POV-Ray : Newsgroups : povray.binaries.images : Brass Lamp Server Time
23 Apr 2026 01:00:33 EDT (-0400)
  Brass Lamp (Message 21 to 26 of 26)
Subject: Re: Brass Lamp
Date: 23 Sep 2009 06:55:22
Message: <4ab9fe9a$1@news.povray.org>
message de news: 4ab9e2ac@news.povray.org...
> That big shadow carving out a triangle on the back wall is not made by the
> lamp flame I guess? or is it? I cannot relate it to something and it is
> what troubles me :-)
I see it as a shadow from a more luminous and remote lamp to something as a
stair and its post.
I like it because it gives us a hint of the scene behind the camera :-)
Marc
Date: 24 Sep 2009 03:24:40
Message: <4abb1eb8@news.povray.org>
"m_a_r_c" <jac### [at] wanadoofr> schreef in bericht
news:4ab9fe9a$1@news.povray.org...
> a stair and its post.
That is what I thought too... but there is something in the geometry or in
the relative position of this shadow that I find disturbing... I am unable
to be much clearer I am afraid.
On the other hand, it nicely frames the lamp.
Date: 24 Sep 2009 04:59:55
Message: <4abb350b@news.povray.org>
"Thomas de Groot" <tDOTdegroot@interDOTnlANOTHERDOTnet> wrote in message
news:4ab9e2ac@news.povray.org...
> Thomas
There is a big window and you are seeing the shadow of the framework of that
window (half moon shape in center with panels forming a larger half moon).
Having the light from the lamp as the only light source was a problem. The
wideness of the base just under the lamp globe made a zone of darkness and I
needed an outside light source to get the lamp base looking like I wanted.
Jim
Date: 24 Sep 2009 05:13:53
Message: <4abb3851$1@news.povray.org>
news:4ab8f036@news.povray.org...
>  I like how you dared to put the lamp somewhere else than at the very
> center of the image. The main object at the very center of the image is
> almost always a very poor choice of composition (although there are some
> exceptions). Being slightly on the side gives a much stronger artistic
> feeling to the image.
Thanks .... used a subtle trick I discovered by mistake! Basically the
camera orbits the table located at origin, depending how much "zoom" you use
a very small rotation of the camera around the origin works nicely. In this
case just 5 degrees.
Jim
Date: 24 Sep 2009 05:19:00
Message: <4abb3984@news.povray.org>
"Paolo Gibellini" <p.g### [at] gmailcom> wrote in message
news:4ab8e326$1@news.povray.org...
> The lamp is awesome!
> Perhaps the edges of the table are too sharp compared to the object on his
> surface.
> Nice work!
> Paolo
Ha-ha ... I've already started work on the table. I've made a "tool" (box
differened by a cylinder) that I'm using to trim some of the edges. The lamp
DID turn out nice .... Thanks
Date: 25 Sep 2009 04:25:09
Message: <4abc7e65$1@news.povray.org>
"Jim Holsenback" <jho### [at] povrayorg> schreef in bericht
news:4abb350b@news.povray.org...
> that window (half moon shape in center with panels forming a larger half
> moon). Having the light from the lamp as the only light source was a
> problem. The wideness of the base just under the lamp globe made a zone of
> darkness and I needed an outside light source to get the lamp base looking
> like I wanted.
Yes, I thought it was something like that. Maybe it is the alignment of the
window's shadow with the table which should be shifted a tiny bit in order
to break its symmetry. It is rather subtle what I have in mind and would
need a bit of experimentation. Also the wall would be great with fine lines
or cracks here and there, and/or some irregularities... Oh well, I should
stop now ;-)
To be sure, this is a great scene anyway, Jim, especially the lamp, but also
the feeling/touch of the objects.
