POV-Ray : Newsgroups : povray.binaries.images : trying to combine SSS and radiosity (80kb jpeg) Server Time
17 Mar 2026 04:20:31 EDT (-0400)
  trying to combine SSS and radiosity (80kb jpeg) (Message 1 to 5 of 5)
Subject: trying to combine SSS and radiosity (80kb jpeg)
Date: 29 Aug 2009 17:36:07
Message: <4a999f47@news.povray.org>
Hi everyone,
Now that we have backside illumination in 3.7, I thought I would try to
combine subsurface scattering and radiosity with it.
I used two objects to get the SSS effect. One object is inside the
other, scaled along the normals so that it fits neatly inside. The
outside object uses unrealistic diffuse n,n values. The inside object is
just a container for media.
The backside illumination takes media (and also the
fade_power/fade_distance/fade_color interior attributes, not used here)
into account, so what we have is an opaque, paper-like shell filled with
a light-attenuating medium to keep the rays from going too far.
If POV could have an object look at its own interior media (and
fade_power stuff), two objects would not be needed for this effect.
Here is a quick look at the objects and materials:
union{
  object{dodecaWire_p1_
   pigment{rgb 1 transmit 0}
   finish{diffuse .25,.75}
  object{dodecaWire_p2_
   pigment{rgbt 1}
   interior{
    media{absorption<.25,.5,1>*15}
  hollow
Notice in the image how shadows cast from the POV logo do not make much
of a difference in the SSS effect. The is the main reason I consider
this only a partial success.
Perhaps this technique could shed some light on how radiosity and
subsurface scattering may someday be joined happily? Perhaps also
somebody can trick POV into allowing an object to recognize its own
interior media and fade_stuff as far as backside illumination goes? That
would be cool :D
Sam
Download 'sss_rad.jpg' (77 KB)
Preview of image 'sss_rad.jpg'
Subject: Re: trying to combine SSS and radiosity (80kb jpeg)
Date: 29 Aug 2009 18:09:53
Message: <4a99a731$1@news.povray.org>
stbenge schrieb:
 > Perhaps also
> would be cool :D
I must confess I have no idea whatsoever what you mean by that.
Date: 29 Aug 2009 19:36:45
Message: <4a99bb8d$1@news.povray.org>
clipka wrote:
> stbenge schrieb:
>  > Perhaps also
>> That would be cool :D
Okay, take this object for instance:
  pigment{rgb 1}
  interior{
  hollow
Render that and you have no SSS effect, you only get backside
illumination effects. You might as well have not even given that object
media.
An object's media (or interior fading) will not cast shadows onto the
object itself.
Date: 30 Aug 2009 08:20:46
Message: <4a9a6e9e$1@news.povray.org>
> media.
> object itself.
That's not how it should be of course.
Now that you mention it, I didn't add any code to explicitly inform
POV-Ray that during the backside shadow testing we're /inside/ the
object of course (if it is solid and not just a patch). Symptoms to be
expected: Failure of POV-Ray to compute media for the object...
Ouch.
Date: 30 Aug 2009 19:08:10
Message: <4a9b065a$1@news.povray.org>
>> object media.
>> object itself.
I thought so too, but figured there was a good reason why the developers
left out support for it.
> Ouch.
Unless I'm mistaken, such a thing would have gone unnoticed for a long
time...
BTW, thank you for all the effort you've been putting into POV lately :)
