POV-Ray : Newsgroups : povray.binaries.images : "Spinner" space colony (2) Server Time
7 Jul 2026 20:33:18 EDT (-0400)
  "Spinner" space colony (2) (Message 41 to 50 of 65)
Subject: Re: "Spinner" space colony (2)
Date: 13 Jun 2010 10:30:48
Message: <4c14eb98@news.povray.org>
On 13/06/2010 11:20 AM, SharkD wrote:
> On 6/13/2010 5:58 AM, Stephen wrote:
>> It looks like it might be worth it. :-D
> Well, the last time I rendered the full scene it took all night. That
> was before the recent changes. :(
Quality is not cheap ;-)
Best Regards,
Date: 14 Jun 2010 02:11:43
Message: <4c15c81f$1@news.povray.org>
How good is the radiosity pretrace as an estimator of how long a scene
will take to render? Right now it takes about 10 seconds to render a
pixel, even with a reduced texture quality.
http://isometricland.com
Date: 14 Jun 2010 02:18:28
Message: <4c15c9b4@news.povray.org>
Another render showing another new building type and a variety of other
objects.
Download 'gh_scene_buildingstrip_curve_d.png' (322 KB)
Preview of image 'gh_scene_buildingstrip_curve_d.png'
Date: 14 Jun 2010 03:20:51
Message: <4c15d853$1@news.povray.org>
"SharkD" <pos### [at] gmailcom> schreef in bericht
news:4c15c9b4@news.povray.org...
> objects.
This is looking really good!
Date: 14 Jun 2010 08:07:23
Message: <4c161b7b$1@news.povray.org>
Not for me to answer as I seldom use radiosity. 10 seconds a pixel, WOW!
Best Regards,
Date: 14 Jun 2010 08:35:33
Message: <4c162215$1@news.povray.org>
Am 14.06.2010 08:11, schrieb SharkD:
It's usually not a good estimator, because there are various factors
involved:
The Good News:
- Unless radiosity pretrace settings are poor, the pretrace will take a
significantly higher ratio of radiosity samples per pixel (with each
sample requiring tens, hundreds, or even up to 1600 more rays to be
shot, albeit with a few simplifications).
- Using low_error_factor significantly increases the "cost" of sample
lookup (i.e. looking up samples that have already been taken nearby)
during pretrace, while leaving the "cost" during main render unchanged.
The Bad News:
- As the pretrace progresses, the total number of samples keeps
increasing (of course), which also increases the overhead of checking
which samples are suitable for re-use; thus, sample re-use is
comparatively more "expensive" during the main render than during the
first pretrace steps.
- Some features are disabled during pretrace, most notably antialiasing
and focal blur, so these added "costs" don't show during pretrace.
So, all in all, pretrace may or may not be slower or faster than main
render - it depends.
A smaller-sized render is probably a much better indicator of the main
render performance.
Date: 14 Jun 2010 16:23:35
Message: <4c168fc7$1@news.povray.org>
On 6/14/2010 3:20 AM, Thomas de Groot wrote:
> "SharkD"<pos### [at] gmailcom>  schreef in bericht
>> objects.
> Thomas
Yeah, clipka's advice on compensating for gamma really helped a bunch!
Date: 14 Jun 2010 18:12:51
Message: <4c16a963$1@news.povray.org>
What kinds of things might be the causes of all the slowdown? I've
turned off all media and reflection and it is still abysmally slow.
One major revision I've made to Chris Colefax's CityGen include file is
that each building is now called by a macro and generated individually
at runtime. Whereas originally a single copy (more or less) of a
building was stored in an array and replicated/duplicated when needed.
The other difference of course is that buildings now have greater
complexity. They make use of more CSG operations and feature a greater
number of storeys.
Date: 14 Jun 2010 19:03:34
Message: <4c16b546$1@news.povray.org>
> number of storeys.
You have a "concave" geometry composed of many objects made out of
coaxyal cylinders slices. This can very easily lead to bounding problems
where most objects bounding boxes overlap each other, and are
excessively large.
Try manualy bounding the individual buildings. Try to see if you can use
some mesh.
Use simple boxes or prisms for narrow buildings and some of the farder
ones. Some/most broad buildings probably can do with only a texture that
curves instead of the actual floors.
Except for the closest buildings, don't model individual floors. A flat
topped conical building can be a simple truncated cone. The flat base
beed hiden under the ground. If needed, remove a small cylindrical part
from it's top.
Only model the interior of a building IF you look from it's inside or
take a closeup look into it. Use conditional statements, possibly based
on insideness test or bounding box test to toggle the insides as needed.
Date: 14 Jun 2010 19:31:17
Message: <4c16bbc5$1@news.povray.org>
>> number of storeys.
> excessively large.
> some mesh.
> from it's top.
> Alain
Here's the macro I use to generate the concave cylinder sections:
#macro cyl_box(in_star, in_stop)
	#local in_star_height	= city_radius - in_star.y;
	#local in_stop_height	= city_radius - in_stop.y;
	#local in_star_z_angle	= in_star.x/city_circum * 360;
	#local in_stop_z_angle	= in_stop.x/city_circum * 360;
	difference
		cylinder {<0,0,in_star.z-0>, <0,0,in_stop.z+0>, in_star_height}
		cylinder {<0,0,in_star.z-1>, <0,0,in_stop.z+1>, in_stop_height}
		plane {+x, 0 rotate z * in_star_z_angle}
		plane {-x, 0 rotate z * in_stop_z_angle}
		bounded_by {cylinder {<0,0,in_star.z-0>, <0,0,in_stop.z+0>,
in_star_height}}
Can I use an object produced by this macro as a bounding object? Would
it be better to use a mesh instead? Does bounding work on unions and
merges as well as differences and intersections?
