POV-Ray : Newsgroups : povray.binaries.images : 3.7b stack overflow Server Time
14 Nov 2024 06:14:40 EST (-0500)
  3.7b stack overflow (Message 1 to 10 of 11)
Subject: 3.7b stack overflow
Date: 15 Sep 2009 16:22:48
Message: <4aaff798@news.povray.org>
Here is all I managed to render before POV threw an exception. The main
figure is a mesh. It has a reflective finish, absorbing media, a
max_trace_level of 31, 7 dispersion samples, focal blur, and 2182
spheres inside the mesh...
This also happened when I was testing the opal. It seems to have
something to do with having lots of transparent objects inside another
object.
I wonder if I should write up a bug report?
Sam
Download 'stackoverflow.jpg' (139 KB)
Preview of image 'stackoverflow.jpg'
Subject: Re: 3.7b stack overflow
Date: 15 Sep 2009 16:33:58
Message: <4aaffa36$1@news.povray.org>
You should. :-)
It appears odd to me that this should happen with comparatively few (as
it would seem to me) nested transparent objects.
Date: 15 Sep 2009 17:57:49
Message: <4ab00ddd$1@news.povray.org>
stbenge wrote:
> Here is all I managed to render before POV threw an exception...
This is an entirely off-topic, irrelevant comment, but...
It appears that your dialog box image was cropped from a larger image,
presumably the whole screen.  While the PrintScreen key will save the
entire screen, you can also use Alt-PrintScreen to save just the
currently active window -- no cropping necessary.
I _think_ it's Alt-PS, but it might be Ctrl-PS -- I'm using Linux at the
moment and don't want to bother rebooting to Windows to double check.
      -=- Larry -=-
Date: 15 Sep 2009 18:04:50
Message: <4ab00f82$1@news.povray.org>
You're remembering perfectly right - but as Alt-PringScreen only
screenshots a single window, it wouldn't have allowed to capture both
the rendering preview /and/ the error box.
I think we would have missed a fascinating (albeit partial) pictute.
Date: 15 Sep 2009 19:54:41
Message: <4ab02941$1@news.povray.org>
>      -=- Larry -=-
Thanks Larry! I had no idea about that, or else I would have used it.
Sam
Subject: ALT-PrintScreen
Date: 15 Sep 2009 20:08:20
Message: <4ab02c74$1@news.povray.org>
RIGHT-ALT & PrtScreen, else Windows might pop up a dialogue to enhance
screen-contrast for the visually challenged.
Date: 15 Sep 2009 21:16:02
Message: <4ab03c52$1@news.povray.org>
Well, it looked to me that it was two separate screen captures that were
pasted together, which prompted my comment.  Or more likely, the image
was from the saved file and not a screen capture.
Agreed!
      -=- Larry -=-
Date: 16 Sep 2009 05:56:58
Message: <4ab0b66a$1@news.povray.org>
The latter seems pretty unlikely, given that POV-Ray 3.7 at present
doesn't write images to file until render has completed :-)
Subject: Re: ALT-PrintScreen
Date: 16 Sep 2009 06:02:38
Message: <4ab0b7be$1@news.povray.org>
That pretty likely depends on Windows version and/or settings. On my
Windows XP x64, either Alt key will do the job (even though I use German
keyboard settings, where the right Alt key generally does different
things than the left one, and is actually labelled "AltGr").
Date: 16 Sep 2009 08:08:02
Message: <4ab0d522$1@news.povray.org>
Technically, it does ;) The povstate file ... :)
~Mike
