POV-Ray : Newsgroups : povray.binaries.images : Using a couple of proximity patterns Server Time
29 May 2026 10:29:27 EDT (-0400)
  Using a couple of proximity patterns (Message 1 to 10 of 20)
Subject: Using a couple of proximity patterns
Date: 4 Sep 2009 05:12:44
Message: <4aa0da0c@news.povray.org>
Hi all,
I promised to show some results of my experimentation with proximity
patterns, using my cenotaph building. The attached image shows three
results, from top to bottom:
- Patina2 macro (Rune Johansen/James Coons; 2003/2004). The pattern gives an
interesting result for the building but it renders veeeerrrryyy slowly. The
image took more than three hours to complete.
- df3prox macro (Edouard Poor; 2009). Something rather similar to Patina2.
Parsing the present df3 file took about half an hour but the render was very
fast. I believe that I have not yet got the parameters correctly as there
are still some artifacts showing.
- fastprox3 macro (Sam Benge; 2009). Very fast parsing/rendering. I added
here an adapted version of the wear pattern provided by Sam in his demo file
to get a more interesting result. The settings especially of the pigment in
the pigment_map block seems to be more tricky than with the other patterns.
I am not really sure why.
What do you think?
All the best,
Download 'boullee_cenotaphe_proxpat.jpg' (190 KB)
Preview of image 'boullee_cenotaphe_proxpat.jpg'
Subject: Re: Using a couple of proximity patterns
Date: 4 Sep 2009 05:56:35
Message: <4aa0e453@news.povray.org>
Hi
I tested Edouard's df3prox test scene with some meshes
I don't see such artifacts.
I use :
#declare resolution = <30,30,30>;
#declare num_samples = 100;
#declare sample_radius_fraction = 4;
I still have to test the others methods :-)
Marc
message de news: 4aa0da0c@news.povray.org...
> Hi all,
> an
> The
> very
> file
> in
> patterns.
> What do you think?
> All the best,
> Thomas
Download 'DF3Prox_Ajax_Aphrodite.jpg' (47 KB)
Preview of image 'DF3Prox_Ajax_Aphrodite.jpg'
Date: 4 Sep 2009 06:00:01
Message: <web.4aa0e4149d317c83c83e2c410@news.povray.org>
> Hi all,
> What do you think?
"Oh dear, mine looks terrible"
What are the parameters you're using (for the macro and for the textures)? It
might be able to be improved a little.
I am interested in the rendering speed, as I was hoping that, at least, would be
faster than other methods. Can you give some more timings?
Cheers,
Edouard.
Date: 4 Sep 2009 06:35:00
Message: <web.4aa0ec379d317c83c83e2c410@news.povray.org>
"m_a_r_c" <jac### [at] wanadoofr> wrote:
> Hi
> I use :
Oh wow - those look great! Cool!
Because the DF3 pattern runs over a regular spaced grid, I suspect it works much
better on more irregularly shaped objects like those meshes, rather than regular
objects like sphere's etc. Or at least with less tuning required...
Cheers,
Edouard.
Date: 4 Sep 2009 06:49:08
Message: <4aa0f0a4@news.povray.org>
web.4aa0ec379d317c83c83e2c410@news.povray.org...
It's your work lol, I only dropped those meshs in your test scene, tuned the
bronze texture at my taste and modified your inc file.
the defaut values declared there (as mesh_mode=false) are not overridden by
those declared in the pov file.
> works much
> regular
That's what I suspected too :-)
Marc
Date: 4 Sep 2009 07:15:01
Message: <web.4aa0f5a69d317c834726e92b0@news.povray.org>
> What do you think?
Thomas, to me Edouard's has the best overall coverage and look (aside from the
rather obvious radial pattern). I really like the dome arches you've added. The
original bald dome design was rather bland. Nice work!
-Rob
Date: 5 Sep 2009 03:59:40
Message: <4aa21a6c$1@news.povray.org>
"Edouard" <pov### [at] edouardinfo> schreef in bericht
news:web.4aa0e4149d317c83c83e2c410@news.povray.org...
Probably the settings....
> It
#declare interpolation_mode = 2;
#declare resolution = <80,80,80>;
#declare num_samples = 60;
//Proximity_SetBailoutValue( 30 )
#declare add_noise = true;
I used your demo pigment_pattern code without changes;
as pigment_map I used:
        pigment_map {
            [0.30 color rgb <0.837064, 0.814426, 0.762936>]
            [0.50 color rgb <0.625, 0.5729, 0.454396>]
            [0.60 color rgb <0.3854, 0.395833, 0.1875>]
Not being entirely sure about what I am doing, I am sure that you can
improve on this :-)  However, Marc might be right about the difficluty in
tuning a regular surface.
> would be
I did not really note those down. What I remember is that apart from the
parsing of the df3 which took about 30 minutes, the render was finished in
no more than 4 minutes on a dual core machine.
Date: 5 Sep 2009 04:04:53
Message: <4aa21ba5$1@news.povray.org>
"Robert McGregor" <rob### [at] mcgregorfineartcom> schreef in bericht
news:web.4aa0f5a69d317c834726e92b0@news.povray.org...
> the
> added. The
Thanks Robert. The original design indeed needed a bit of extra attention.
Possibly, I shall add or change some more things.
To me also Edouard's is approaching closest to what I want. Sam's seems to
be the most difficult to tune (perhaps due to my stupidity though) with or
without the extra wear given to the pigment_pattern.
Date: 5 Sep 2009 04:06:49
Message: <4aa21c19$1@news.povray.org>
"m_a_r_c" <jac### [at] wanadoofr> schreef in bericht
news:4aa0e453@news.povray.org...
> Hi
> I use :
I feel ashamed when I see this indeed :-)  Maybe, as you say below, a
regular surface is more difficult to tune right...
Date: 5 Sep 2009 05:32:07
Message: <4aa23017@news.povray.org>
OK, Edouard, it seems that I exagerated my settings. Going back to basics, I
get a much better result as the image may testify.
Using these settings now:
 #declare sample_radius_fraction = 2;
All other things equal. Parsing of the df3 took a couple of minutes; render
in about 2.5 minutes.
Download 'boullee_cenotaphe_adapted_df3prox.jpg' (43 KB)
Preview of image 'boullee_cenotaphe_adapted_df3prox.jpg'
