stbenge wrote:
> faster rate than panning alone. With gold prices the way they are, it
> looks like we'll be able to make up for the lack of real jobs available
> to us!
Oops, gold prospecting *is* a real job; I meant to say "regular job" :)
"stbenge" <UN### [at] hotmail com> wrote in message news:4b81a3c6@news.povray.org...
>> to us!
I know someone up in Alaska whose waiting on the thaw ... he's had his eye
on what he thinks is a pretty good sized nugget in a stream, but hasn't had
the courage to go after it just yet!
Jim
Well, those things don't stay put. The longer he waits, the deeper he
might have to dig to get at it.
I can't wait for the thaw myself. I found some granite pegmatite nearby,
and with pegmatite there is always a chance of finding tourmaline,
aquamarine and other great things! But the trail leading to this place
experiences a particularly deep freeze, and the snow is covering up
everything :(
"stbenge" <UN### [at] hotmail com> schreef in bericht
news:4b819605@news.povray.org...
> Thomas de Groot wrote:
>> Is there still some gold left? :)
> Yes, there is quite a bit of gold left. The current town my brother and I
> are prospecting is said to still have 70% of its placer deposits intact.
> When we checked it out the other day, I was seeing color in every pan I
> tried, which is a good sign.
Interesting. I thought that most had been dug by the end of the 19th
century, ending the gold rush. But then, I am no expert at all ;-)
I suppose that all placers have not been exploited and erosion is uncovering
new sites.
> When the sluice is finished we'll be able to retrieve gold at a much
> looks like we'll be able to make up for the lack of real jobs available to
> us!
Good luck to you two. It is not an easy job (not like romantic stories want
to make us believe).
>stbenge on date 19/02/2010 20:12 wrote:
> Hi,
> This is a quick render of a sluice box that I hope to build mostly out
> of materials available to me. The proportions are not exact; this is
> just a concept to explore how it might fit together using flashing,
> narrow metal edging, and rivets. I'll have to buy the miner's moss.
> How are the light levels? I just got a new LCD monitor, so I'm having
> difficulty getting my rendered images to look correct.
> Happy Raytracing,
> Sam
Hey, stop posting photos here, Sam! ;-)
Are you searching a different approach to data mining? Data filtering? ;-)
Paolo
I think the treehouse looks really cool too.
I don't recall posting the landscape design renderings, but that's a great idea.
Maybe someone will be inspired in some small way by them as I'm often inspired
by everyone's pictures here. I'll post the pictures in a separate article so as
not to interfere with your posting.
Dave Blandston
I wonder if the overlapping of the metal plates forming the side should
be reversed - so that flow from the top down does not encounter the
edges of the metal as now. You want to minimise wear and the
possibility of clogging that is inevitable when gravel and sand is
washed through the device.
Similarly it would be better to replace the separate plates and rivets
at the base with a single plate. Better yet have an 'insert' plate that
can be replaced as needed covering the base. Wear and tear is a major
consideration for sluice boxes.
Actually, they are set up in consideration of the water flow. The
material/water will start flowing from the funneled end.
We are using the materials available to us. We don't have any large
plates of sheet metal, so we are forced to use several pieces of flashing...
Hehe, yeah. I can't figure out to turn a profit from data mining, so I'm
turning to real mining ;)
> new sites.
I thought most of the gold had been found too, since the town in
question was extensively dredged back during the Gold Rush. But for some
reason they stopped. Every once in a while somebody will find a large
nugget washed out onto the road from the alluvium.
>> us!
Thanks! You're right, it's not easy work, but a sluice box will multiply
our efforts ten-fold. Hopefully we can continue paying rent :S
