It looks good, except, it's gone plaid...
Looks like everything worked as expected, except the left edge and top
edge didn't have appropriate normals, causing a plaid effect.
Any ideas on how to counter this?
Download 'plaid.jpg' (131 KB)
Preview of image 'plaid.jpg'
Hmmm... An attempt, using the mean delta between two rows or columns.
Download 'deplaided.jpg' (118 KB)
Preview of image 'deplaided.jpg'
Haha! Perfection!
Instead of the mean of the deltas, I used the median of the deltas!
Download 'deplaided_median.jpg' (64 KB)
Preview of image 'deplaided_median.jpg'
On Mon, 31 Aug 2009 09:21:24 -0500, Mike Raiford <mraXXXiford.at.@g1023mail.com>
wrote:
>Haha! Perfection!
Congratulations Mike, but excuse my ignorance. What is the difference between
normal maps and bump maps?
Regards
A normal map stores the (relative) surface normal vectors in the RGB
channels of the image, whereas a bump map (which POV-Ray uses) stores
the perceived height of the surface as a gray value.
Normal maps are actually more flexible in how they can alter the surface
normal of an image than bump maps. But, obviously these don't work in
POV-Ray yet.
~Mike
On Mon, 31 Aug 2009 11:11:21 -0500, Mike Raiford <"m[raiford]!at"@gmail.com>
>POV-Ray yet.
Thanks Mike,
I could have Googled it but I was doing an "Invisible" :P
What applications are they used in?
Regards
Stephen wrote:
> Thanks Mike,
The one I've been messing with was output by the game Spore, when I
exported my creature to a mesh.
I think Blender and other modeling programs use them as well. I'm
betting inside a lot of games that use D3D hardware probably use them,
since they can give better surface normal results. Many of the
commercial 3D packages can use them, too.
~Mike
Like, every 3d app beside POVRay.
[/rant]
> [/rant]
Something like that :-D
~Mike
On Mon, 31 Aug 2009 14:23:53 -0500, Mike Raiford <"m[raiford]!at"@gmail.com>
>> [/rant]
Well my ignorance is bliss since I don't play games and only use Pov. Except
maybe Poser but I don't use the render o/p much.
Heigh Ho! :D
Regards
