POV-Ray : Newsgroups : povray.binaries.images : Normal map to bump map ... plaid. Server Time
23 Apr 2026 00:47:21 EDT (-0400)
  Normal map to bump map ... plaid. (Message 3 to 12 of 12)
<<< Previous 2 Messages Goto Initial 10 Messages
Subject: Re: Normal map to bump map ... plaid.
Date: 31 Aug 2009 10:21:46
Message: <4a9bdc7a@news.povray.org>
Mike Raiford wrote:
> Mike Raiford wrote:
>> It looks good, except, it's gone plaid...
>> Looks like everything worked as expected, except the left edge and top
>> edge didn't have appropriate normals, causing a plaid effect.
> Hmmm... An attempt, using the mean delta between two rows or columns.
Haha! Perfection!
Instead of the mean of the deltas, I used the median of the deltas!
Download 'deplaided_median.jpg' (64 KB)
Preview of image 'deplaided_median.jpg'
Date: 31 Aug 2009 11:13:18
Message: <c1qn951s1e0bouht40f6h20p00hspt2lp6@4ax.com>
On Mon, 31 Aug 2009 09:21:24 -0500, Mike Raiford <mraXXXiford.at.@g1023mail.com>
wrote:
>Haha! Perfection!
Congratulations Mike, but excuse my ignorance. What is the difference between
normal maps and bump maps?
Regards
Date: 31 Aug 2009 12:15:20
Message: <4a9bf718$1@news.povray.org>
A normal map stores the (relative) surface normal vectors in the RGB
channels of the image, whereas a bump map (which POV-Ray uses) stores
the perceived height of the surface as a gray value.
Normal maps are actually more flexible in how they can alter the surface
normal of an image than bump maps. But, obviously these don't work in
POV-Ray yet.
~Mike
Date: 31 Aug 2009 13:22:50
Message: <1f1o95dndcda38aosdgicmek13khh04472@4ax.com>
On Mon, 31 Aug 2009 11:11:21 -0500, Mike Raiford <"m[raiford]!at"@gmail.com>
>POV-Ray yet.
Thanks Mike,
	I could have Googled it but I was doing an "Invisible" :P
What applications are they used in?
Regards
Date: 31 Aug 2009 13:27:35
Message: <4a9c0807$1@news.povray.org>
Stephen wrote:
> Thanks Mike,
The one I've been messing with was output by the game Spore, when I
exported my creature to a mesh.
I think Blender and other modeling programs use them as well. I'm
betting inside a lot of games that use D3D hardware probably use them,
since they can give better surface normal results. Many of the
commercial 3D packages can use them, too.
~Mike
Date: 31 Aug 2009 15:20:00
Message: <web.4a9c2234f8a102de15bacd950@news.povray.org>
Like, every 3d app beside POVRay.
[/rant]
Date: 31 Aug 2009 15:27:52
Message: <4a9c2438$1@news.povray.org>
> [/rant]
Something like that :-D
~Mike
Date: 31 Aug 2009 15:39:12
Message: <ll9o9519hj4loljt47lnh4qoh7i6cs3fe2@4ax.com>
On Mon, 31 Aug 2009 14:23:53 -0500, Mike Raiford <"m[raiford]!at"@gmail.com>
>> [/rant]
Well my ignorance is bliss since I don't play games and only use Pov. Except
maybe Poser but I don't use the render o/p much.
Heigh Ho! :D
Regards
Date: 31 Aug 2009 18:52:35
Message: <4a9c5433@news.povray.org>
Mike Raiford wrote:
>>> top edge didn't have appropriate normals, causing a plaid effect.
> Haha! Perfection!
used map:
Download 'test.jpg' (57 KB)
Preview of image 'test.jpg'
Date: 1 Sep 2009 05:33:50
Message: <4a9cea7e@news.povray.org>
"Mike Raiford" <"m[raiford]!at"@gmail.com> schreef in bericht
news:4a9c0807$1@news.povray.org...
> I think Blender and other modeling programs use them as well. I'm betting
> inside a lot of games that use D3D hardware probably use them, since they
> can give better surface normal results. Many of the commercial 3D packages
> can use them, too.
Ah! I remember now that GeoControl (a heightfield program) can generate
normal maps too. I always wondered what I could do with them... in Pov I
mean... :-)
Thanks for lighting my dim understanding torch...
