POV-Ray : Newsgroups : povray.binaries.images : Stupid Beginner's Media Problem Server Time
27 Jun 2026 04:12:21 EDT (-0400)
  Stupid Beginner's Media Problem (Message 1 to 4 of 4)
Subject: Stupid Beginner's Media Problem
Date: 11 Nov 2009 19:02:18
Message: <4afb508a$1@news.povray.org>
High!
After Christoph's suggestion to use media for my Saturn's rings, I
started working through the Media Tutorial in the POV manual to get a
thorough understanding of what's media all about... but already at the
first simple demo scene, I ran into an impossibility:
Why gives
sphere // transparent sphere containing media
  { <0, 2, 0>,1
    pigment { rgbt 1 }
    hollow
    interior
    { media
      { emission 1
        density
        { spherical density_map
          { [0 rgb 0]
            [0.4 rgb <1,0,0>]
            [0.8 rgb <1,1,0>]
            [1 rgb 1]
which I literally copied from the tutorial (except for the position of
the sphere's center), no visible media at all? Yes, I noticed that
emitting media is best visible against dark backgrounds, so I set the
ground plane to rgb 0.2 - but all I ever get is an empty grey plane
beneath an empty black sky!
When I lower the sphere's pigment's rgbt level, the sphere becomes
visible (therefore, no wrong camera orientation), but still with no
visible media inside...
See you in Khyberspace!
Yadgar
Subject: Re: Stupid Beginner's Media Problem
Date: 11 Nov 2009 19:32:28
Message: <4afb579c$1@news.povray.org>
>  { <0, 2, 0>,1
>    pigment { rgbt 1 }
>    hollow
>    interior
>    { media
>      { emission 1
>        density
>          { [0 rgb 0]
>            [0.4 rgb <1,0,0>]
>            [0.8 rgb <1,1,0>]
>            [1 rgb 1]
You forgot to move the pattern with the object. If you instead crate the
sphere at the center, and just translate it around once you've equipped
it with the media, you should be fine.
Likewise, if you substituted "onion" for "spherical", you'd have gotten
some visible stuff, too (but again most likely not what you want).
Date: 12 Nov 2009 13:39:34
Message: <4afc5666$1@news.povray.org>
>  { <0, 2, 0>,1
>    pigment { rgbt 1 }
>    hollow
>    interior
>    { media
>      { emission 1
>        density
>          { [0 rgb 0]
>            [0.4 rgb <1,0,0>]
>            [0.8 rgb <1,1,0>]
>            [1 rgb 1]
  Your sphere is centered at <0, 2, 0>, while your spherical density map
is centered at <0, 0, 0>. Thus it's not a surprise that you are not
seeing anything because inside the sphere the density is rgb 0 all over.
  Create the sphere centered at <0, 0, 0> and then translate it to
<0, 2, 0> at the end (ie. after the interior definition).
Date: 12 Nov 2009 16:11:43
Message: <4afc7a0f$1@news.povray.org>
> High!
> Why gives
>  { <0, 2, 0>,1
>    pigment { rgbt 1 }
>    hollow
>    interior
>    { media
>      { emission 1
>        density
>          { [0 rgb 0]
>            [0.4 rgb <1,0,0>]
>            [0.8 rgb <1,1,0>]
>            [1 rgb 1]
> Yadgar
The spherical pattern is centered at <0,0,0> and it density drops to
zero at a radius of 1 unit.
The result is that the density is zero where you placed your sphere.
If you'd made your sphere larger, it would have had some non-zero media
inside of it.
The same apply to the boxed, cylindrical and planar patterns. They are
all defined passing by the origin.
The cure is to create the container around the origin, then to translate
it to where you want it.
boxed have a density of 1 at the origin, it drops to zero at coordinate
+1 and -1 on each axis.
cylindrical have a value of 1 ON the Y axis, droping to zero at radius 1
around it.
planar have a value of 1 on the X-Z plane and drop to zero at +1*y and -1*y.
