POV-Ray : Newsgroups : povray.binaries.images : Pioneer WIP Server Time
22 Apr 2026 16:20:44 EDT (-0400)
  Pioneer WIP (Message 11 to 12 of 12)
Subject: Re: Pioneer WIP
Date: 18 May 2010 08:01:17
Message: <op.vcwgzohoufxv4h@go-dynamite>
On Sun, 16 May 2010 21:06:22 +0200, TC get-enough-spam-already-2498.com>
<do-not-reply@i-do> wrote:
> I doubt the plate looks aged at all. It probably is still as shiny as it
> was
> when the spacecraft was launched.
> No oxygen in space to corrode it (and gold does not corrode easily,
> anyway),
> no dust to grind it down. At the velocities involved even a small speck
> would either make a neat hole or destroy the whole spacecraft.
Hmmm...
Maybe the corrosion is due to crashing onto their planet?
-Nekar Xenos-
Date: 18 May 2010 15:12:19
Message: <4bf2e693@news.povray.org>
Jaime Vives Piqueres wrote:
> Putting aside the controversy about if it should be weathered or not, I
> think the corrosion looks good, only perhaps a bit exaggerated in height
thanks, I consider that high praise coming from you ;)
I will try scaling it down.
Although it wasn't intended to be corrosion in the chemical
sense, more accumulated mechanical micro-impacts, hence the
longish scratches. I think the borders are too strongly
affected: I cranked the function way up near the borders so
it would go all the way to the bottom and give jagged edges
in x-z plane instead of the actual straight hf boundaries.
