POV-Ray : Newsgroups : povray.binaries.images : I think warp is right ... 3.7 gamma Server Time
11 Apr 2026 10:55:21 EDT (-0400)
  I think warp is right ... 3.7 gamma (Message 1 to 10 of 14)
Subject: I think warp is right ... 3.7 gamma
Date: 1 Sep 2009 16:43:39
Message: <4a9d877b@news.povray.org>
two renderings of the same scene. Both rendered in 3.7,
chextest-36 has #version 3.6 defined, chextest-37 does not.
No matter how hard I try with lighting, I cannot get the 3.7 version to
look anything other than "Washed-out"
This is with the Display_Gamma setting set at 2.2
Setting Display_Gamma changes how the image looks POV-Ray's render
window, but does nothing to correct the image.
It doesn't matter what my monitor is set to, even properly calibrated
(with a colorimeter) it loses plenty saturation, and looks washed out.
~Mike
Download 'chextest-37.jpg' (9 KB) Download 'chextest-36.jpg' (10 KB)
Preview of image 'chextest-37.jpg'
Preview of image 'chextest-36.jpg'
Subject: Re: I think warp is right ... 3.7 gamma
Date: 1 Sep 2009 18:09:49
Message: <4a9d9bad@news.povray.org>
  Did you try setting File_Gamma and then rendering to an image format
other than PNG (ie. one which has no gamma metadata)? Or, alternatively,
did you try to remove the gamma metadata from the PNG to see how it
affects it?
Date: 1 Sep 2009 18:47:26
Message: <4a9da47e$1@news.povray.org>
> affects it?
No, I didn't ... I'll play with this later on.
Date: 1 Sep 2009 19:30:35
Message: <4a9dae9b$1@news.povray.org>
>> affects it?
I can't find anything that will remove the gamma setting of a png image.
Date: 2 Sep 2009 01:25:08
Message: <4a9e01b4$1@news.povray.org>
Guys, you're still on the wrong track!
As I've pointed out to Warp about half a dozen of times, it is the
/input file/ gamma handling that's broken indeed.
Your image looks washed out because the texture /is/ washed out (from
the render engine's point of view).
Convert the texture file to PNG using IC for instance (to make sure it
has a gAMA chunk, too), and you should be perfectly fine.
Date: 2 Sep 2009 04:26:52
Message: <4a9e2c4c$1@news.povray.org>
> As I've pointed out to Warp about half a dozen of times, it is the /input
> Your image looks washed out because the texture /is/ washed out (from the
Exactly.  POV assumes all input files and colour literals are in linear
colour space.  Images and colours that you see on your monitor (eg in
picture viewer, colour picker, or on the web) are not in linear colour
space, they have already been gamma corrected.  Unless you "undo" the gamma
correction before handing them to POV, your output file is going to look
very washed out as essentially they have been gamma corrected twice.  This
is very obvious if you pick colours in Windows and then try to use them in
POV, without undoing the gamma correction first they can be very obviously
wrong!
> Convert the texture file to PNG using IC for instance (to make sure it has
Or alternatively you can use a paint program to undo the gamma correction
and save as bmp or jpeg.  I think someone also posted some SDL code here to
do the conversion within POV.
Date: 2 Sep 2009 07:04:47
Message: <4a9e514f@news.povray.org>
> gamma correction before handing them to POV, your output file is going
> to look very washed out as essentially they have been gamma corrected
> twice.  This is very obvious if you pick colours in Windows and then try
> to use them in POV, without undoing the gamma correction first they can
> be very obviously wrong!
Isn't this counterintuitive? Heck, even Photoshop, which has a very
sophisticated color correction system will give you the colors you
expect. e.g. If I give a 50% gray on input, I get in the output a 50% gray.
> correction and save as bmp or jpeg.  I think someone also posted some
> SDL code here to do the conversion within POV.
In fact a gamma of 0.46 works well to "uncorrect" the gamma setting in
the image, but this does cause a loss of color fidelity in the
highlights, because the highlight area is being stretched over a larger
range of colors, this could potentially cause posterization and banding
in gradients.
With the following scene, what would you expect the output color to be?
global_settings
     max_trace_level 20
camera
     location <0, 0.2, -5>
     look_at 0
box
   -1,1
   pigment { color rgb .5 } // intuitively: 50% gray!
   finish { ambient 1 }
Sampled with irfanview, the box samples as 186,186,186 (not 128,128,128
gray as you would expect!)
If your monitor is calibrated to a 2.2 gamma, this will be too bright,
My colorimiter doesn't allow me to select a gamma higher than 2.4. With
the monitor calibrated to the same gamma as a Macintosh it is way to
bright. There is no calibration where the colors will look right.
Download 'gamma.png' (2 KB) Download 'gamma_ps.png' (4 KB)
Preview of image 'gamma.png'
Preview of image 'gamma_ps.png'
Date: 2 Sep 2009 10:59:10
Message: <4a9e883e$1@news.povray.org>
Maybe, but I can see why POV was written the way it was.  If you specify rgb
0.5 that means you want 50% physical brightness compared to rgb 1.0.  Note
however, that if you are looking at an image in paint, RGB 128,128,128 is
*not* 50% brightness on a normal monitor.
There have been several discussions here about adding a new keyword to POV
so that you can specify gamma-corrected colours and images in SDL.
> in gradients.
That's totally the wrong thing to do.  You *must* set POV's output gamma
correction to match your monitor (or just to 2.2 as it's a kind of standard
nowadays anyway) to get anywhere near realistic scenes.  Then you need to
make sure any colours or images you are giving to POV as *inputs* are in
linear colour space (ie they have not already been gamma corrected).
<snip>
With an output gamma correction of 2.2, I would expect the colour to be
0.5^(1/2.2) * 255 = 186,186,186
No, I make it correct.  (186/255)^2.2 = 0.5, so on a monitor with 2.2 gamma,
186 should be half as bright as 255.
The problem with *inputs* to POV is that a user sees a pixel of (255,186,0)
on their desktop (ie 100% brightness red, 50% brightness green, and 0%
brightness blue) and inputs this to POV:
pigment { color rgb <255,186,0>/255 }
finish{ ambient 1 }
Then renders and checks the pixel value in a paint program.  It gives
<255,221,0> a totally different colour (and washed out).  The only way to
get around this currently is to apply some inverse gamma to the colour you
want out before you give it to POV.  Of course you need to do this for
images too.
Date: 2 Sep 2009 17:52:17
Message: <4a9ee911$1@news.povray.org>
(Well, to be /exact/, they /are/ in linear color space (or should be),
because the display hardware's gamma and the gamma pre-correction cancel
out; after all, that's what the pre-correction is for ;-))
Date: 3 Sep 2009 03:43:39
Message: <4a9f73ab$1@news.povray.org>
>> Images and colours that you see on your monitor (eg in picture viewer,
>> colour picker, or on the web) are not in linear colour space, they have
I meant the actual image and colour data itself, like what is stored in a
jpeg file, or when you set the fill colour to (220,120,64) in a graphics
program.  All those values you are used to seeing and probably "knowing"
have already had gamma correction applied to them, you cannot just use them
directly in POV without undoing the implied gamma correction first.
