
[0.3607 rgbf <0.1129, 0.0929, 0.0081, 0.841>]
[0.3613 rgbf <0.1129, 0.0929, 0.0081, 0.841>]
[0.3613 rgbf <0.1031, 0.0842, 0.0072, 0.846>]
[0.3628 rgbf <0.1031, 0.0842, 0.0072, 0.846>]
[0.3628 rgbf <0.0953, 0.0472, 0.0074, 0.869>]
[0.3648 rgbf <0.0953, 0.0472, 0.0074, 0.869>]
[0.3648 rgbf <0.0973, 0.0381, 0.0037, 0.563>]
[0.3657 rgbf <0.0973, 0.0381, 0.0037, 0.563>]
[0.3657 rgbf <0.0982, 0.0429, 0.0053, 0.583>]
[0.3682 rgbf <0.0982, 0.0429, 0.0053, 0.583>]
[0.3682 rgbf <0.4721, 0.4127, 0.0153, 0.109>]
[0.3705 rgbf <0.4721, 0.4127, 0.0153, 0.109>]
[0.3705 rgbf <0.1023, 0.0357, 0.0003, 0.984>]
scale 2.4
finish { ambient 0.05 diffuse 1 brilliance 0.2 }
scale <63879, 58782, 63879>
rotate <-8.6, 0, 27.7>
#if (!ani)
#declare Pos_Ghurghusht = 3961542 * <sin(radians(270)), 0,
cos(radians(270))>;
#declare Rot_Ghurghusht = <0, 153, 0>;
#else
#declare Pos_Ghurghusht = 3961542 * <sin(radians(50)), 0,
cos(radians(50))>;
#declare Pos_Shams = <-104720000, 0, 0>;
light_source // Shams
Pos_Shams
color rgb <1, 1, 0.95>
sphere
(Pos_Shams-Pos_Ghurghusht)/100, 6230
texture
pigment { color rgb <1, 1, 0.95> }
finish { ambient 1 diffuse 0 }
no_shadow
#declare T_Ghurghusht=
texture
pigment { color rgb <0.98, 0.85, 0.45> }
finish { ambient 0.003 diffuse 1 brilliance 0.98 }
#if (tcm=0)
#declare Ghurghusht =
isosurface
function { Terrain_Function(x, y, z) }
contained_by { sphere { 0, 1 } }
max_gradient 5
accuracy 0.0001
double_illuminate
texture { T_Ghurghusht }
scale 5178
#else
#declare hf=
pigment
image_map
png "tiles/ghurghusht360_n05_040.png"
#declare sl=5124.6666;
#declare rng=31.5519+6.2452;
#declare ll=sl-6.2452;
#declare long=40;
#declare lat=5;
mesh2
vertex_vectors
1440000 // 1200 * 1200
#declare a=0;
#while (a<1200)
#declare b=0;
#while (b<1200)
#declare rd=eval_pigment(hf, <1/2400+b/1200, 2399/2400-a/1200, 0>).red;
#declare gr=eval_pigment(hf, <1/2400+b/1200, 2399/2400-a/1200,
0>).green/256;
#declare bl=eval_pigment(hf, <1/2400+b/1200, 2399/2400-a/1200,
0>).blue/65536;
(ll+(rd+gr+bl)*rng)*<sin(radians(-long-(10/3)*(1/2400+b/1200)))*cos(radians(lat-(10/3)*(1/2400+a/1200))),
sin(radians(lat-(10/3)*(1/2400+a/1200))),
cos(radians(-long-(10/3)*(1/2400+b/1200)))*cos(radians(lat-(10/3)*(1/2400+a/1200)))>
#declare b=b+1;
// #warning concat("Assigning vectors for line ", str(a, 4, 0))
#declare a=a+1;
face_indices
2875202 // 1199 * 1199 * 2
#declare a = 0;
#while (a < 1199)
#declare b = 0;
#while (b < 1199)
<1200*a + b, 1200*a + b+1, 1200*(a+1) + b>,
<1200*a + b+1, 1200*(a+1) + b+1, 1200*(a+1) + b>
#if(b<(l-2))
#declare b = b+1;
#warning concat("Parsing lines ", str(a, 4, 0), " and ", str(a+1, 4,
0),".")
#declare a = a+1;
#if (!mapping)
#declare Box_Cutout =
box
<-1, -10, -1>, <1, 30, 1>
#declare surfPos = trace(Ghurghusht, 0,
<sin(radians(-140.5905556))*cos(radians(0.368888888)),
sin(radians(0.368888888)),
cos(radians(-140.5905556))*cos(radians(0.368888888))>);
rotate <0, 0, 90-0.368888888>
rotate <0, -50.5905556, 0>
translate surfPos
union
#if (test = 1)
intersection
union
object { Ghurghusht }
sphere
0, 1
material {
color rgbt <1, 1, 1, 1>
finish {
diffuse 0
reflection {
<0.03, 0.03, 0.04>, <0.75, 0.75, 1>
exponent 1.2
falloff 5
fresnel on
phong 1
phong_size 2500000
normal
bozo 1.5
bump_size 0.5
scale 0.00000013
interior {
ior 1.34
scale 5178*0.9897 // sea level at 5124.6666 kms
sphere
0, 1
hollow
texture
pigment { color rgb <0, 0, 0.5> }
finish { ambient 0.05 diffuse 1 brilliance 1 }
scale 5178*0.98969999 // preliminary sea floor at 5124.666548 kms
#if (test = 1)
object { Box_Cutout }
bounded_by { object { Box_Cutout } }
#if (test = 0)
object { _tp_rayleigh_atmosphere }
#if (ani=1)
rotate y*(clock/10)
rotate Rot_Ghurghusht
translate Pos_Ghurghusht
#if (test = 1)
sky_sphere
pigment
gradient y
color_map
[0 rgb <0.8, 1, 1>]
[0.15 rgb <0, 0.7, 1>]
[0.3 rgb <0, 0.3, 1>]
[1 rgb <0, 0.3, 1>]
#declare view=12;
#if (test=1)
#declare view=12;
#switch (view)
#case (0)
#declare camPos=Pos_Ghurghusht + 20000 * <sin(radians(300)), 0,
cos(radians(300))>;
#declare camLook=Pos_Ghurghusht-<7200, 0, 0>;
#declare camAng=1.5;
#declare surfPos=<-1, 0, 0>;
#break
#case (1)
#declare camPos=Pos_Ghurghusht + 20000 * <sin(radians(270)), 0,
cos(radians(270))>;
#declare camLook=Pos_Ghurghusht;
#declare camAng=40;
#declare surfPos=<0, 1, 0>;
#break
#case (2)
#declare lat=0.131666666;
#declare long=140.902222;
#declare ht=3000;
#declare dir=0;
#declare azi=-89.999;
#declare camAng=40;
#break
#case (3) // equivalent to Cologne, Germany
#declare lat=51;
#declare long=7;
#declare ht=1000;
#declare dir=0;
#declare camAng=40;
#break
#case (3.01) // equivalent to Cologne, Germany
#declare lat=51;
#declare long=7;
#declare ht=250;
#declare dir=0;
#declare camAng=40;
#break
#case (3.02) // equivalent to Cologne, Germany
#declare lat=51;
#declare long=7;
#declare ht=50;
#declare dir=0;
#declare camAng=40;
#break
#case (4) // equivalent to Kabul, Afghanistan
#declare lat=34.5;
#declare long=67.75;
#declare ht=0.0017;
#declare dir=0;
#declare azi=0;
#declare camAng=40;
#break
#case (5) // Centlivres Lacus
#declare lat=-33.54;
#declare long=110.78;
#declare ht=0.0017;
#declare dir=0;
#declare azi=0;
#declare camAng=40;
#break
#case (6) // substellar point
#declare lat=0;
#declare long=90;
#declare ht=0.0017;
#declare dir=180;
#declare azi=0;
#declare camAng=40;
#break
#case (7) // 45 degrees west from substellar point
#declare lat=0;
#declare long=45;
#declare ht=0.0017;
#declare dir=0;
#declare azi=0;
#declare camAng=40;
#break
#case (8) // 55 degrees west from substellar point
#declare lat=0;
#declare long=35;
#declare ht=0.0017;
#declare dir=90;
#declare azi=89.999;
#declare camAng=40;
#break
#case (9) // 65 degrees west from substellar point
#declare lat=0;
#declare long=25;
#declare ht=0.0017;
#declare dir=180;
#declare azi=0;
#declare camAng=40;
#break
#case (10) // 80 degrees west from substellar point
#declare lat=0;
#declare long=10;
#declare ht=0.05;
#declare dir=90;
#declare azi=10;
#declare camAng=40;
#break
#case (11) // 90 degrees west from substellar point
#declare lat=0;
#declare long=0;
#declare ht=5;
#declare dir=90;
#declare azi=0;
#declare camAng=40;
#break
#case (12) // Schmidt Lacus, Achakzai Peninsula
#declare lat=0.368888888;
#declare long=140.5905556;
#declare ht=0.0017;
#declare dir=160;
#declare azi=0;
#declare camAng=40;
#break
#case (13) // 90 degrees east from substellar point
#declare lat=0;
#declare long=180;
#declare ht=0.5;
#declare dir=270;
#declare azi=0;
#declare camAng=40;
#break
#case (14) // Test scene for isosurface vs. mesh2 comparison
#declare lat=1.8;
#declare long=43.2;
#declare ht=0.0017;
#declare dir=315;
#declare azi=0;
#declare camAng=40;
#break
#case (15) // Rathjens Lacus
#declare lat=17;
#declare long=27.8;
#declare ht=0.0017;
#declare dir=90;
#declare azi=0;
#declare camAng=40;
#break
#case (16) // Start point for Ghurghusht Equatorial Flight
#declare lat=0;
#declare long=25.53056789;
#declare ht=35;
#declare dir=90;
#declare azi=0;
#declare camAng=40;
#break
#switch (view)
#range (0, 1)
camera
#if (ani=1)
sky <-1, 0, 0>
#else
sky surfPos
location camPos
look_at camLook
angle camAng
#range (2, 16)
camera
<sin(radians(-long))*cos(radians(lat)), sin(radians(lat)),
cos(radians(-long))*cos(radians(lat))>);
#if (vlength(surfPos)<5178*0.9897)
#declare surfPos = vnormalize(surfPos)*5178*0.9897; // camera
over lake
#declare camPos = surfPos+vnormalize(surfPos)*ht;
#declare dirVect = <sin(radians(dir))*cos(radians(azi)),
sin(radians(azi)), cos(radians(dir))*cos(radians(azi))>;
#declare camLook=camPos + vrotate(dirVect, <lat-90, -(long-180), 0>);
#declare camLook=vrotate(camLook, Rot_Ghurghusht);
#declare camPos =vrotate(camPos, Rot_Ghurghusht);
#declare camLook=camLook+Pos_Ghurghusht;
#declare camPos =camPos+Pos_Ghurghusht;
sky vrotate(surfPos, Rot_Ghurghusht)
location camPos
look_at camLook
angle camAng
#break
#case (17)
camera
#declare d=300000;
location d*<sin(radians(40.01)), 0, cos(radians(40.01))>
look_at 0
angle 100
#break
#declare v1=camPos-Pos_Ghurghusht;
#declare v2=Pos_Shams-Pos_Ghurghusht;
#declare phase_ang=vdot(camPos-Pos_Ghurghusht,
Pos_Shams-Pos_Ghurghusht)/(vlength(camPos-Pos_Ghurghusht)*vlength(Pos_Shams-Pos_Ghurghusht));
#declare phase_ang=acos(phase_ang)/(pi/180);
#warning str(phase_ang, 3, 2)
#if (!test)
sky_sphere // random starry sky, to be replaced later on with
astronomically accurate sky generated from Hipparcos star catalogue
#declare R1=seed(9843);
#declare i=0;
horizon
object
union
#while (i<50)
sphere
0, 0.001
#declare rn1=rand(R1)*360;
#declare rn2=asin(rand(R1)*2-1);
translate <sin(radians(rn1))*cos(rn2), sin(rn2),
cos(radians(rn1))*cos(rn2)>
#declare i=i+1;
color rgb 0,
#switch (phase_ang)
#range (0, 95)
color rgb 0
#break
#range (95, 98)
color rgb (1/3)*(phase_ang-95)
#break
#range (98, 180)
color rgb 1
#break
#declare i=0;
object
union
#while (i<150)
sphere
0, 0.00075
#declare i=i+1;
color rgbf 1,
#switch (phase_ang)
#range (0, 97)
color rgb 0
#break
#range (97, 100)
color rgb (1/3)*(phase_ang-97)
#break
#range (100, 180)
color rgb 1
#break
#declare i=0;
below horizon
object
union
#while (i<500)
sphere
0, 0.0006
#declare i=i+1;
color rgbf 1,
#switch (phase_ang)
#range (0, 100)
color rgb 0
#break
#range (100, 104)
color rgb (0.9/4)*(phase_ang-100)
#break
#range (104, 180)
color rgb 0.9
#break
#declare i=0;
object
union
#while (i<2000)
sphere
0, 0.0005
#declare i=i+1;
color rgbf 1,
#switch (phase_ang)
#range (0, 105)
color rgb 0
#break
#range (105, 110)
color rgb (0.7/5)*(phase_ang-105)
#break
#range (110, 180)
color rgb 1
#break
#else
#declare T_White =
texture
pigment { color rgb 1 }
#declare Grid_Bar_H =
box
0, <15, 1, 3>
texture { T_White }
#declare Grid_Bar_V =
object
Grid_Bar_H
rotate <0, -90, 0>
translate <2, 0, 0>
#declare Physical = array[26]
color rgb <0, 0, 0.2>,
color rgb <0, 0, 0.4>,
color rgb <0, 0, 0.7>,
color rgb <0, 0.15, 1>,
color rgb <0, 0.25, 1>,
color rgb <0, 0.5, 1>,
color rgb <0, 0.65, 1>,
color rgb <0, 1, 1>,
color rgb <0.4, 1, 1>,
color rgb <0.6, 1, 1>,
color rgb <0, 0.7, 0>,
color rgb <0, 1, 0>,
color rgb <1, 1, 0.5>,
color rgb <1, 1, 0>,
color rgb <1, 0.7, 0>,
color rgb <1, 0.6, 0>,
color rgb <1, 0.4, 0>,
color rgb <1, 0.2, 0>,
color rgb <1, 0, 0>,
color rgb 0.3,
color rgb 0.4,
color rgb 0.5,
color rgb 0.6,
color rgb 0.7,
color rgb 0.78,
color rgb 1
#declare Elevations = array [25]
{ "10000", "8000", "6000", "4000", "2000", "1000", "500", "200",
"100", "0", "100", "200", "500", "1000", "2000", "3000", "4000", "5000",
"6000", "7000", "8000", "10000", "12000", "15000", "20000" };
#declare lat_start=90-int(clock/360);
#declare long_start=mod(clock,360);
#declare res=900; // pixels per degree
#declare xdim=900;
#declare ydim=900;
#declare lat_end=lat_start-(ydim/res);
#declare long_end=long_start+(xdim/res);
#if (!legend)
#declare sl=5124.6666; // sea level
// #if (mapping=2) // elevation probing mode for grayscale maps
#declare min_file=0;
#declare max_file=0;
#fopen mm "minmax" read
#while (defined(mm))
#read (mm, min_file, max_file)
#fclose mm
#warning concat("min_file = ", str(min_file, 5, 4), " max_file =
", str(max_file, 5, 4))
#declare min_el=min_file;
#declare max_el=max_file;
// #end
#declare lat=lat_start;
#while (lat >= lat_end)
#declare long=long_start;
#while (long < long_end)
#declare el=vlength(trace(Ghurghusht, 0,
cos(radians(-long))*cos(radians(lat))>));
#if (greymap=0) // defining pixel colors for physical map
#switch(el-sl)
#range (-sl, -10)
#declare pc = Physical[0];
#break
#range (-10, -8)
#declare pc = Physical[1];
#break
#range (-8, -6)
#declare pc = Physical[2];
#break
#range (-6, -4)
#declare pc = Physical[3];
#break
#range (-4, -2)
#declare pc = Physical[4];
#break
#range (-2, -1)
#declare pc = Physical[5];
#break
#range (-1, -0.5)
#declare pc = Physical[6];
#break
#range (-0.5, -0.2)
#declare pc = Physical[7];
#break
#range (-0.2, -0.1)
#declare pc = Physical[8];
#break
#range (-0.1, 0)
#declare pc = Physical[9];
#break
#range (0, 0.1)
#declare pc = Physical[10];
#break
#range (0.1, 0.2)
#declare pc = Physical[11];
#break
#range (0.2, 0.5)
#declare pc = Physical[12];
#break
#range (0.5, 1)
#declare pc = Physical[13];
#break
#range (1, 2)
#declare pc = Physical[14];
#break
#range (2, 3)
#declare pc = Physical[15];
#break
#range (3, 4)
#declare pc = Physical[16];
#break
#range (4, 5)
#declare pc = Physical[17];
#break
#range (5, 6)
#declare pc = Physical[18];
#break
#range (6, 7)
#declare pc = Physical[19];
#break
#range (7, 8)
#declare pc = Physical[20];
#break
#range (8, 10)
#declare pc = Physical[21];
#break
#range (10, 12)
#declare pc = Physical[22];
#break
#range (12, 15)
#declare pc = Physical[23];
#break
#range (15, 20)
#declare pc = Physical[24];
#break
#range (20, 100)
#declare pc = Physical[25];
#break
#if ((el-sl)<min_el)
#declare min_el = el-sl;
#if ((el-sl)>max_el)
#declare max_el = el-sl;
#declare rng=max_el+abs(min_el);
#declare ll=sl-abs(min_el);
#declare grv=(el-ll)/rng;
#if (mapping != 2)
box
0, 1
texture
#switch (greymap)
#case (0) // physical map
pigment { color rgb <pc.red, pc.green, pc.blue> }
#break
#case (1) // 8-bit heightfield
pigment { color rgb <grv, grv, grv> }
#break
#case (2) // 16-bit heightfield
#declare rdraw = grv*255;
#declare rdval = int(rdraw);
#declare grraw = (rdraw-rdval)*255;
#declare grval = int(grraw);
pigment { color rgb <rdval, grval, 0>/255 }
#break
#case (3) // 24-bit heightfield
#declare blraw = (grraw-grval)*255;
#declare blval = int(blraw);
pigment { color rgb <rdval, grval, blval>/255 }
#break
translate <(long-long_start)*res, 0, 450-(lat_start-lat)*res>
#declare long=long+1/res;
#declare lat=lat-1/res;
// #if (mapping=2)
#warning concat("min_el = ", str(min_el, 5, 4), " max_el = ",
str(max_el, 5, 4))
#fopen mm "minmax" write
#write (mm, min_el, ",", max_el, "\n")
#fclose mm
// #end
#if(legend)
box // dummy map
<0, 0, -450>, <1800, 1, 450>
texture
pigment { color rgb <1, 0, 0> }
#if (greymap=0)
object { Grid_Bar_H translate <-15, 0, -450> } // lower left map
corner, latitude bar
object { Grid_Bar_H translate <-15, 0, 447> } // upper left map
object { Grid_Bar_H translate <1800, 0, -450> } // lower right map
object { Grid_Bar_H translate <1800, 0, 447> } // upper right map
object { Grid_Bar_V translate <1, 0, -465> } // lower left map
corner, longitude bar
object { Grid_Bar_V translate <1, 0, 450> } // upper left map
object { Grid_Bar_V translate <1798, 0, -465> } // lower right map
object { Grid_Bar_V translate <1798, 0, 450> } // upper right map
text
ttf concat(fontpath, "arial.ttf") str(lat_start, 2, 0), 1, 0
texture { T_White }
rotate <90, 0, 0>
scale 20
translate <-47, 0, 442.5>
text
ttf concat(fontpath, "arial.ttf") str(lat_end, 2, 0), 1, 0
texture { T_White }
rotate <90, 0, 0>
scale 20
translate <-47, 0, -455>
text
texture { T_White }
rotate <90, 0, 0>
scale 20
translate <1820, 0, 442.5>
text
texture { T_White }
rotate <90, 0, 0>
scale 20
translate <1820, 0, -455>
text
ttf concat(fontpath, "arial.ttf") str(long_end, 3, 0), 1, 0
texture { T_White }
rotate <90, 0, 0>
scale 20
translate <1785, 0, 470>
text
ttf concat(fontpath, "arial.ttf") str(long_start, 3, 0), 1, 0
texture { T_White }
rotate <90, 0, 0>
scale 20
translate <-15, 0, 470>
text
texture { T_White }
rotate <90, 0, 0>
scale 20
translate <1785, 0, -484>
text
texture { T_White }
rotate <90, 0, 0>
scale 20
translate <-15, 0, -484>
text
ttf concat(fontpath, "arial.ttf") concat("Cylindrical Map of
Ghurghusht - ", str(res, 3, 0), " pixels per degree"), 1, 0
texture
rotate x*90
scale 40
translate <430, 0, 515>
#declare Elevation_Color_Bar =
box
0, <40, 1, 20>
#declare a=0;
#while (a<26)
object
Elevation_Color_Bar
texture
pigment { color rgb <Physical[a].red, Physical[a].green,
Physical[a].blue> }
translate <40*a, 0, -525>
#declare a=a+1;
#declare a=0;
#while (a<25)
text
ttf concat(fontpath, "arial.ttf") Elevations[a] 1, 0
texture
rotate x*90
scale 10
#if (a=9)
#declare os=7.5;
#else
#declare os=6;
translate <5*(os+8*a), 0, -540>
#declare a=a+1;
text
ttf concat(fontpath, "arial.ttf") "Depths and elevations in
metres" 1, 0
texture
rotate x*90
scale 10
translate <1090, 0, -540>
camera
orthographic
#switch (greymap)
#case (0) // physical map with legend
right <1900, 0, 0>
up <0, 1100, 0 >
location <900, 500, 0>
look_at <900, 0, 0>
#break
#range (1, 2) // 8- and 16-bit heightfield, global coverage
right <1800, 0, 0>
up <0, 900, 0>
look_at <900, 0, 0>
#break
#case (3) // tiled 24-bit heightfields
right <900, 0, 0>
up <0, 900, 0>
location <450, 500, 0>
look_at <450, 0, 0>
#break
![](/i/fill.gif) |
