POV-Ray : Newsgroups : povray.binaries.images : Small problem with the luminous bloom and HDRi Server Time
23 Dec 2025 22:06:11 EST (-0500)
  Small problem with the luminous bloom and HDRi (Message 1 to 5 of 5)
Subject: Small problem with the luminous bloom and HDRi
Date: 7 Sep 2009 14:38:13
Message: <4aa55315@news.povray.org>
// intensity of glare effect
#declare intensity = 1;
// quality of the effect
// use values between 0 and 1 (with 1 being best [and slowest])
#declare quality = 1;
// intensity falloff method
// 0 = constant falloff
// 1 = intensity divided by distance - default
// 2 = inverse square of distance
#declare falloff_method = 1;
// radius of effect
// change independent values for width/height
#declare rad = <2,1.8>*0.05; // .05;
Download 'lb5t.jpg' (78 KB)
Preview of image 'lb5t.jpg'
Subject: Re: Small problem with the luminous bloom and HDRi
Date: 7 Sep 2009 18:28:54
Message: <4aa58926@news.povray.org>
> // radius of effect
> Alain
Is this a macro?
Date: 7 Sep 2009 19:49:05
Message: <4aa59bf1$1@news.povray.org>
>> // radius of effect
>> Alain
> Is this a macro?
by legendary Sam Benge.
Date: 8 Sep 2009 04:01:13
Message: <4aa60f49$1@news.povray.org>
nemesis schrieb:
>> Is this a macro?
So chances are it works by overlaying zillions of shifted variants of
the pigment ;-)
I presume that somewhere in the process Sam used the input file to drive
a color_map or such. In that case, unfortunately HDRI colors are
"wrapped" to the 0..1 range. In that case the macro would need a major
overhaul to make it work with HDR images.
Date: 8 Sep 2009 12:06:41
Message: <4aa68111@news.povray.org>
>> // radius of effect
>> Alain
> Is this a macro?
No. Those are only a part of the scene where the parameters of the
luminous bloom are set.
Just using the lb5.pov, from Samuel T. Benge, scene file that does a
luminous bloom post process on a previously rendered image.
