On 02/06/2010 9:04 AM, Thomas de Groot wrote:
> "Stephen"<mca### [at] aolDOT com> schreef in bericht
> news:4c04f695$1@news.povray.org...
>> On 01/06/2010 9:50 AM, Thomas de Groot wrote:
>>> I have started a new scene for my Iskander series, located (again) in the
>>> Apollo temple model I built a couple of years ago.
>> Love the textures :-)
> Thanks, Stephen. Interestingly, this is mainly the result of the lighting
> which casts that yellowish sheen over the building, which is grey by itself.
I must have a play with LightSys. Do you set it up in Moray or in the
generated Pov script?
Best Regards,
"Stephen" <mca### [at] aolDOT com> schreef in bericht
news:4c0653bb@news.povray.org...
In POV-Ray. This scene does not use Moray by the way, but is entirely POV
SDL, with the temple as a construction of mesh2 objects.
"Bill Pragnell" <bil### [at] hotmail com> schreef in bericht
news:web.4c050e56816befb66dd25f0b0@news.povray.org...
> Nice. Bring on the high-quality renders. Ahead, quality factor 9!
Here is one. 200 blur samples (still visible artifacts) and a render time of
about 1.5 hours
Should have added the image :-(
Here it is.
Download 'A Treacherous Knife_04.jpg' (89 KB)
Preview of image 'A Treacherous Knife_04.jpg'
> Here it is.
> Thomas
Looking great!
Cheers,
Edouard.
"Edouard" <pov### [at] edouard info> schreef in bericht
news:web.4c08cc6a816befb63694f4200@news.povray.org...
> Looking great!
Thanks Edouard. Your camera macros are great too :-)
Everything looks fine with exception of these strange dots.
> Used here: LightSys with a high turbidity setting (simulates the sunlight
> during Harmattan season); Real Camera of Edouard Poor, with as yet very low
> blur samples as is obvious; radiosity with also very low samples. Rendered
> in 25 minutes on a dual core machine and using POV-Ray 3.7, latest beta.
> Thomas
That's looking very good! It reminds me that I need to make an illusion.inc
tutorial describing how to speed up such renders. Scenes like this can benefit
from the technique without a loss of quality.
"Samuel Benge" <stb### [at] hotmail com> schreef in bericht
news:web.4c19209d816befb6a48fdb00@news.povray.org...
> illusion.inc
> benefit
Thanks indeed, Sam. I shall have a look into illusion.inc as I had not
realized its potentials.
> > illusion.inc
> > benefit
Currently, illusion.inc does not take .hdr images, nor does it perform a
repeat/flip warp for the edges of the image. Both of these things are necessary
to make the final output convincing. I have a modified version of Rune's file at
hand, but I need to contact him before distributing it. Maybe he'll update his
version with my changes :)
A rough draft of my tutorial is nearly ready. I need to simplify things. There
are some ins-and-outs to making the whole thing work. To quickly summarize, let
me say that you need to:
1) render the background objects with no_image applied to the foreground objects
2) render the foreground objects with the background visible (you can render
only a section of the image to save time, POV-Ray reads partials)
3) finally, render all objects without radiosity/lighting/diffuse/etc., but with
the pre-rendered images applied, and with focal blur
During the first step for your particular scene, I would give the front-most
pillar the no_image attribute, but render everything else. I single it out
because the combined focal blur/compositing errors from it will be most visible.
That pillar will still cast a shadow and contribute to the radiosity, but having
it invisible will allow the background to render, which is what you want for the
first step. After that, you just work your way up to the foreground.
Complex scenes may require more layers, and some scenes will never look right no
matter what you do. But compositing errors in a scene like yours, if everything
is layered correctly, would be hardly noticeable, if at all.
I hope it doesn't sound too complex.
Sam
P.S. How long does "A Treacherous Knife" take to render without focal blur?
