POV-Ray : Newsgroups : povray.binaries.images : Ghurghusht: artifacts at dawn Server Time
12 Nov 2026 04:40:11 EST (-0500)
  Ghurghusht: artifacts at dawn (Message 31 to 40 of 40)
<<< Previous 30 Messages Goto Initial 40 Messages
Subject: Re: Ghurghusht: artifacts at dawn
Date: 12 Jun 2010 14:26:21
Message: <4c13d14d$1@news.povray.org>
Le 2010-06-11 16:06, Jörg 'Yadgar' Bleimann a écrit :
> High!
> On 06/11/2010 09:57 PM, clipka wrote:
>> I still have no idea about the bright spots on the hills. At present, I
>> can only imagine that it's some precision problem with the isosurface.
> Increasing isosurface accuracy didn't help, I tried this earlier...
> See you in Khyberspace!
> Yadgar
> Now playing: Lichtermeer (Michael Rother)
By precision, I think that it's FP precision. I think that you are
pushing the floating point calculations very close to it limits.
The planet is large, your position over it's surface is very low.
Date: 12 Jun 2010 17:46:17
Message: <4c140029$1@news.povray.org>
High!
So the only way would be to scale the whole scene by 10 or 100?
Yadgar
Date: 13 Jun 2010 03:20:26
Message: <4c1486ba$1@news.povray.org>
"Jörg 'Yadgar' Bleimann" <yaz### [at] gmxde> schreef in bericht
news:4c140029$1@news.povray.org...
> High!
I am afraid that you cannot have the best of two worlds, or like they say in
French: "To have the butter, and the money for the butter"  ;-)
Zooming in close to a modelled planet pushes your possibilities to the
extreme and scaling your scene would not help. My advice for the groundlevel
landscape would be to model a scene totally separated from the planet model
itself but in accordance with its character of course. If you want to zoom
in from planet-wide view to groundlevel-wide view in an animation, you will
have to find a way to merge from one to the other in a satisfactory way.
Date: 13 Jun 2010 10:42:30
Message: <4c14ee56$1@news.povray.org>
Le 2010-06-12 17:46, Jörg 'Yadgar' Bleimann a écrit :
> High!
> Yadgar
No. The problem is not the location nor the planet itself, BUT the
location AND the dimention of the planet.
You have very small distances with very large object. That's the
problem: the /range/ of the scales.
One way that you could possibly work around would be, when you get close
enough to the geound that the planetary curvature becomes barely
perceptible, to switch to a limited, flat-world, version of the planet.
The part beyond the horizon can then be totaly droped, or replaced by a
large sphere located totaly under and out of view WHEN it can have an
effect on the scene. You may also be able to use a simple disk for that.
The function of that disk would only be to provide a shadow for the media.
Date: 14 Jun 2010 10:19:56
Message: <4c163a8c$1@news.povray.org>
High!
So even converting a, let's say 1 by 1 degree slice of the isosurface
into a mesh2 and than using only this comparatively small (900 by 900
vertices) mesh2 instead of the whole isosurface won't help?
Yadgar
Date: 14 Jun 2010 12:32:51
Message: <4c1659b3$1@news.povray.org>
Le 2010-06-14 10:19, Jörg 'Yadgar' Bleimann a écrit :
> High!
>> media.
> Yadgar
It can help, if you also shift the scene toward the origin to restrict
the effective range of values.
You can still use the isosurface, in a much smaller containing object.
Date: 15 Jun 2010 17:35:32
Message: <4c17f224@news.povray.org>
High!
No, this does not work - if I try to constrain the isosurface to a
sphere rotated to the chosen camera position (in geographical
coordinates), such as:
     isosurface
       function { Terrain_Function(x, y, z) }
       contained_by
	sphere
	  <0, 15, 0>/5178, <20, 25, 20>/5178
	  rotate <0, 0, 90-lat>
	  rotate <0, -long+90, 0>
	  translate <sin(radians(-long))*cos(radians(lat)), sin(radians(lat)),
cos(radians(-long))*cos(radians(lat))>
       max_gradient 5
       accuracy 0.0001
       double_illuminate
       texture { T_Ghurghusht }
       scale 5178
// end of code
I get error messages like "rotate found instead"... the container sphere
may not even scaled non-uniformly!
Yadgar
Date: 16 Jun 2010 12:26:03
Message: <4c18fb1b$1@news.povray.org>
Le 2010-06-15 17:35, Jörg 'Yadgar' Bleimann a écrit :
> High!
> isosurface
> contained_by
> sphere
> max_gradient 5
> accuracy 0.0001
> double_illuminate
> scale 5178
> // end of code
> Yadgar
I was thinking of a box that you can set to any arbitrary dimention.
Very often, the sphere is very far from the best container.
Bottom just under the lowest part of the ground.
Top at the maximum hight in the area.
Depth and width acording to where you are situated and what part is
likely to be visible.
If you still want to use a sphere, apply the rotation to the center
using v_rotate(), then, if needed, add any translation also to the
center itself.
sphere{vrotate(v_rotate(<0, 15, 0>/5178,rotate <0, 0, 90-lat>),<0,
-long+90, 0>)+<sin(radians(-long))*cos(radians(lat)),
sin(radians(lat)),cos(radians(-long))*cos(radians(lat))> , <20, 25,
20>/5178}
Should be equivalent to your case.
Date: 16 Jun 2010 16:40:15
Message: <4c1936af@news.povray.org>
High!
> 20>/5178}
It still doesn't work... contained_by does not accept any rotate or
translate statements! At least it's that way with 3.6...
Yadgar
Date: 17 Jun 2010 00:11:08
Message: <4c19a05c@news.povray.org>
Le 2010-06-16 16:40, Jörg 'Yadgar' Bleimann a écrit :
> High!
>> sphere{v_rotate(v_rotate(<0, 15, 0>/5178,rotate <0, 0, 90-lat>),<0,
>> 20>/5178}
Did not change with 3.7 to my knowlege.
> Yadgar
Oups, forgot to remove a rotate in the macro call. Also, there is a
superfluous underscore "_".
sphere{vrotate(vrotate(<0, 15, 0>/5178,<0, 0, 90-lat>),<0, -long+90,
20>/5178}
That long location statement is meant to replace your translate and rotates.
The v_rotate() macro replace the rotations.
Everything between the "+" and the radius replace your translate.
Don't forget to remove those:
