POV-Ray : Newsgroups : povray.binaries.images : My longest render but I'm unhappy Server Time
29 May 2026 12:22:56 EDT (-0400)
  My longest render but I'm unhappy (Message 5 to 14 of 14)
<<< Previous 4 Messages Goto Initial 10 Messages
Subject: Re: My longest render but I'm unhappy
Date: 11 Sep 2009 11:05:00
Message: <web.4aaa66ef489ef02881c811d20@news.povray.org>
OK, a couple final observations:
If you do want to use the iso rather than a heightfield, I noticed that your
isosurface is clipped too high and intersects with the floor, this will get
noticeable when the light fading is working properly.  Change your contained_by
box (This is likely also increasing your render time unecessarily)
   contained_by {box {<-10,-3,-10>, < 25, 1, 25>}}
If you are not happy with the way the lightfading is working switch to media,
with scattering only it doesn't add much render time: (be sure to add "hollow"
to your isosurface or heightfield object for it to work)
#declare WCol=rgb <0.217,0.552,0.877>;
#local FD=3;
#declare i_water =interior {
    ior 1.33
      media{
        absorption rgb 1-WCol
        density{rgb -ln(0.58)/FD}
I did some very quick time comparisons for you:
1) Original iso with fading: 56s
2) Corrected iso (as above) with fading: 40s  (big increase! doesn't have to
calculate back intersections anymore
3) Corrected iso with media: 42s (only slight increase)
4) HF (600x600) with fading: 28s  (another big decrease!)
5) HF (600x600) with media: 30s  (again, only slight increase)
Also note that changin the resoltuion of the HF only increases parse time (and
memory usage) not render time.
Hope this has all been of some help to you.
-tgq
Date: 11 Sep 2009 14:25:10
Message: <4aaa9606@news.povray.org>
Paolo Gibellini wrote:
> Hallo!
> The render of the image I had to propose for IRTC testing session is
> ended yesterday (I have posted a version without water).
> My home hardware is a little obsolete and after a month render was at
> 30%, so I've asked help to a friend with a more efficient machine, which
> completed the work in less than two weeks (ok, I need to upgrade my
> hardware).
> I'm not happy of the final image because it is shady and the golden
> pieces composing the IRTC word doesn't shines as in my intention.
> Sources in p.b.i.
> Have a nice day,
> Paolo
It looks quite nice imo
Date: 11 Sep 2009 18:00:23
Message: <4aaac877$1@news.povray.org>
> #local FD=3;
>     ior 1.33
>       media{
> -tgq
Trevor, thank you sincerely for all your work: you probably spent a lot
of time!
Now I'm beginning to test your suggestion in a more simple scene. I will
post the results.
Thank you again,
Paolo
Date: 11 Sep 2009 18:01:12
Message: <4aaac8a8$1@news.povray.org>
>> Hallo!
>> which completed the work in less than two weeks (ok, I need to upgrade
>> my hardware).
>> Sources in p.b.i.
>> Have a nice day,
>> Paolo
Thank you, Jim!
I will try now Trevor's suggestions.
Paolo
Date: 12 Sep 2009 20:43:01
Message: <4aac4015@news.povray.org>
> Hallo!
> hardware).
> Sources in p.b.i.
> Have a nice day,
> Paolo
Did you use photons? This is a case where "caustics" can avantageously
be used.
Date: 13 Sep 2009 03:11:29
Message: <4aac9b21$1@news.povray.org>
It makes me unhappy, too.   ;-)
Date: 13 Sep 2009 03:25:00
Message: <web.4aac9d08489ef0282182165e0@news.povray.org>
Paolo Gibellini <p.g### [at] gmailcom> wrote:
> Hallo!
> hardware).
We all know what it is like to have slow CPUs. All hardware is slow in the face
of some render jobs. My brother's Tandy CC3 was actually able to compute the
Mandelbrot in 16 hours.
I'm always trying to find ways to speed up my renders. The results are not
always accurate :(
> Sources in p.b.i.
Ideas always shine most brightly in the mind :)
Sam
Date: 15 Sep 2009 07:49:44
Message: <4aaf7f58@news.povray.org>
> be used.
> Alain
Yes, the scene arises from caustics in water test.
Now I'm working on Trevor's suggestions.
Paolo
Date: 15 Sep 2009 07:50:58
Message: <4aaf7fa2$1@news.povray.org>
A trouble shared is a trouble halved,
Paolo
Date: 15 Sep 2009 07:51:52
Message: <4aaf7fd8$1@news.povray.org>
> Sam
I agree...
Paolo
