POV-Ray : Newsgroups : povray.binaries.images : Ghurghusht: artifacts at dawn Server Time
10 Apr 2026 23:48:10 EDT (-0400)
  Ghurghusht: artifacts at dawn (Message 1 to 10 of 40)
Subject: Ghurghusht: artifacts at dawn
Date: 9 Jun 2010 16:43:17
Message: <4c0ffce5@news.povray.org>
High!
Meanwhile, I managed to add a random starry sky_sphere based on the
object pattern to my Ghurghusht/DM +19 279 system project, with four
brightness classes of stars appearing at different angles of the sun (i.
e. DM +19 279, known also as Shams by the locals) below the horizon.
But I'm still not content with the appearance of the sky just before
sunrise/after sunset: instead of smooth brightness transitions, I get
patchy, streaky structures (see images attached here). Also, bright
spots show up on the hillsides long before the sun is close to the
horizon. And I wonder what makes the water (gleaned from Christoph
Hormann's pages) reflect a blue sky even when it should be as black as
pitch...
The "sun" positions are as follows (from first to last image):
79, 20, 16, 12, 8 and 4 degrees below the horizon
See you on www.khyberspace.de!
Yadgar
Now playing: Twilight (Vangelis) - how matching!
Download '2010-06-09 ghurghusht, schmidt lacus with sitara insula, sun 79 degrees below horizon, take 1.jpg' (24 KB) Download '2010-06-08 ghurghusht, schmidt lacus with sitara insula, sun 20 degrees below horizon, take 1.jpg' (25 KB) Download '2010-06-08 ghurghusht, schmidt lacus with sitara insula, sun 16 degrees below horizon, take 1.jpg' (25 KB) Download '2010-06-09 ghurghusht, schmidt lacus with sitara insula, sun 12 degrees below horizon, take 1.jpg' (24 KB) Download '2010-06-09 ghurghusht, schmidt lacus with sitara insula, sun 8 degrees below horizon, take 1.jpg' (27 KB) Download '2010-06-09 ghurghusht, schmidt lacus with sitara insula, sun 4 degrees below horizon, take 1.jpg' (41 KB)
Preview of image '2010-06-09 ghurghusht, schmidt lacus with sitara insula, sun 79 degrees below horizon, take 1.jpg'
Preview of image '2010-06-08 ghurghusht, schmidt lacus with sitara insula, sun 20 degrees below horizon, take 1.jpg'
Preview of image '2010-06-08 ghurghusht, schmidt lacus with sitara insula, sun 16 degrees below horizon, take 1.jpg'
Preview of image '2010-06-09 ghurghusht, schmidt lacus with sitara insula, sun 12 degrees below horizon, take 1.jpg'
Preview of image '2010-06-09 ghurghusht, schmidt lacus with sitara insula, sun 8 degrees below horizon, take 1.jpg'
Preview of image '2010-06-09 ghurghusht, schmidt lacus with sitara insula, sun 4 degrees below horizon, take 1.jpg'
Subject: Re: Ghurghusht: artifacts at dawn
Date: 9 Jun 2010 19:00:01
Message: <web.4c101c17db118a4ae69105fc0@news.povray.org>
=?ISO-8859-1?Q?J=F6rg_=27Yadgar=27_Bleimann?= <yaz### [at] gmxde> wrote:
> High!
> pitch...
> Yadgar
You didn't post the relevant code, but the water (and the land) looks like it
has a non-zero ambient setting, which will make it show up instead of being
black.  Perhaps I can be more helpful if you post the code for the water.
The bright speckles on the hills look like radiosity artifacts (leakage).  The
banding looks like media settings (too few samples).
-Reactor
Date: 9 Jun 2010 19:38:41
Message: <4c102601@news.povray.org>
High!
O.k., here it is:
// Media settings
global_settings
     #if (version < 3.7 & !mapping) assumed_gamma 1 #end
     max_trace_level 20
     #if (rds) radiosity { } #end
#declare TP_PLANET_RADIUS = 5124.6666;
#declare TP_BASE_RAYLEIGH_POWER = 6.7;  // Constant
#declare TP_RAYLEIGH_FACTOR = 0.35; // User defined
#declare _tp_rayleigh_power = TP_BASE_RAYLEIGH_POWER*TP_RAYLEIGH_FACTOR;
#declare TP_ATMO_THICKNESS = 100; // original value: 50
#declare TP_RAYLEIGH_DENSITY_MAX = 0.15; // original value: 1
#declare TP_RAYLEIGH_AMOUNT = 2.3;
#declare _tp_rayleigh_density = density
     function
TP_RAYLEIGH_DENSITY_MAX*exp(-_tp_rayleigh_power*(sqrt(x*x+(y+TP_PLANET_RADIUS)*(y+TP_PLANET_RADIUS)+z*z)
- TP_PLANET_RADIUS)/TP_ATMO_THICKNESS)
#declare TP_RAYLEIGH_SCATTERING_COLOR = rgb <0.135, 0.33, 1>;
#declare TP_ATMO_INTERVALS = 3; // Necessary for good integration
#declare TP_ATMO_SAMPLES = 10;
#declare TP_ATMO_METHOD = 3; // Adaptive
#declare TP_ATMO_BOTTOM = 0;
#declare _tp_rayleigh_media =
media
   method TP_ATMO_METHOD
   intervals TP_ATMO_INTERVALS
   samples TP_ATMO_SAMPLES
   scattering
     4, TP_RAYLEIGH_AMOUNT*TP_RAYLEIGH_SCATTERING_COLOR/TP_ATMO_THICKNESS
     extinction 1
   density
#declare _tp_rayleigh_atmosphere = difference
     sphere {0, TP_PLANET_RADIUS + TP_ATMO_BOTTOM + TP_ATMO_THICKNESS
translate -TP_PLANET_RADIUS*y}
     sphere {0, TP_PLANET_RADIUS + TP_ATMO_BOTTOM translate
     hollow
     pigment {rgbt 1}
     interior {media{_tp_rayleigh_media}}
     translate TP_PLANET_RADIUS*y
// Water
	  sphere
	    0, 1
	    material {
		  color rgbt <1, 1, 1, 1>
		finish {
		  diffuse 0 // no ambient set at all! Defaults?
		  reflection {
		    <0.03, 0.03, 0.04>, <0.75, 0.75, 1>
		    exponent 1.2
		    falloff 5
		    fresnel on
		  phong 1
		  phong_size 2500000
		normal
		  bozo 1.5
		  bump_size 0.5
		  scale 0.00000013
	      interior {
		ior 1.34
// Land
#declare T_Ghurghusht=
texture
   pigment { color rgb <0.98, 0.85, 0.45> }
   finish { ambient 0.003 diffuse 1 brilliance 0.98 }
The land is probably visible only because of the low assumed_gamma (1.0)...
I don't use any radiosity in this scene!
> The
Doubtful... I increased the samples from 3 to 10 (it now takes ages to
render), but the transition is still banded!
See you in Khyberspace!
Yadgar
Date: 9 Jun 2010 20:10:51
Message: <4c102d8b$1@news.povray.org>
>> The
What settings do you use for media sampling (method, and possibly
variance & confidence or aa_level && aa_threshold and/or jitter)?
adc_bailout might also be a candidate cause for the effect; try reducing
it - with proper gamma handling, the default can be too low in dark areas.
Date: 9 Jun 2010 20:42:02
Message: <4c1034da$1@news.povray.org>
High!
3
> and possibly
Default values
No anti-aliasing
> and/or jitter)?
No jitter
Probably not - I decreased it from the default 1/255 down to 0.001, the
early dawn sky is still "raggedly" banded (if you can conceive what I
mean), and also the odd bright spots on some slopes (preferably in the
more distant background) still occur!
Yadgar
Date: 9 Jun 2010 22:50:01
Message: <web.4c1051aadb118a4acba3fb0f0@news.povray.org>
Always good music!
Why not post the entire scene code? I'm not very experienced with media, but the
bright spots on the hills are very interesting. I will try to help you if I can.
Dave Blandston
Date: 9 Jun 2010 23:26:41
Message: <4c105b71@news.povray.org>
High!
> Always good music!
And I thought you were a metalhead... I'm quite amazed!
O.k., but beware, its VERY long - some 1500 lines!
// Ghurghusht and the Shams System
// Credits:
// Atmosphere: Bruno Cabasson
// Water: Christoph Hormann
#include "functions.inc"
#declare ani=0; // animation flag (if mapping = 0)
#declare mapping=0; // toggles generating a cylindrical map of Ghurghusht
#declare greymap=3; // 0 = physical map, 1 = 8-bit grayscale map, 2 =
16-bit grayscale map, 3 = 24-bit map
#declare legend=0; // toggles rendering map legend only (if mapping != 0)
#declare ridges=2; // switches between various patterns for isosurface
#declare os=1; // operating system: 0 = Linux, 1 = Windows
#declare tcm=0; // terrain calculation mode: 0 = isosurface, 1 = mesh2
#declare test=0; // 0 = full globe, 1 = lake around Sitara Insula only
#declare rds=0; // radiosity switch
#if (ani=1)
   #declare mapping=0;
#if (mapping)
   #declare rds=0;
#if (mapping=2)
   #declare greymap=1;
// Positions of planets and moons
// Column 0: orbital semi-major axis (to Shams or the respective planet)
in kilometres
// Column 1: radius in x dimension, in kilometres
// Column 2: radius in y dimension, in kilometres (if oblateness is
given then stated as -1)
// Column 3: radius in z dimension, in kilometres (if oblateness is
// Column 4: axial tilt in degrees (planets: relative to orbit around
Shams, moons: relative to planet's equatorial plane)
// Column 5: orbital inclination in degrees (planets: relative to
ecliptic, moons: relative to planet's equatorial plane)
// Column 6: orbital eccentricity
// Column 7: perihelion argument (degrees; if variable then stated als -1)
// Column 8: longitude of ascending node (degrees; if variable then
stated als -1)
// Column 9: oblateness (not taken into account if different radii
explicitly stated)
// Column 10: declination of north pole (degrees)
// Column 11: right ascension of north pole (degrees!)
// Column 12: albedo (if irrelevant (Shams) stated as -1)
// begin modifications according to Bruno Cabasson's TerraPOV tutorial
(2009)
global_settings
       assumed_gamma 1
       adc_bailout 0.001
     max_trace_level 20
     function
#declare TP_ATMO_SAMPLES = 3;
media
   scattering
     extinction 1
   density
     hollow
     pigment {rgbt 1}
// end modifications according to Bruno Cabasson's TerraPOV tutorial (2009)
#if (os=0)
   #declare fontpath="/media/disk1part9/fonts/";
#else
   #declare fontpath="D:/WINDOWS/Fonts/";
#declare S =
function { x*x + y*y + z*z -1 }
#declare Terrain_Part1_Function=
function
   pattern
     granite
     scale 10
     poly_wave 0.333
#declare Terrain_Part2_Function=
function
   pattern
     bozo
#declare Terrain_Part3_Function=
function
   pattern
     ripples
     scale 10
     turbulence 0.5
#declare P_Average =
pigment
   average
   pigment_map
     [0.5 granite scale 10 poly_wave 0.333 ]
     [1 spherical scale 10 turbulence 0.5 poly_wave 0.333 ]
     [0.025 crackle scale 0.2 turbulence 1 ]
#declare Terrain_Part4_Function=
function
   pigment { P_Average }
#switch (ridges)
   #case (0)
     #declare Terrain_Function=
     function { S(x, y, z) + Terrain_Part1_Function (x*50, y*50,
z*50)*0.02 + Terrain_Part2_Function (x, y, z)*0.01 }
   #break
   #case (1)
     function { S(x, y, z) + Terrain_Part3_Function (x*50, y*50, z*50)*0.05
   #break
   #case (2)
     function { S(x, y, z) + Terrain_Part4_Function (x*50, y*50,
z*50).gray*0.05
   #break
#if (!mapping)
   #declare R1=seed(1747);
   #declare R2=seed(1969);
   union
     sphere // Qais
       0, 1
       texture
	pigment
	  gradient y
	  color_map
	    [0      rgb 1]
	    [0.027  rgb 1]
	    [0.0274 rgb 0.85]
	    [0.0304 rgb 0.85]
	    [0.0324  rgb 1]
	    [0.0329  rgb 1]
	    [0.0411 rgb 0.6]
	    [0.0418 rgb 0.6]
	    [0.0429 rgb 1]
	    [0.0708  rgb 1]
	    [0.0712 rgb 0.96]
	    [0.0731 rgb 0.96]
	    [0.0742  rgb 1]
	    [0.0776 rgb <0.8, 0.9, 1>]
	    [0.0783 rgb <0.8, 0.9, 1>]
	    [0.079 rgb 1]
	    [0.0845 rgb 1]
	    [0.0848 rgb <0.66, 0.85, 1>]
	    [0.0976 rgb <0.66, 0.85, 1>]
	    [0.0987 rgb 1]
	    [0.1102 rgb 1]
	    [0.1108 rgb 0.88]
	    [0.1128 rgb 0.88]
	    [0.1132 rgb 1]
	    [0.1339 rgb 1]
	    [0.1452 rgb <0.56, 0.76, 1>]
	    [0.1501 rgb <0.56, 0.76, 1>]
	    [0.1537 rgb 1]
	    [0.1639 rgb 1]
	    [0.1646 rgb 0.91]
	    [0.1692 rgb 0.91]
	    [0.1784 rgb 1]
	    [0.1987 rgb 1]
	    [0.1999 rgb <0.3, 0.7, 1>]
	    [0.2473 rgb <0.3, 0.7, 1>]
	    [0.2478 rgb 1]
	    [0.2538 rgb 1]
	    [0.2541 rgb <0.17, 0.53, 1>]
	    [0.2798 rgb <0.17, 0.53, 1>]
	    [0.2901 rgb 1]
	    [0.2976 rgb 1]
	    [0.2995 rgb <0.04, 0.45, 1>]
	    [0.3524 rgb <0, 0.3, 1>]
	    [0.4634 rgb <0, 0, 0.95>]
	    [0.4982 rgb <0.2, 0.59, 1>]
	    [0.5052 rgb <0.12, 0.56, 1>]
	    [0.5475 rgb <0, 0, 0.97>]
	    [0.6789 rgb <0.06, 0.47, 1>]
	    [0.6967 rgb <0.3, 0.8, 1>]
	    [0.6978 rgb 0.35]
	    [0.7032 rgb 0.35]
	    [0.7035 rgb 0.86]
	    [0.7472 rgb 0.89]
	    [0.7498 rgb <0.42, 0.86, 1>]
	    [0.7767 rgb <0.42, 0.86, 1>]
	    [0.7782 rgb 0.93]
	    [0.8245 rgb 0.93]
	    [0.8261 rgb <0.45, 0.89, 1>]
	    [0.8673 rgb <0.45, 0.89, 1>]
	    [0.8702 rgb 0.75]
	    [0.8712 rgb 0.75]
	    [0.8713 rgb 0.43]
	    [0.8756 rgb 0.43]
	    [0.876  rgb 1]
	    [0.8903 rgb 1]
	    [0.8916 rgb 0.68]
	    [0.8923 rgb 0.68]
	    [0.8928 rgb 1]
	    [0.9139 rgb 1]
	    [0.9142 rgb 0.53]
	    [0.9187 rgb 0.53]
	    [0.9193 rgb 1]
	    [0.9372 rgb 1]
	    [0.9398 rgb 0.48]
	    [0.9508 rgb 0.48]
	    [0.9682 rgb 1]
	    [1      rgb 1]
           turbulence 0.02
           scale 2
           translate y
	finish { ambient 0.0005 diffuse 1 brilliance 0.4 }
     difference
       cylinder
	<0, -0.002, 0>, <0, 0.002, 0>, 2.4
       cylinder
	<0, -0.0021, 0>, <0, 0.0021, 0>, 1.5
       double_illuminate
       texture
	pigment
	  cylindrical
	  color_map
	    [0 rgbf <1, 0.97, 0.985, 0.6>]
	    [0.0092 rgbf <1, 0.97, 0.985, 0.6>]
	    [0.0092 rgbf <0.65, 0.62, 0.47, 0.14>]
	    [0.0107 rgbf <0.65, 0.62, 0.47, 0.14>]
	    [0.0107 rgbf <1, 0.97, 0.985, 0.6>]
	    [0.0127 rgbf <1, 0.97, 0.985, 0.6>]
	    [0.0127 rgbf <0.75, 0.696, 0.672, 0.36>]
	    [0.0141 rgbf <0.75, 0.696, 0.672, 0.36>]
	    [0.0141 rgbf <1, 0.97, 0.985, 0.6>]
	    [0.0184 rgbf <1, 0.97, 0.985, 0.6>]
	    [0.0184 rgbf <1, 1, 1, 0.6>]
	    [0.0205 rgbf <1, 1, 1, 0.6>]
	    [0.0205 rgbf <1, 0.97, 0.985, 0.6>]
	    [0.0321 rgbf <1, 0.97, 0.985, 0.6>]
	    [0.0321 rgbf <0.89, 0.87, 0.834, 0.64>]
	    [0.0373 rgbf <0.89, 0.87, 0.834, 0.64>]
	    [0.0373 rgbf <1, 0.97, 0.985, 0.6>]
	    [0.0452 rgbf <1, 0.97, 0.985, 0.6>]
	    [0.0452 rgbf <0.98, 0.95, 0.81, 0.43>]
	    [0.0487 rgbf <0.98, 0.95, 0.81, 0.43>]
	    [0.0487 rgbf <1, 0.97, 0.985, 0.6>]
	    [0.0532 rgb <1, 0.97, 0.985, 0.6>]
	    [0.0532 rgb <0.97, 0.925, 0.896, 0.51>]
	    [0.0575 rgb <0.97, 0.925, 0.896, 0.51>]
	    [0.0575 rgbf <0.683, 0.5904, 0.2164, 0.8>]
	    [0.0603 rgbf <0.683, 0.5904, 0.2164, 0.8>]
	    [0.0603 rgbf <1, 0.963, 0.888, 0.534>]
	    [0.0651 rgbf <1, 0.963, 0.888, 0.534>]
	    [0.0651 rgbf <0.742, 0.7195, 0.6721, 0.248>]
	    [0.0675 rgbf <0.742, 0.7195, 0.6721, 0.248>]
	    [0.0675 rgbf <0.721, 0.612, 0.5139, 0.557>]
	    [0.0692 rgbf <0.721, 0.612, 0.5139, 0.557>]
	    [0.0692 rgbf <0.965, 0.948, 0.8123, 0.092>]
	    [0.0732 rgbf <0.965, 0.948, 0.8123, 0.092>]
	    [0.0732 rgbf <0.7921, 0.78231, 0.6231, 0.47>]
       [0.0762 rgbf <0.7921, 0.78231, 0.6231, 0.47>]
       [0.0762 rgbf <0.7812, 0.7526, 0.5931, 0.53>]
       [0.0804 rgbf <0.7812, 0.7526, 0.5931, 0.53>]
       [0.0804 rgbf <0.7415, 0.7126, 0.6312, 0.12>]
       [0.0829 rgbf <0.7415, 0.7126, 0.6312, 0.12>]
       [0.0829 rgbf <0.6712, 0.6623, 0.4894, 0.73>]
       [0.0853 rgbf <0.6712, 0.6623, 0.4894, 0.73>]
       [0.0853 rgbf <0.5921, 0.5823, 0.5561, 0.376>]
       [0.0881 rgbf <0.5921, 0.5823, 0.5561, 0.376>]
       [0.0881 rgbf <0.3126, 0.2531, 0.0037, 0.621>]
       [0.09 rgbf <0.3126, 0.2531, 0.0037, 0.621>]
	    [0.09 rgbf <1, 0.97, 0.985, 0.6>]
	    [0.09 rgbf <0.2, 0.14, 0.04, 0.045>]
	    [0.1023 rgbf <0.2, 0.14, 0.04, 0.045>]
	    [0.1023 rgbf <1, 0.95, 0.94, 0.5>]
	    [0.1065 rgbf <1, 0.95, 0.94, 0.5>]
	    [0.1065 rgbf <0.45, 0.38, 0.29, 0.19>]
	    [0.1083 rgbf <0.45, 0.38, 0.29, 0.19>]
	    [0.1083 rgbf <0.93, 0.85, 0.81, 0.55>]
	    [0.1102 rgbf <0.93, 0.85, 0.81, 0.55>]
	    [0.1102 rgbf <0.74, 0.61, 0.46, 0.21>]
	    [0.1108 rgbf <0.74, 0.61, 0.46, 0.21>]
	    [0.1108 rgbf <0.51, 0.457, 0.219, 0.77>]
	    [0.1134 rgbf <0.51, 0.457, 0.219, 0.77>]
	    [0.1134 rgbf <0.49, 0.416, 0.193, 0.92>]
	    [0.1156 rgbf <0.49, 0.416, 0.193, 0.92>]
	    [0.1156 rgbf <0.692, 0.623, 0.523, 0.14>]
	    [0.1181 rgbf <0.692, 0.623, 0.523, 0.14>]
	    [0.1181 rgbf <0.815, 0.761, 0.4134, 0.69>]
	    [0.1197 rgbf <0.815, 0.761, 0.4134, 0.69>]
	    [0.1197 rgbf <0.512, 0.412, 0.3218, 0.92>]
	    [0.1215 rgbf <0.512, 0.412, 0.3218, 0.92>]
	    [0.1215 rgbf <0.478, 0.423, 0.2951, 0.85>]
	    [0.1228 rgbf <0.478, 0.423, 0.2951, 0.85>]
	    [0.1228 rgbf <0.1946, 0.1725, 0.0842, 0.94>]
	    [0.1251 rgbf <0.1946, 0.1725, 0.0842, 0.94>]
	    [0.1251 rgbf <0.8153, 0.7841, 0.7522, 0.25>]
	    [0.1275 rgbf <0.8153, 0.7841, 0.7522, 0.25>]
	    [0.1275 rgbf <0.5278, 0.5005, 0.3928, 0.68>]
	    [0.1299 rgbf <0.5278, 0.5005, 0.3928, 0.68>]
	    [0.1299 rgbf <0.8039, 0.7869, 0.7521, 0.29>]
	    [0.1327 rgbf <0.8039, 0.7869, 0.7521, 0.29>]
	    [0.1327 rgbf <0.5732, 0.5412, 0.3412, 0.67>]
	    [0.1339 rgbf <0.5732, 0.5412, 0.3412, 0.67>]
	    [0.1339 rgbf <0.951, 0.9082, 0.8312, 0.2209>]
	    [0.1374 rgbf <0.951, 0.9082, 0.8312, 0.2209>]
	    [0.1374 rgbf <0.6731, 0.6233, 0.4678, 0.4761>]
	    [0.14 rgbf <0.6731, 0.6233, 0.4678, 0.4761>]
	    [0.14 rgbf <0.8592, 0.8492, 0.5782, 0.2375>]
	    [0.1415 rgbf <0.8592, 0.8492, 0.5782, 0.2375>]
	    [0.1415 rgbf <0.7572, 0.6531, 0.5905, 0.4231>]
	    [0.1447 rgbf <0.7572, 0.6531, 0.5905, 0.4231>]
	    [0.1447 rgbf <0.4824, 0.4245, 0.3126, 0.8634>]
	    [0.1476 rgbf <0.4824, 0.4245, 0.3126, 0.8634>]
	    [0.1476 rgbf <0.5123, 0.4563, 0.2195, 0.7361>]
	    [0.1503 rgbf <0.5123, 0.4563, 0.2195, 0.7361>]
	    [0.1503 rgbf <0.3735, 0.3129, 0.1938, 0.0412>]
	    [0.1523 rgbf <0.3735, 0.3129, 0.1938, 0.0412>]
	    [0.1523 rgbf <0.4123, 0.3563, 0.2453, 0.0932>]
	    [0.1547 rgbf <0.4123, 0.3563, 0.2453, 0.0932>]
	    [0.1547 rgbf <0.4593, 0.4126, 0.2231, 0.4231>]
	    [0.1601 rgbf <0.4593, 0.4126, 0.2231, 0.4231>]
	    [0.1601 rgbf <0.4003, 0.3521, 0.1963, 0.0214>]
	    [0.1634 rgbf <0.4003, 0.3521, 0.1963, 0.0214>]
	    [0.1651 rgbf <0.4003, 0.3521, 0.1963, 0.0214>]
	    [0.1651 rgbf <0.5124, 0.4751, 0.2768, 0.2544>]
	    [0.1678 rgbf <0.5124, 0.4751, 0.2768, 0.2544>]
	    [0.1678 rgbf <0.5069, 0.4457, 0.2989, 0.3444>]
	    [0.1695 rgbf <0.5069, 0.4457, 0.2989, 0.3444>]
	    [0.1695 rgbf <0.5241, 0.4321, 0.1295, 0.9542>]
	    [0.1732 rgbf <0.5241, 0.4321, 0.1295, 0.9542>]
	    [0.1732 rgbf <0.4721, 0.4109, 0.1758, 0.4682>]
	    [0.176 rgbf <0.4721, 0.4109, 0.1758, 0.4682>]
	    [0.176 rgbf <0.4832, 0.4201, 0.2254, 0.2156>]
	    [0.1776 rgbf <0.4832, 0.4201, 0.2254, 0.2156>]
	    [0.1776 rgbf <0.4369, 0.3974, 0.2405, 0.1198>]
	    [0.1805 rgbf <0.4369, 0.3974, 0.2405, 0.1198>]
	    [0.1805 rgbf <0.5823, 0.5172, 0.4423, 0.5768>]
	    [0.1828 rgbf <0.5823, 0.5172, 0.4423, 0.5768>]
	    [0.1828 rgbf <0.5492, 0.5047, 0.4782, 0.315>]
	    [0.1857 rgbf <0.5492, 0.5047, 0.4782, 0.315>]
	    [0.1857 rgbf <0.5392, 0.4902, 0.4248, 0.229>]
	    [0.1891 rgbf <0.5392, 0.4902, 0.4248, 0.229>]
	    [0.1891 rgbf <0.5205, 0.4721, 0.4004, 0.311>]
	    [0.1916 rgbf <0.5205, 0.4721, 0.4004, 0.311>]
	    [0.1916 rgbf <0.5085, 0.4631, 0.3815, 0.782>]
	    [0.197 rgbf <0.5085, 0.4631, 0.3815, 0.782>]
	    [0.197 rgbf <0.4581, 0.413, 0.3241, 0.762>]
	    [0.1994 rgbf <0.4581, 0.413, 0.3241, 0.762>]
	    [0.1994 rgbf <0.4329, 0.3571, 0.2554, 0.1563>]
	    [0.2041 rgbf <0.4329, 0.3571, 0.2554, 0.1563>]
	    [0.2041 rgbf <0.4003, 0.32, 0.2136, 0.537>]
	    [0.2067 rgbf <0.4003, 0.32, 0.2136, 0.537>]
	    [0.2067 rgbf <0.4153, 0.3041, 0.1942, 0.3478>]
	    [0.2089 rgbf <0.4153, 0.3041, 0.1942, 0.3478>]
	    [0.2089 rgbf <0.3999, 0.3128, 0.1911, 0.3237>]
	    [0.2112 rgbf <0.3999, 0.3128, 0.1911, 0.3237>]
	    [0.2112 rgbf <0.3745, 0.2984, 0.1736, 0.5123>]
	    [0.2137 rgbf <0.3745, 0.2984, 0.1736, 0.5123>]
	    [0.2137 rgbf <0.3763, 0.2742, 0.1836, 0.221>]
	    [0.2154 rgbf <0.3763, 0.2742, 0.1836, 0.221>]
	    [0.2154 rgbf <0.3423, 0.2532, 0.1325, 0.198>]
	    [0.2181 rgbf <0.3423, 0.2532, 0.1325, 0.198>]
	    [0.2181 rgbf <0.3321, 0.2409, 0.1452, 0.209>]
	    [0.22 rgbf <0.3321, 0.2409, 0.1452, 0.209>]
	    [0.22 rgbf <0.11, 0.045, 0.001, 1>]
	    [0.2223 rgbf <0.11, 0.045, 0.001, 1>]
	    [0.2223 rgbf <0.3163, 0.2376, 0.1508, 0.2842>]
	    [0.2246 rgbf <0.3163, 0.2376, 0.1508, 0.2842>]
	    [0.2246 rgbf <0.3004, 0.2153, 0.1276, 0.3412>]
	    [0.2275 rgbf <0.3004, 0.2153, 0.1276, 0.3412>]
	    [0.2275 rgbf <0.2987, 0.2204, 0.1264, 0.3934>]
	    [0.23 rgbf <0.2987, 0.2204, 0.1264, 0.3934>]
	    [0.23 rgbf <0.2835, 0.2175, 0.1003, 0.2145>]
	    [0.2331 rgbf <0.2835, 0.2175, 0.1003, 0.2145>]
	    [0.2331 rgbf <0.2809, 0.1984, 0.0921, 0.3674>]
	    [0.2367 rgbf <0.2809, 0.1984, 0.0921, 0.3674>]
	    [0.2367 rgbf <0.279, 0.1912, 0.0909, 0.4582>]
	    [0.2389 rgbf <0.279, 0.1912, 0.0909, 0.4582>]
	    [0.2389 rgbf <0.2659, 0.1738, 0.1184, 0.44>]
	    [0.2406 rgbf <0.2659, 0.1738, 0.1184, 0.44>]
	    [0.2406 rgbf <0.2711, 0.166, 0.1053, 0.5693>]
	    [0.2437 rgbf <0.2711, 0.166, 0.1053, 0.5693>]
	    [0.2437 rgbf <0.2523, 0.123, 0.0934, 0.5552>]
	    [0.2459 rgbf <0.2523, 0.123, 0.0934, 0.5552>]
	    [0.2459 rgbf <0.2401, 0.1264, 0.0894, 0.126>]
	    [0.2483 rgbf <0.2401, 0.1264, 0.0894, 0.126>]
	    [0.291 rgbf <0.09, 0.035, 0.001, 1>]
	    [0.294 rgb <0.98, 0.94, 0.97, 0.2>]
	    [0.296 rgbf <0.09, 0.035, 0.001, 1>]
	    [0.3289 rgbf <0.092, 0.032, 0.002, 1>]
	    [0.3293 rgbf <0.78, 0.71, 0.21, 0.3>]
	    [0.3299 rgbf <0.78, 0.71, 0.21, 0.3>]
	    [0.3301 rgbf <0.089, 0.029, 0.0017, 0.99>]
	    [0.3325 rgbf <0.089, 0.029, 0.0017, 0.99>]
	    [0.3325 rgbf <0.34, 0.29, 0.007, 0.32>]
	    [0.3333 rgbf <0.34, 0.29, 0.007, 0.32>]
	    [0.3333 rgbf <0.09, 0.027, 0.0015, 0.84>]
	    [0.3357 rgbf <0.09, 0.027, 0.0015, 0.84>]
	    [0.3357 rgbf <0.37, 0.29, 0.013, 0.54>]
	    [0.3364 rgbf <0.37, 0.29, 0.013, 0.54>]
	    [0.3365 rgbf <0.09, 0.027, 0.0015, 0.84>]
	    [0.3397 rgbf <0.09, 0.027, 0.0015, 0.84>]
	    [0.34   rgbf <0.54, 0.49, 0.09, 0.23>]
	    [0.3412  rgbf <0.53, 0.497, 0.085, 0.25>]
	    [0.3415 rgbf <0.09, 0.027, 0.0015, 0.84>]
	    [0.3421 rgbf <0.09, 0.027, 0.0015, 0.84>]
	    [0.3421 rgbf <0.1034, 0.0256, 0.008, 0.87>]
	    [0.3438 rgbf <0.1034, 0.0256, 0.008, 0.87>]
	    [0.3438 rgbf <0.126, 0.0463, 0.0042, 0.912>]
	    [0.3449 rgbf <0.126, 0.0463, 0.0042, 0.912>]
	    [0.3449 rgbf <0.115, 0.0408, 0.0052, 0.905>]
	    [0.3465 rgbf <0.115, 0.0408, 0.0052, 0.905>]
	    [0.3465 rgbf <0.105, 0.0467, 0.0053, 0.942>]
	    [0.3479 rgbf <0.105, 0.0467, 0.0053, 0.942>]
       [0.3479 rgbf <0.109, 0.0504, 0.0023, 0.921>]
       [0.3482 rgbf <0.109, 0.0504, 0.0023, 0.921>]
	    [0.3482 rgbf <0.116, 0.0532, 0.0038, 0.829>]
	    [0.3509 rgbf <0.116, 0.0532, 0.0038, 0.829>]
	    [0.3509 rgbf <0.1362, 0.07631, 0.0091, 0.821>]
	    [0.3521 rgbf <0.1362, 0.07631, 0.0091, 0.821>]
	    [0.3521 rgbf <0.0921, 0.0683, 0.0073, 0.859>]
	    [0.3529 rgbf <0.0921, 0.0683, 0.0073, 0.859>]
	    [0.3529 rgbf <0.1582, 0.0921, 0.0089, 0.912>]
	    [0.3576 rgbf <0.1582, 0.0921, 0.0089, 0.912>]
	    [0.3576 rgbf <0.1542, 0.0931, 0.0082, 0.921>]
	    [0.3592 rgbf <0.1542, 0.0931, 0.0082, 0.921>]
	    [0.3592 rgbf <0.1321, 0.1021, 0.0079, 0.949>]
	    [0.3607 rgbf <0.1321, 0.1021, 0.0079, 0.949>]
	    [0.3607 rgbf <0.1129, 0.0929, 0.0081, 0.841>]
	    [0.3613 rgbf <0.1129, 0.0929, 0.0081, 0.841>]
	    [0.3613 rgbf <0.1031, 0.0842, 0.0072, 0.846>]
	    [0.3628 rgbf <0.1031, 0.0842, 0.0072, 0.846>]
	    [0.3628 rgbf <0.0953, 0.0472, 0.0074, 0.869>]
	    [0.3648 rgbf <0.0953, 0.0472, 0.0074, 0.869>]
	    [0.3648 rgbf <0.0973, 0.0381, 0.0037, 0.563>]
	    [0.3657 rgbf <0.0973, 0.0381, 0.0037, 0.563>]
	    [0.3657 rgbf <0.0982, 0.0429, 0.0053, 0.583>]
	    [0.3682 rgbf <0.0982, 0.0429, 0.0053, 0.583>]
	    [0.3682 rgbf <0.4721, 0.4127, 0.0153, 0.109>]
	    [0.3705 rgbf <0.4721, 0.4127, 0.0153, 0.109>]
	    [0.3705 rgbf <0.1023, 0.0357, 0.0003, 0.984>]
	  scale 2.4
	finish { ambient 0.05 diffuse 1 brilliance 0.2 }
     scale <63879, 58782, 63879>
     rotate <-8.6, 0, 27.7>
  #if (!ani)
     #declare Pos_Ghurghusht = 3961542  * <sin(radians(270)), 0,
cos(radians(270))>;
     #declare Rot_Ghurghusht = <0, 153, 0>;
   #else
     #declare Pos_Ghurghusht = 3961542  * <sin(radians(50)), 0,
cos(radians(50))>;
   #declare Pos_Shams = <-104720000, 0, 0>;
   light_source  // Shams
     Pos_Shams
     color rgb <1, 1, 0.95>
   sphere
     (Pos_Shams-Pos_Ghurghusht)/100, 6230
     texture
       pigment { color rgb <1, 1, 0.95> }
       finish { ambient 1 diffuse 0 }
     no_shadow
texture
#if (tcm=0)
   #declare Ghurghusht =
     isosurface
       function { Terrain_Function(x, y, z) }
       contained_by { sphere { 0, 1 } }
       max_gradient 5
       accuracy 0.0001
       double_illuminate
       texture { T_Ghurghusht }
       scale 5178
#else
   #declare hf=
   pigment
     image_map
       png "tiles/ghurghusht360_n05_040.png"
   #declare sl=5124.6666;
   #declare rng=31.5519+6.2452;
   #declare ll=sl-6.2452;
   #declare long=40;
   #declare lat=5;
   mesh2
     vertex_vectors
       1440000 // 1200 * 1200
       #declare a=0;
       #while (a<1200)
	#declare b=0;
	#while (b<1200)
	  #declare rd=eval_pigment(hf, <1/2400+b/1200, 2399/2400-a/1200, 0>).red;
	  #declare gr=eval_pigment(hf, <1/2400+b/1200, 2399/2400-a/1200,
0>).green/256;
	  #declare bl=eval_pigment(hf, <1/2400+b/1200, 2399/2400-a/1200,
0>).blue/65536;
(ll+(rd+gr+bl)*rng)*<sin(radians(-long-(10/3)*(1/2400+b/1200)))*cos(radians(lat-(10/3)*(1/2400+a/1200))),
sin(radians(lat-(10/3)*(1/2400+a/1200))),
cos(radians(-long-(10/3)*(1/2400+b/1200)))*cos(radians(lat-(10/3)*(1/2400+a/1200)))>
	  #declare b=b+1;
	// #warning concat("Assigning vectors for line ", str(a, 4, 0))
	#declare a=a+1;
     face_indices
       2875202 // 1199 * 1199 * 2
       #declare a = 0;
       #while (a < 1199)
	#declare b = 0;
	#while (b < 1199)
	  <1200*a + b, 1200*a + b+1, 1200*(a+1) + b>,
	  <1200*a + b+1, 1200*(a+1) + b+1, 1200*(a+1) + b>
	  #if(b<(l-2))
	  #declare b = b+1;
	#warning concat("Parsing lines ", str(a, 4, 0), " and ", str(a+1, 4,
0),".")
	#declare a = a+1;
#if (!mapping)
   #declare Box_Cutout =
   box
     <-1, -10, -1>, <1, 30, 1>
     #declare surfPos = trace(Ghurghusht, 0,
<sin(radians(-140.5905556))*cos(radians(0.368888888)),
sin(radians(0.368888888)),
cos(radians(-140.5905556))*cos(radians(0.368888888))>);
     rotate <0, 0, 90-0.368888888>
     rotate <0, -50.5905556, 0>
     translate surfPos
   union
     #if (test = 1)
       intersection
	union
	  object { Ghurghusht }
	  sphere
	    0, 1
	    material {
		finish {
		  diffuse 0
		  reflection {
		    exponent 1.2
		    falloff 5
		    fresnel on
		  phong 1
		  phong_size 2500000
		normal
		  bozo 1.5
		  bump_size 0.5
		  scale 0.00000013
	      interior {
		ior 1.34
	    scale 5178*0.9897 // sea level at 5124.6666 kms
	  sphere
	    0, 1
	    hollow
	    texture
	      pigment { color rgb <0, 0, 0.5> }
	      finish { ambient 0.05 diffuse 1 brilliance 1 }
	    scale 5178*0.98969999 // preliminary sea floor at 5124.666548 kms
     #if (test = 1)
	object { Box_Cutout }
	bounded_by { object { Box_Cutout } }
     #if (test = 0)
       object { _tp_rayleigh_atmosphere }
     #if (ani=1)
       rotate y*(clock/10)
     rotate Rot_Ghurghusht
     translate Pos_Ghurghusht
   #if (test = 1)
     sky_sphere
       pigment
	gradient y
	color_map
	  [0 rgb <0.8, 1, 1>]
	  [0.15 rgb <0, 0.7, 1>]
	  [0.3 rgb <0, 0.3, 1>]
	  [1   rgb <0, 0.3, 1>]
   #declare view=12;
   #if (test=1)
     #declare view=12;
   #switch (view)
     #case (0)
       #declare camPos=Pos_Ghurghusht + 20000 * <sin(radians(300)), 0,
cos(radians(300))>;
       #declare camLook=Pos_Ghurghusht-<7200, 0, 0>;
       #declare camAng=1.5;
       #declare surfPos=<-1, 0, 0>;
     #break
     #case (1)
       #declare camPos=Pos_Ghurghusht + 20000 * <sin(radians(270)), 0,
cos(radians(270))>;
       #declare camLook=Pos_Ghurghusht;
       #declare camAng=40;
       #declare surfPos=<0, 1, 0>;
     #break
     #case (2)
       #declare lat=0.131666666;
       #declare long=140.902222;
       #declare ht=3000;
       #declare dir=0;
       #declare azi=-89.999;
       #declare camAng=40;
     #break
     #case (3) // equivalent to Cologne, Germany
       #declare lat=51;
       #declare long=7;
       #declare ht=1000;
       #declare dir=0;
       #declare camAng=40;
     #break
     #case (3.01) // equivalent to Cologne, Germany
       #declare lat=51;
       #declare long=7;
       #declare ht=250;
       #declare dir=0;
       #declare camAng=40;
     #break
     #case (3.02) // equivalent to Cologne, Germany
       #declare lat=51;
       #declare long=7;
       #declare ht=50;
       #declare dir=0;
       #declare camAng=40;
     #break
     #case (4) // equivalent to Kabul, Afghanistan
       #declare lat=34.5;
       #declare long=67.75;
       #declare ht=0.0017;
       #declare dir=0;
       #declare azi=0;
       #declare camAng=40;
     #break
     #case (5) // Centlivres Lacus
       #declare lat=-33.54;
       #declare long=110.78;
       #declare ht=0.0017;
       #declare dir=0;
       #declare azi=0;
       #declare camAng=40;
     #break
     #case (6) // substellar point
       #declare lat=0;
       #declare long=90;
       #declare ht=0.0017;
       #declare dir=180;
       #declare azi=0;
       #declare camAng=40;
     #break
     #case (7) // 45 degrees west from substellar point
       #declare lat=0;
       #declare long=45;
       #declare ht=0.0017;
       #declare dir=0;
       #declare azi=0;
       #declare camAng=40;
     #break
     #case (8) // 55 degrees west from substellar point
       #declare lat=0;
       #declare long=35;
       #declare ht=0.0017;
       #declare dir=90;
       #declare azi=89.999;
       #declare camAng=40;
     #break
     #case (9) // 65 degrees west from substellar point
       #declare lat=0;
       #declare long=25;
       #declare ht=0.0017;
       #declare dir=180;
       #declare azi=0;
       #declare camAng=40;
     #break
     #case (10) // 80 degrees west from substellar point
       #declare lat=0;
       #declare long=10;
       #declare ht=0.05;
       #declare dir=90;
       #declare azi=10;
       #declare camAng=40;
     #break
     #case (11) // 90 degrees west from substellar point
       #declare lat=0;
       #declare long=0;
       #declare ht=5;
       #declare dir=90;
       #declare azi=0;
       #declare camAng=40;
     #break
     #case (12) // Schmidt Lacus, Achakzai Peninsula
       #declare lat=0.368888888;
       #declare long=140.5905556;
       #declare ht=0.0017;
       #declare dir=160;
       #declare azi=0;
       #declare camAng=40;
     #break
     #case (13) // 90 degrees east from substellar point
       #declare lat=0;
       #declare long=180;
       #declare ht=0.5;
       #declare dir=270;
       #declare azi=0;
       #declare camAng=40;
     #break
     #case (14) // Test scene for isosurface vs. mesh2 comparison
       #declare lat=1.8;
       #declare long=43.2;
       #declare ht=0.0017;
       #declare dir=315;
       #declare azi=0;
       #declare camAng=40;
     #break
     #case (15) // Rathjens Lacus
       #declare lat=17;
       #declare long=27.8;
       #declare ht=0.0017;
       #declare dir=90;
       #declare azi=0;
       #declare camAng=40;
     #break
     #case (16) // Start point for Ghurghusht Equatorial Flight
       #declare lat=0;
       #declare long=25.53056789;
       #declare ht=35;
       #declare dir=90;
       #declare azi=0;
       #declare camAng=40;
     #break
   #switch (view)
     #range (0, 1)
       camera
         #if (ani=1)
           sky <-1, 0, 0>
         #else
           sky surfPos
         location camPos
         look_at camLook
         angle camAng
     #range (2, 16)
       camera
<sin(radians(-long))*cos(radians(lat)), sin(radians(lat)),
cos(radians(-long))*cos(radians(lat))>);
         #if (vlength(surfPos)<5178*0.9897)
           #declare surfPos = vnormalize(surfPos)*5178*0.9897; // camera
over lake
         #declare camPos = surfPos+vnormalize(surfPos)*ht;
	#declare dirVect = <sin(radians(dir))*cos(radians(azi)),
sin(radians(azi)), cos(radians(dir))*cos(radians(azi))>;
	#declare camLook=camPos + vrotate(dirVect, <lat-90, -(long-180), 0>);
	#declare camLook=vrotate(camLook, Rot_Ghurghusht);
	#declare camPos =vrotate(camPos, Rot_Ghurghusht);
	#declare camLook=camLook+Pos_Ghurghusht;
         #declare camPos =camPos+Pos_Ghurghusht;
         sky vrotate(surfPos, Rot_Ghurghusht)
         location camPos
         look_at camLook
         angle camAng
     #break
     #case (17)
       camera
         #declare d=300000;
         location d*<sin(radians(40.01)), 0, cos(radians(40.01))>
         look_at 0
         angle 100
     #break
   #declare v1=camPos-Pos_Ghurghusht;
   #declare v2=Pos_Shams-Pos_Ghurghusht;
   #declare phase_ang=vdot(camPos-Pos_Ghurghusht,
Pos_Shams-Pos_Ghurghusht)/(vlength(camPos-Pos_Ghurghusht)*vlength(Pos_Shams-Pos_Ghurghusht));
   #declare phase_ang=acos(phase_ang)/(pi/180);
   #warning str(phase_ang, 3, 2)
   #if (!test)
     sky_sphere // random starry sky, to be replaced later on with
astronomically accurate sky generated from Hipparcos star catalogue
       #declare R1=seed(9843);
       #declare i=0;
horizon
	object
	  union
	    #while (i<50)
	      sphere
		0, 0.001
		#declare rn1=rand(R1)*360;
		#declare rn2=asin(rand(R1)*2-1);
		translate <sin(radians(rn1))*cos(rn2), sin(rn2),
cos(radians(rn1))*cos(rn2)>
	      #declare i=i+1;
	  color rgb 0,
	  #switch (phase_ang)
	    #range (0, 95)
	      color rgb 0
             #break
	    #range (95, 98)
	      color rgb (1/3)*(phase_ang-95)
             #break
	    #range (98, 180)
	      color rgb 1
             #break
       #declare i=0;
	object
	  union
	    #while (i<150)
	      sphere
		0, 0.00075
	      #declare i=i+1;
	  color rgbf 1,
	  #switch (phase_ang)
	    #range (0, 97)
	      color rgb 0
	    #break
	    #range (97, 100)
	      color rgb (1/3)*(phase_ang-97)
	    #break
	    #range (100, 180)
	      color rgb 1
             #break
       #declare i=0;
below horizon
	object
	  union
	    #while (i<500)
	      sphere
		0, 0.0006
	      #declare i=i+1;
	  color rgbf 1,
	  #switch (phase_ang)
	    #range (0, 100)
	      color rgb 0
	    #break
	    #range (100, 104)
	      color rgb (0.9/4)*(phase_ang-100)
	    #break
	    #range (104, 180)
	      color rgb 0.9
             #break
       #declare i=0;
	object
	  union
	    #while (i<2000)
	      sphere
		0, 0.0005
	      #declare i=i+1;
	  color rgbf 1,
	  #switch (phase_ang)
	    #range (0, 105)
	      color rgb 0
	    #break
	    #range (105, 110)
	      color rgb (0.7/5)*(phase_ang-105)
	    #break
	    #range (110, 180)
	      color rgb 1
             #break
#else
   #declare T_White =
   texture
     pigment { color rgb 1 }
   #declare Grid_Bar_H =
   box
     0, <15, 1, 3>
     texture { T_White }
   #declare Grid_Bar_V =
   object
     Grid_Bar_H
     rotate <0, -90, 0>
     translate <2, 0, 0>
   #declare Physical = array[26]
     color rgb <0, 0, 0.2>,
     color rgb <0, 0, 0.4>,
     color rgb <0, 0, 0.7>,
     color rgb <0, 0.15, 1>,
     color rgb <0, 0.25, 1>,
     color rgb <0, 0.5, 1>,
     color rgb <0, 0.65, 1>,
     color rgb <0, 1, 1>,
     color rgb <0.4, 1, 1>,
     color rgb <0.6, 1, 1>,
     color rgb <0, 0.7, 0>,
     color rgb <0, 1, 0>,
     color rgb <1, 1, 0.5>,
     color rgb <1, 1, 0>,
     color rgb <1, 0.7, 0>,
     color rgb <1, 0.6, 0>,
     color rgb <1, 0.4, 0>,
     color rgb <1, 0.2, 0>,
     color rgb <1, 0, 0>,
     color rgb 0.3,
     color rgb 0.4,
     color rgb 0.5,
     color rgb 0.6,
     color rgb 0.7,
     color rgb 0.78,
     color rgb 1
   #declare Elevations = array [25]
   { "10000", "8000", "6000", "4000", "2000", "1000", "500", "200",
"100", "0", "100", "200", "500", "1000", "2000", "3000", "4000", "5000",
"6000", "7000", "8000", "10000", "12000", "15000", "20000" };
   #declare lat_start=90-int(clock/360);
   #declare long_start=mod(clock,360);
   #declare res=900; // pixels per degree
   #declare xdim=900;
   #declare ydim=900;
   #declare lat_end=lat_start-(ydim/res);
   #declare long_end=long_start+(xdim/res);
   #if (!legend)
     #declare sl=5124.6666; // sea level
     // #if (mapping=2) // elevation probing mode for grayscale maps
       #declare min_file=0;
       #declare max_file=0;
       #fopen mm "minmax" read
       #while (defined(mm))
         #read (mm, min_file, max_file)
       #fclose mm
       #warning concat("min_file = ", str(min_file, 5, 4), " max_file =
", str(max_file, 5, 4))
       #declare min_el=min_file;
       #declare max_el=max_file;
     // #end
     #declare lat=lat_start;
     #while (lat >= lat_end)
       #declare long=long_start;
       #while (long < long_end)
	#declare el=vlength(trace(Ghurghusht, 0,
cos(radians(-long))*cos(radians(lat))>));
	#if (greymap=0) // defining pixel colors for physical map
	  #switch(el-sl)
	    #range (-sl, -10)
	      #declare pc = Physical[0];
	    #break
	    #range (-10, -8)
	      #declare pc = Physical[1];
	    #break
	    #range (-8, -6)
	      #declare pc = Physical[2];
	    #break
	    #range (-6, -4)
	      #declare pc = Physical[3];
	    #break
	    #range (-4, -2)
	      #declare pc = Physical[4];
	    #break
	    #range (-2, -1)
	      #declare pc = Physical[5];
	    #break
	    #range (-1, -0.5)
	      #declare pc = Physical[6];
	    #break
	    #range (-0.5, -0.2)
	      #declare pc = Physical[7];
	    #break
	    #range (-0.2, -0.1)
	      #declare pc = Physical[8];
	    #break
	    #range (-0.1, 0)
	      #declare pc = Physical[9];
	    #break
	    #range (0, 0.1)
	      #declare pc = Physical[10];
	    #break
	    #range (0.1, 0.2)
	      #declare pc = Physical[11];
	    #break
	    #range (0.2, 0.5)
	      #declare pc = Physical[12];
	    #break
	    #range (0.5, 1)
	      #declare pc = Physical[13];
	    #break
	    #range (1, 2)
	      #declare pc = Physical[14];
	    #break
	    #range (2, 3)
	      #declare pc = Physical[15];
	    #break
	    #range (3, 4)
	      #declare pc = Physical[16];
	    #break
	    #range (4, 5)
	      #declare pc = Physical[17];
	    #break
	    #range (5, 6)
	      #declare pc = Physical[18];
	    #break
	    #range (6, 7)
	      #declare pc = Physical[19];
	    #break
	    #range (7, 8)
	      #declare pc = Physical[20];
	    #break
	    #range (8, 10)
	      #declare pc = Physical[21];
	    #break
	    #range (10, 12)
	      #declare pc = Physical[22];
	    #break
	    #range (12, 15)
	      #declare pc = Physical[23];
	    #break
	    #range (15, 20)
	      #declare pc = Physical[24];
	    #break
	    #range (20, 100)
	      #declare pc = Physical[25];
	    #break
   #if ((el-sl)<min_el)
     #declare min_el = el-sl;
   #if ((el-sl)>max_el)
     #declare max_el = el-sl;
   #declare rng=max_el+abs(min_el);
   #declare ll=sl-abs(min_el);
   #declare grv=(el-ll)/rng;
   #if (mapping != 2)
    	box
    	  0, 1
    	  texture
    	    #switch (greymap)
		      #case (0) // physical map
			      pigment { color rgb <pc.red, pc.green, pc.blue> }
           #break
         	#case (1) // 8-bit heightfield
         	  pigment { color rgb <grv, grv, grv> }
         	#break
           #case (2) // 16-bit heightfield
             #declare rdraw = grv*255;
             #declare rdval = int(rdraw);
             #declare grraw = (rdraw-rdval)*255;
             #declare grval = int(grraw);
             pigment { color rgb <rdval, grval, 0>/255 }
           #break
           #case (3) // 24-bit heightfield
             #declare blraw = (grraw-grval)*255;
             #declare blval = int(blraw);
             pigment { color rgb <rdval, grval, blval>/255 }
           #break
       translate <(long-long_start)*res, 0, 450-(lat_start-lat)*res>
	#declare long=long+1/res;
       #declare lat=lat-1/res;
   // #if (mapping=2)
     #warning concat("min_el = ", str(min_el, 5, 4), " max_el = ",
str(max_el, 5, 4))
     #fopen mm "minmax" write
       #write (mm, min_el, ",", max_el, "\n")
      #fclose mm
   // #end
   #if(legend)
     box // dummy map
       <0, 0, -450>, <1800, 1, 450>
       texture
	pigment { color rgb <1, 0, 0> }
   #if (greymap=0)
     object { Grid_Bar_H translate <-15, 0, -450> } // lower left map
corner, latitude bar
     object { Grid_Bar_H translate <-15, 0, 447> }  // upper left map
     object { Grid_Bar_H translate <1800, 0, -450> } // lower right map
     object { Grid_Bar_H translate <1800, 0, 447> } // upper right map
     object { Grid_Bar_V translate <1, 0, -465> } // lower left map
corner, longitude bar
     object { Grid_Bar_V translate <1, 0, 450> } // upper left map
     object { Grid_Bar_V translate <1798, 0, -465> } // lower right map
     object { Grid_Bar_V translate <1798, 0, 450> } // upper right map
     text
       ttf concat(fontpath, "arial.ttf") str(lat_start, 2, 0), 1, 0
       texture { T_White }
       rotate <90, 0, 0>
       scale 20
       translate <-47, 0, 442.5>
     text
       ttf concat(fontpath, "arial.ttf") str(lat_end, 2, 0), 1, 0
       texture { T_White }
       rotate <90, 0, 0>
       scale 20
       translate <-47, 0, -455>
     text
       texture { T_White }
       rotate <90, 0, 0>
       scale 20
       translate <1820, 0, 442.5>
     text
       texture { T_White }
       rotate <90, 0, 0>
       scale 20
       translate <1820, 0, -455>
     text
       ttf concat(fontpath, "arial.ttf") str(long_end, 3, 0), 1, 0
       texture { T_White }
       rotate <90, 0, 0>
       scale 20
       translate <1785, 0, 470>
     text
       ttf concat(fontpath, "arial.ttf") str(long_start, 3, 0), 1, 0
       texture { T_White }
       rotate <90, 0, 0>
       scale 20
       translate <-15, 0, 470>
     text
       texture { T_White }
       rotate <90, 0, 0>
       scale 20
       translate <1785, 0, -484>
     text
       texture { T_White }
       rotate <90, 0, 0>
       scale 20
       translate <-15, 0, -484>
     text
       ttf concat(fontpath, "arial.ttf") concat("Cylindrical Map of
Ghurghusht - ", str(res, 3, 0), " pixels per degree"), 1, 0
       texture
       rotate x*90
       scale 40
       translate <430, 0, 515>
     #declare Elevation_Color_Bar =
     box
       0, <40, 1, 20>
     #declare a=0;
     #while (a<26)
       object
	Elevation_Color_Bar
	texture
	  pigment { color rgb <Physical[a].red, Physical[a].green,
Physical[a].blue> }
	translate <40*a, 0, -525>
       #declare a=a+1;
     #declare a=0;
     #while (a<25)
       text
	ttf concat(fontpath, "arial.ttf") Elevations[a] 1, 0
	texture
	rotate x*90
	scale 10
	#if (a=9)
	  #declare os=7.5;
	#else
	  #declare os=6;
	translate <5*(os+8*a), 0, -540>
       #declare a=a+1;
     text
       ttf concat(fontpath, "arial.ttf") "Depths and elevations in
metres" 1, 0
       texture
       rotate x*90
       scale 10
       translate <1090, 0, -540>
   camera
     orthographic
     #switch (greymap)
       #case (0) // physical map with legend
	right <1900, 0, 0>
	up <0, 1100, 0 >
	location <900, 500, 0>
	look_at <900, 0, 0>
       #break
       #range (1, 2) // 8- and 16-bit heightfield, global coverage
	right <1800, 0, 0>
	up <0, 900, 0>
	look_at <900, 0, 0>
       #break
       #case (3) // tiled 24-bit heightfields
         right <900, 0, 0>
         up <0, 900, 0>
        location <450, 500, 0>
        look_at <450, 0, 0>
       #break
Date: 10 Jun 2010 05:05:00
Message: <web.4c10aa75db118a4acba3fb0f0@news.povray.org>
> High!
> > Always good music!
Hello,
This seems to be a different view than the posted pictures, and I don't see the
bright spots on the hills, or even the lake...
I posted a link to my music website before to show the graphics (all done with
POV-Ray, of course), but you may enjoy it for the music list too.
http://mysite.verizon.net/moronicon/Eighties/
Dave Blandston
Date: 10 Jun 2010 06:57:38
Message: <4c10c522$1@news.povray.org>
High!
What POV-Ray version did you use to render? I used 3.61...
O.k., I'll check it out!
Yadgar
Date: 10 Jun 2010 07:20:00
Message: <web.4c10c98fdb118a4acba3fb0f0@news.povray.org>
I used version 3.7 37a. But, the difference is probably caused by the different
view/time of day.
Dave Blandston
