POV-Ray : Newsgroups : povray.binaries.images : Assumed_gamma, too bright and washed out Server Time
29 May 2026 12:24:24 EDT (-0400)
  Assumed_gamma, too bright and washed out (Message 11 to 14 of 14)
Subject: Re: Assumed_gamma, too bright and washed out
Date: 8 Sep 2009 11:58:23
Message: <4aa67f1f$1@news.povray.org>
SharkD a écrit :
> Alain wrote:
>> This forces both medias to use the same number of samples.
>> Also, the sampling for the clouds probably continue into the haze media.
>> To use only one container, you'll need to add another density pattern.
>> One media with a single density for the haze.
>> One media with two densities for the clouds. The new pttern can be
>> "planar" with a map similar to: (added in the cloud's media block)
>> density{planar {color_map{ [0 rgb 0][0.02 rgb 1] }}}
>> To have the clouds go sharply from invisible to full density.
>> Two media in a container add.
>> A media with two densities multiply the densities.
>> Alain
> Actually I am using concentric spheres. The media attached to the
> smaller sphere uses an onion pattern, so I'll need to figure out how to
> limit it to just the assigned area instead of repeating.
> -Mike
In that case, you can use the spherical pattern, scaled and with a
color_map set to only have a shell.
something like:
density{spherical scale 1000 color_map{[0 rgb 0][0.0000001 rgb 1][0.001
rgb 1][0.0010001 rgb 0]}}
Date: 13 Sep 2009 03:08:05
Message: <4aac9a55$1@news.povray.org>
How did you do the glass spheres? Can you give me the code for them? Thanks.
Date: 13 Sep 2009 15:42:45
Message: <4aad4b35$1@news.povray.org>
I *think* this is where I got them from:
http://www.interq.or.jp/blue/kawashu/
-Mike
Date: 13 Sep 2009 22:15:30
Message: <4aada742$1@news.povray.org>
Hmm... I just checked it out, maybe not good enough. i couldn't see these
glass spheres there. Sure it's from there? I just like them!
