POV-Ray : Newsgroups : povray.binaries.images : Making Planets Server Time
28 May 2026 17:44:08 EDT (-0400)
  Making Planets (Message 3 to 12 of 12)
<<< Previous 2 Messages Goto Initial 10 Messages
Subject: Re: Making Planets
Date: 9 Mar 2010 10:38:45
Message: <4b966b85$1@news.povray.org>
Kirk Andrews wrote:
> This has been done many times--in fact, not so long ago someone was
> using some rather advanced techniques with very nice results, but I
> couldn't find the post or remember who was doing it.  In any case, I was
> inspired last night to make a POV planet, and here it is.  I'm fond of
> the atmosphere and the water, but I should keep working on the texture
> for the landmasses.
Wow,,, nice
Date: 9 Mar 2010 15:24:19
Message: <4b96ae73@news.povray.org>
Thanks for the nice comments.  Here's another, larger render.  This one
I rendered with beta 35, and the media seems to have rendered quite
substantially different.  I had to do some post-processing to make up
for it.
In case you were curious, the land forms are an isosurface based on
F_ridged; the ocean is a transparent sphere with colored fade statements
in the interior.  I used two separate spheres with media--one for
general atmosphere and another for clouds.
Download 'blueplanet2.jpg' (114 KB)
Preview of image 'blueplanet2.jpg'
Date: 9 Mar 2010 16:51:52
Message: <4b96c2f8$1@news.povray.org>
"Kirk Andrews" <kir### [at] tektonartcom> schrieb im Newsbeitrag
news:4b96ae73@news.povray.org...
> for it.
The dark side of the planet in this render features a few lights. Are these
city-lights (intentionally placed) or stars from the background shining
through or artifacts (from beta)?
Date: 9 Mar 2010 17:15:33
Message: <4b96c885$1@news.povray.org>
>> for it.
Ah yes, I forgot to mention that.  The render did show some artifacts on
the landmasses on the dark side of the planet.  However, their placement
seemed realistic enough to serve as city-lights, so I boosted their
brightness and blurred them slightly in post-processing.
Date: 9 Mar 2010 17:54:46
Message: <4b96d1b6$1@news.povray.org>
> substantially different. I had to do some post-processing to make up for
> it.
> in the interior. I used two separate spheres with media--one for general
Any chance of posting the code?  This is something I have played with a
few times but never got this good a result.
Rarius
Date: 10 Mar 2010 09:41:30
Message: <op.u9cwfdneufxv4h@go-dynamite>
On Tue, 09 Mar 2010 22:24:03 +0200, Kirk Andrews
> for it.
I had to change a lot in my media statements when changing from 3.6 to 3.7
beta, but it looked better in the end :)
-Nekar Xenos-
Date: 10 Mar 2010 09:43:55
Message: <op.u9cwjee3ufxv4h@go-dynamite>
On Wed, 10 Mar 2010 00:15:20 +0200, Kirk Andrews
>>> for it.
>> these city-lights (intentionally placed) or stars from the background
>> shining through or artifacts (from beta)?
You could also just put a smaller black sphere inside to stop anything
 from shining through. Did you try playing around with the isosurface
accuracy setting?
-Nekar Xenos-
Date: 10 Mar 2010 11:41:37
Message: <4b97cbc1@news.povray.org>
> accuracy setting?
> -Nekar Xenos-
An inner sphere is a good idea which would probably fix it.  I did have
to boost the accuracy setting 1000 fold already just to prevent the
coastlines from showing up black, for some reason.
Date: 15 Mar 2010 22:40:57
Message: <4b9eefb9@news.povray.org>
High!
one I rendered with beta 35, and the media seems to have rendered quite
for it.
Awesome... how did you use F_ridged? Could you render a surface close-up
(with the camera located a few meters above the surface looking towards
the horizon) of one of your continents?
Coincidentally, I currently also work on a planet, and my isosurface
consists of a blend of granite, spherical and crackle:
#declare S = // for the basic spherical shape
function { x*x + y*y + z*z -1 }
#declare P_Average =
pigment
   average
   pigment_map
     [0.5 granite scale 10 poly_wave 0.333 ]
     [1 spherical scale 10 turbulence 0.5 poly_wave 0.333 ]
     [0.025 crackle scale 0.2 turbulence 1 ]
#declare Terrain_Part4_Function=
function
   pigment { P_Average }
overlain with bozo for large-scale altitude variation:
#declare Terrain_Part2_Function=
function
   pattern
     bozo
#declare Terrain_Function=
function { S(x, y, z) + Terrain_Part4_Function (x*50, y*50,
z*50).gray*0.05 + Terrain_Part2_Function (x, y, z)*0.01 }
The altitudes range between about -7 and 30 kms (relative to sea
level)... but the shores of the scattered small "seas" are mostly very
steep (see images below) - I would preferably have more flat low-lying
lands around the "seas"! How can this be achieved?
Perhaps we could join forces in building our worlds...
See you in Khyberspace!
Yadgar
Download '2010-03-15 ghurghusht, glatzer lacus region from 8000 km altitude, lookingdown, take 1.jpg' (177 KB) Download '2010-03-16 ghurghusht, schmidt lacus, achakzai peninsula from 1.7 m altitude,looking southeast, take 1.jpg' (17 KB)
Preview of image '2010-03-15 ghurghusht, glatzer lacus region from 8000 km altitude, lookingdown, take 1.jpg'
Preview of image '2010-03-16 ghurghusht, schmidt lacus, achakzai peninsula from 1.7 m altitude,looking southeast, take 1.jpg'
Date: 26 Mar 2010 11:25:09
Message: <4bacd1d5$1@news.povray.org>
>> it.
> Rarius
Sure, I've put it up on my website here:  http://www.tektonart.com/?p=170
