POV-Ray : Newsgroups : povray.binaries.images : Picking up steam... slowly... Server Time
13 Sep 2025 04:07:15 EDT (-0400)
  Picking up steam... slowly... (Message 11 to 18 of 18)
Subject: Re: Picking up steam... slowly...
Date: 22 Sep 2009 05:14:32
Message: <4ab89578@news.povray.org>
Thomas de Groot schrieb:
> Impressive and interesting. Nice texture too. I am curious to see how long
> you will be able to sustain the CSG construction before render times become
> unmanageable...
I guess that will not happen at all.
I actually found that the detail stuff isn't so much of a problem - it
was the big holes punched into the main struts that bogged down render
times for some reason I didn't fully grasp. I'm using a different
approach for them now, which is much more render-time-friendly:
Previously, I had defined those holes separately from the struts' basic
outline, each of these being a complex compound based on a prism shape.
Changing this to use just one multi-loop prism made quite some difference.
Date: 22 Sep 2009 12:53:48
Message: <4ab9011c$1@news.povray.org>
>> long you will be able to sustain the CSG construction before render
>> times become unmanageable...
A prism is not the more effecient primitive: It's relatively hard to
optimize a "free form" object.
Punching holes in any object result in bounding inefeciency, that
increases the render time.
Each and every ray that encounter the bounding box of one of the struts
needs to be tested against the strut AND every object used to make the
holes.
With the complexe prism, you now only need to test that object.
Date: 22 Sep 2009 12:59:19
Message: <4ab90267@news.povray.org>
Just to show off the hardest single part so far.
The locomotive has 6 of these - plus 2 more that are similar, but a
little less complex.
Still all pure CSG.
Download 'steam.jpg' (63 KB)
Preview of image 'steam.jpg'
Date: 22 Sep 2009 13:03:41
Message: <4ab9036d$1@news.povray.org>
I know that, but...
> holes.
... for some reason the many, many small cylinders I'm cutting away to
round off inward edges don't seem to matter that much.
Date: 22 Sep 2009 14:00:40
Message: <4ab910c8$1@news.povray.org>
> I know that, but...
>> struts needs to be tested against the strut AND every object used to
>> make the holes.
A cylinder is much more effecient than a prism to cut holes.
If you cut ceveral holes using prisms, you need to evaluate each prism
for every rays.
Use two prisms, one for the faces and another for the edges, and add
small cylinders to do the beveling between the faces and the edges.
You'll get an union with no or very few differences or intersections.
Do you use a prism and 3 cylinders to punch those rounded triangular
holes. If you use a besier spline, you can have straight and round
parts, and do away with a good part, even all, of the cylinders. Even if
the prism takes slightly longer to render after that, you'll gain more
by no longer having that difference.
Date: 22 Sep 2009 15:00:51
Message: <4ab91ee3$1@news.povray.org>
Um... yes sir, but how would you cut /straight/ lines with a cylinder?
> for every rays.
'Scuse me, but you're not telling me anything new. I didn't want to go
into that much detail, but that's exactly how I've been doing it right
from the start, except that I didn't make use of multi-loop polygons.
(You're forgetting the spheres and tori, btw... you can't properly bevel
in 3 dimensions without those.)
While this may be so, splines are (a) more cumbersome to work with than
the approach I'm using, as they are not so straightforward, to control;
(b) very difficult to smoothly interface to standard box-&-cylinder
geometry, and (c) I'd be lost with the math required to displace the
spline for the beveling job on the outline (if you know what I mean).
Date: 23 Sep 2009 04:52:19
Message: <4ab9e1c3@news.povray.org>
"clipka" <ano### [at] anonymousorg> schreef in bericht
news:4ab90267@news.povray.org...
> Still all pure CSG.
wow
Date: 23 Sep 2009 08:55:18
Message: <4aba1ab6$1@news.povray.org>
>> Still all pure CSG.
> wow
Absolutely positively possible (at least for me) only due to a
"rounded-off corners thingumajig" framework.
There's absolutely /no way/ I would go through all the pain of computing
and hacking in the parameters for every individual torus, cylinder and
prism in there :-P
