POV-Ray : Newsgroups : povray.binaries.images : How to speed up media scenes? Server Time
22 Apr 2026 16:20:05 EDT (-0400)
  How to speed up media scenes? (Message 11 to 13 of 13)
Subject: Re: How to speed up media scenes?
Date: 8 Apr 2010 13:40:43
Message: <4bbe151b$1@news.povray.org>
> High!
> Alain wrote:
>> Use the default sampling mode of 3.
>> NEVER EVER use more that intervals 1: The default value. If you need
>> more samples, only use samples xx. You only use 1 samples value. Any
>> value after a comma will be totaly ignored.
>> intervals 10 samples 10 is WAY slower than samples 200, for half the
>> number of samples.
> According to the POV-Ray 3.6 manual, the default intervals value is 10,
> not 1...
> See you in Khyberspace!
> Yadgar
That's the default for the sampling method 1. It was correct with
version 3.1. With version 3.5, the defaults where changed, but the
documentations where not properly updated. If you read through the text
about method 3, you'll see some of the correct dafault values.
The default sampling method is method 3.
With method 3, the REAL default are:
intervals 1
samples 10 <-- the documentation don't specify that one.
Date: 8 Apr 2010 14:43:55
Message: <4bbe23eb$1@news.povray.org>
I changed the default table here:
http://wiki.povray.org/content/Documentation:Reference Section 6#Media
the passage your referred to ... well I read right past it twice so I
thought it was worth highlighting it as a "Note"
http://wiki.povray.org/content/Documentation:Reference_Section
6.1#Sampling Parameters & Methods (last paragraph)
Jim
Date: 8 Apr 2010 14:48:46
Message: <4bbe250e$1@news.povray.org>
> Jim
sorry about the urls ... hmmm why is it doing that? using 'pan' if anyone
knows the answer
Jim
