POV-Ray : Newsgroups : povray.binaries.images : Nostalgic Lego Server Time
28 Jul 2026 02:55:14 EDT (-0400)
  Nostalgic Lego (Message 21 to 27 of 27)
Subject: Re: Nostalgic Lego
Date: 28 Jan 2010 07:39:16
Message: <4b618574$1@news.povray.org>
On 28.01.2010 01:13, SafePit wrote:
> You are so clever Ive!  I've been struggling using the peeron "official colors"
> and being so light.  Wow, what a difference!  Sadly, I'll having to render all
> my scenes again. :(
> Thanks for sharing!!!
You are welcome.
And do not forget to adjust the other colors also. Also increasing the
key light intensity should help.
Another cheap trick: when no radiosity is used put a shadowless
light_source exactly at the camera position, like:
light_source {cam_location, color rgb 0.1 shadowless}
this looks in most cases much better than adding an ambient value to the
finish.
-Ive
Date: 28 Jan 2010 07:40:04
Message: <4b6185a4$1@news.povray.org>
On 27.01.2010 12:04, Jaime Vives Piqueres wrote:
> Very nice... as usual.
Thank you. Luckily you are not aware of all my usual failed attempts ;)
-Ive
Date: 28 Jan 2010 15:20:50
Message: <4b61f1a2$1@news.povray.org>
My oldest Lego definitely had grey tires, but later they were all black,
so a change of around 1973 sounds right to me.
On 2010-01-27 16:39, Alain wrote:
>> High!
>> scott wrote:
>>> Great render - I remember those old wheels and tyres too, they had a
>>> metal axle that you pressed into a special 2x4 brick didn't they? I
>>> preferred the technic wheels and axles that you actually connect to
>>> stuff :-)
>> When I got my first Lego set in 1974, the tyres were black, not gray...
>> and also later, I never encountered any gray tyres! Could it be that
>> Lego sets with gray tyres were only marketed in the US?
>> See you in Khyberspace!
>> Yadgar
>> Now playing: Sehnsucht nach Allem (Yello & Joy Rider) - German New Wave!
> In the early 70's, they changed from gray to black. Maybe, if you had
> your first set in 1973, the tires would have been gray...
> Alain
Date: 9 Feb 2010 17:54:09
Message: <4b71e791$1@news.povray.org>
Larry Hudson schrieb:
> Well, I'm 72.  So Legos were much later than my early years.  For me it
> was Tinker Toys (all wood), then a little later, Erector Sets (all metal).
> Of course, now we can build anything with POVRay...     ;-)
Speaking of which - has anyone ever modeled some Erector / Meccano (or
Anker stone construction sets might be a thing to try, too...
Date: 9 Feb 2010 18:07:08
Message: <4b71ea9c$1@news.povray.org>
Absolutely great.
But aren't the transparent parts wrong? AFAIK the transparent parts of
that time had "inner pins" just like the non-transparent ones.
I also think you got the axle blocks wrong, IIRC the holes were a good
deal lower (but I might be mistaken about that).
The rounding of the corners seems too strong to me (it's perfectly right
for the knobs though).
For the perfect finishing touch, try randomly rotating the 1x1 pieces
ever so slightly. You'll never ever get them perfectly straight in RL ;-)
Date: 10 Feb 2010 11:04:37
Message: <4b72d915$1@news.povray.org>
On 10.02.2010 00:07, clipka wrote:
> Absolutely great.
Thank you!
The 'glass' tiles I did play with looked like the rendered ones (without
inner pins) and they did not hold very well together. AFAIR the ones
with pins did come later.
You might be right. I have no actual reference and the axle bricks are
just modeled from memory.
I still have exactly one old 2x4 red brick (the one I used as reference)
and its corners are indeed a bit more rounded than those of later and
contemporary bricks.
I'm already cheating a bit as I never had black wheels (but AFAIR they
did exist) nor did I have black 'window'-bricks, only white and red ones
and I even think they did not exist in any other color at that time ;)
-Ive
Date: 10 Feb 2010 13:13:06
Message: <4b72f732$1@news.povray.org>
Ah, so they must have been phased out for a while, but later (somewhere
around 1980) phased back in.
I still have some of them around here, but I'll need to dig them up.
Are you sure that is not due to wear and tear?
You're probably right, but I'm quite sure the black 1x1 windows did
exist at _some_ time, if only as part of some model in a series of
vintage car sets. Must have been somewhen in the mid- or late 70's though.
