"Kenneth" <kdw### [at] earthlink net> wrote in message
news:web.4bde94823d08c812ae92d9930@news.povray.org...
> (I'm curious about the gas-giant planet's appearance; really HUGE objects
> that
> are far off in the distance show a sort of visual 'compression'. There's
> really
> nothing that we see on earth that would be similar, of course, so it's
> hard to
> visualize. But the 'effect' would, I think, be the same as if you
> squashed-down
> your textured planet in z. (Squashing it in-line with the camera.) OR,
> placed it
> WAY off into space while increasing its size accordingly. The only similar
> example I can think of is the planet Saturn, when it's viewed NOT edge-on
> through a telescope. It's an experiment I've been meaning to try in
> POV-Ray, but
> haven't gotten around to.)
The only squashing effect I'm aware of is when viewing through a telescope,
which is the same flattening effect you get with a zoom lens, this image has
a non-zoomed field of view so you wouldn't see squashing.
The squashing is because the more you zoom in, the narrower your field of
view, the closer to parallel the edges of your view become, so the less
perspective you have in the image. With a wide field of view objects further
away get a lot more perspective, so get smaller quicker, a zoomed lens keeps
things much more similar sizes.
The planet in my image is placed by positioning it relative to the camera,
then moving it away and scaling it up as you suggest (in fact the camera is
at <0,0,0> so I just scale the planet). However this does not alter the
appearance of the planet, any ray traced toward it will still hit the same
part, and it won't appear any more flattened (because it is physically
bigger by the same amount that it's been pushed away).
You know, it's probably easier to just show you. Here's a simple scene, the
second image shows the same scene viewed from 5x further away, with a camera
zoomed in appropriately.
Tek
http://evilsuperbrain.com
Download 'zoom1.jpg' (38 KB)
Download 'zoom5.jpg' (29 KB)
Preview of image 'zoom1.jpg'
Preview of image 'zoom5.jpg'
I should also mention my image is quite unrealistic, because the size of
that planet would suggest we're much closer to it than a moon should be
(unless it's a very low-density planet). It should be further away (or
smaller, all things are relative), and then I would have to zoom the camera
in more if I wanted it this large in frame, which would give the flattening
effect (though it would also flatten the foreground). I wanted to get the
appearance of a deliberately exagerated classic sci-fi illustration.
Tek
"Tek" <tek### [at] evilsuperbrain com> wrote in message
news:4bdead14@news.povray.org...
>> that
>> really
>> hard to
>> squashed-down
>> placed it
>> similar
>> POV-Ray, but
> telescope, which is the same flattening effect you get with a zoom lens,
> this image has a non-zoomed field of view so you wouldn't see squashing.
> further away get a lot more perspective, so get smaller quicker, a zoomed
> lens keeps things much more similar sizes.
> is at <0,0,0> so I just scale the planet). However this does not alter the
> the second image shows the same scene viewed from 5x further away, with a
> camera zoomed in appropriately.
> Tek
"Tek" <tek### [at] evilsuperbrain com> schreef in bericht
news:4bdb6832@news.povray.org...
> Personally my favourite is warpgate, closely followed by skyship and
> dustland.
My favourite is skyship, because of the almost abstract landscape and
insect-like ship, but the others are also memorable and intriguing. Very
well done indeed.
Hmm, that *would* seem to be the case, even in the situation I'm thinking of.
Maybe I'm wrong about the whole idea. But I'm imagining, say, the planet Mars:
If it were perhaps far larger in actual size (to take up an area in the sky two
or three times the visible diameter of the Moon, for example) while still being
so far away, it seems to me that the 'perspective' of the 'closer' and 'farther'
parts of the disc would be foreshortened. Based on the idea that, relative to me
as the observer at such a distance, the 'distance difference' between the closer
and farther parts would be quite small, relatively speaking. I guess I just
need to do an experiment, to prove or disprove it to myself. (I have an image in
my mind of what I think it should look like--but maybe that's a false image!)
There's actually a 'down-to-earth' example that I've looked at, which *seems* to
show this effect: It's a giant crane hoist (a *really* big one) at a Navy yard
near me. It has an elevated 'track' (that the crane runs on) which is probably a
good 300-feet long. When that track is rotated to be 'in line' with my line of
sight, it's near and far ends appear to be just about the same size
visually--almost no perspective distortion, in other words. (And I can only view
it from far away--not close enough to show the normal perspective distortion--so
an unfortunate side effect is that it 'looks' quite small.)
Time to experiment! :-)
Ken
If Mars was that big, you'd be able to see it's curvature, and Earth
would orbit around Mars, not the Sun... In that case, mars would be 2 or
3 times bigger than the Sun, and MUCH, MUCH more massive. 8 to 27 times
the volume, and a larger density.
> Ken
Our perseption of perspective depends heavily on the distance that
separate us from what we observe, and the relative depth compared to
that distance.
In a perfectly transparent medium, any sphere whose apparent diameter is
the same will look the same. Be it a 1 cm marble at 1 m or a 1 000 000
km thing at 100 000 000 km. In both cases, the diameter is 1% of the
distance, and both will have the same apparent curvature.
In the example of the crane, you may be at about 5000 feet (a little
under a mile) fom it.
The close part is at 5000 feet, and the far point is at 5300 feet. A
difference of about 6%.
If you are near it, say at around 100 feet and on some scafolding, the
close point is at 110 feet and the far end at 400 feet. A diference of
72.5%.
> > two or three times the visible diameter of the Moon, for example) while
> > still being so far away, it seems to me that the 'perspective' of the
> > 'closer' and 'farther' parts of the disc would be foreshortened. Based on
> > the idea that, relative to me as the observer at such a distance, the
> > 'distance difference' between the closer and farther parts would be quite
> If Mars was that big, you'd be able to see it's curvature...
Yeah, that's probably true; I came to the same conclusion.
So I finally did a test(!), using a 'typical' camera angle of 67-deg. in
POV-Ray. (No telephoto, in other words.) And the result is...I don't see much
if *any* perspective difference between small 'nearer' objects and large
'farther' objects. (If it's there, it's very subtle.) Hmm, not at all the
result that I was expecting. I guess it's time to put this idea to rest. :-(
Or else 'cheat' the scene, to get what I want! ;-P
Ken
news:web.4bdfacfc3d08c812ae92d9930@news.povray.org...
> much
As Alain pointed out, there's no difference, and there can't be a
difference. The camera doesn't know how big it is, so all sizes are
relative, something 10m wide 100m away is identical to something 10km wide
100km away.
This is very common in illustrations and movies: they get a telephoto image
of the moon or a telescope image of a planet and stick it in the background
of a non-telephoto scene, creating artificial flattening.
Personally I like the fact that ray tracers can do stuff more realistically.
I did some test renders using real measurements of the size of planets
viewed from orbiting moons, it's surprising how small the planet appears
with normal camera angles. Even Jupiter viewed from some of its closer moons
is pretty small. But then if you zoom the camera in you get the nice
flattening effect and a very interesting image. I wanted something less
realistic for my IRTC scene but it's nice to know what looks real.
Unfortunately I don't have the test scene on this PC, so I can't show you,
doh!
Tek
High!
> dustland.
I like "Dustland" most... it's classical space art! Did you use an
ordinary heightfield or did you model a whole isosurface moon?
See you in Khyberspace!
Yadgar
Now playing: The Kick Inside Of Me (Simple Minds)
news:4be00b8f$1@news.povray.org...
I started writing a macro to make a nice spherically-curved triangle mesh
with varying polygon density, then I remembered that I couldn't spend too
long on any of these scenes because I had to do so many for my irtc concept,
so I abandonned that and went with a boring standard height_field! :)
Tek
Yes! In fact, this is probably where my wacky idea came from--old sci-fi
illustrations--and thinking that that was how the real world worked!! It's been
embedded in my mind for a *long* time.
Hmm, it makes me wonder about my 'big crane' example; I need to go and look at
it again...armed with my 'new knowledge'. ;-)
Ken
